The DangerRanger
305
55
Carolina South
Next question is this... Is it better to weld the suspension mounts to the frame or bolt?
I remember it used to be I would only see bolted. But when I built my Toyota many years ago I just welded the mounts for the arms and welded the subframe straight to the frame.
Once I get everything tacked on an looking good/ cycling without issue could I just full weld everything instead of using the rivet holes as bolt holes?
It's a tight fit but able to get base line std cab wheel base of 108 inch
So far everything checks out at ride height.
I have the tabs for the radius arms and the tubes cut. Now to decide the attachment to the beams
2,563
443
Weld the beam pivot and steering swinger mounts. If you fuck them up, you have a Chinee Prasma Cuttel!
If radius arms attach to the frame rails, weld the pivot boxes. If you go center mount or semi-center mount, make the x-member easy to remove.
That’s my dos pesos.
Nov 9, 2008
305
55
Carolina South
So far it's gonna be a center Mount radius arm rig! Should have the pics up tomorrow. That prasma cwutta is the bomb!
Once you start welding on a Ford frame you better just go ahead and box the whole thing.
You welded your cage on right? Your all ready boned, keep welding.
Hahaha! Ok I'll keep on boneing away! I had thought about boxing it at some point. Guess it'll have to happen.
Thanks guys!!!
Nov 9, 2008
305
55
Carolina South
Looks good! Check firewall clearance at full bump and full lock with the wheel and tire combo you plan to use ASAP.
Good call! Hopefully I don't have to hack into that ! (To much)
I'm gonna have to get all Kung Fu and karate chop out those wheel wells and relocate then coolant overflow, battery, windshield washer bottle, and other such items
2,563
443
Or push the front wheels forward if you have interference issues.
