Bronco Sin Nombre!
Travisfab
Moderator
Staff member
Aug 21, 2003
19,966
188
Keep it stock or + .5 with rubber bushings. Uniballs can get closer to 2". I'd need to see the back of your radius arms to say for sure, but something along the lines of a bung stacked on top of the one you have now with a sleeve and some plate.
1,033
78
#92
Ive got uniballs, but now I'm thinking is it really worth the work for 1-2 inches? lol. If I'm understanding you correctly, you're saying to lengthen the radius arm to push the beam forward, achieved by adding material where the helm threads into the bung?
If so, i don't think I'm explaining my situation clearly haha. please see super simple sketch for clarity (hopefully)
Because the angle of the radius arm at the beam cannot change, as the beam gets pushed forward, the radius arm moves out away from the frame. so i need to change the angle of the radius arm coming off the beam, as well as making the radius arm longer (heim is buried though so i may have enough there)
1,033
78
#93
nothing? hmmm.. I guess ill just start messing with it and see what happens lol. On another note:
Got my lights set up in the fab lab. still need to clean up the wiring, but ill take care of that when I hardwire them in, no more extension cords!
This pic was taken at night (like above) and no flash or other lights used
I also got my coolant reservoir mounted and plumbed. Im not digging the hose though. But i don't know if it bugs me enough to go baller AN stuff... would cost about $150 to plumb the reservoir and the TB heater, but would really clean it up...
Likes: Turboyota
1,033
78
#95
I literally just got off the phone with desolate and this is the route I'm taking. Going to pick up a set of arms and the brackets for the beam, just need to measure and make sure the length is good, if not Greg will make them longer or shorter as needed. Only thing that has me nervous losing the gusset from the radius arm to the beam. Will make shock mounts easier, but losing strength where the beam was extended. Would an overlay on the front and back, maybe top/bottom as well make a difference?
5,891
211
you could make an over lay for all the sides and make your tabs for the radius arm "long" on the weld side to extend from the beam end to whereever the rad arm needs to be.....hm that doesnt really get my idea across accurately.....
Likes: yltaco05
1,033
78
#97
I measured my radius arms and they are currently 36.75" from back of beam to center of heim (heim is buried into the bung...) Desolates arms are 36" back of beam to center of heim. Since I'm moving the beams forward about 2" that would put me at 38.75". I could A) move the radius arm brackets forward 2.75" and drill another set of holes in my frame. or B) have desolate make the arms 2.75" longer. Either way i will probably get the beams set where i want them before doing A or B.
Oct 18, 2017
67
6
Jamul
#98
Man that work space looks nice.. sometimes I really hate having to work on my truck in the mud. What did you do for your windshield washer tank since the OEM ones connected to the coolant overflow?
1,033
78
#99
Thanks man! The concrete has been nice, but now that its covered and the lights are up, so much better. I have another tank like the overflow that i will use for washer fluid, along with an inline pump. The previous owner removed the factory tanks to make room for air horns, priorities... I could have gotten a stock set up, but found these and thought they would look killer.
Likes: zachwabbit
