Revamping the old 83 pickup with the tweaker cab!
itsmassari
Apr 14, 2014
56
#24
Well been moving slower than i anticipated, but finally close. Tonight i plan on attaching the intake manifold and all the remaining parts in hope of dropping the motor in by the end of the week.
I need a new carb, and want to put in an electronic ignition system. Any recommendations?
itsmassari
Apr 14, 2014
56
#26
Biggest improvement to those is fixing the distributor. Ditch the vacuum advance and limit the mechanical advance to 22*. Run 10* initial and 32* total. Same thing LC does. I can walk you through it.
I’d Absolutly be up for that. Kinda new to carbs and carb tuning etc so I’d love to see what you recommend.
The carb it came with is kinda shitty hence wanting to get a better one just don’t know if it’s worth getting an OeM replacement or a Holley or something else.
I’m your opinion is an electronic ignition not worth it?
9,632
446
#27
I never used anything other than a good coil. It would support 8500RPM.
I had the best luck with a Holley 350 2 barrel with a few mods.
Webber did not like to be off camber, would stumble an die on the side of hills.
Dual side drafts made the most HP on top but were always needing adjustment. Holley made more power low to mid range.
If you could find one of the old Cannon Holley manifolds that would be the hot set-up. I not an adapter to the stock manifold works pretty well.
Oct 15, 2018
6
1
mission viejo
#29
I got everything you want to make that motor scream I have a dui distributor thats practically brand new with live wire cables and I have the weber side draft 40mm carbs its non vacuum advance distributor and I have a full jet kit for it as well lmk if your interested
Likes: itsmassari
itsmassari
Apr 14, 2014
56
#30
Possibly that distributor and cables.
