Warning: I don't work at Deaver anymore, this is a personal opinion.
H-70 is a toyota spring. There have been a lot of part number changes since I left, so I couldn't tell you if H70 is still the high-arch version. The tall one if you measure from an imaginary center line (eye-eye) to the main leaf it should be 15".
G-50s are a ranger spring. 14 leaves is extremely high. On Pete Albano's ranger we used 9 leaves of extra thin material, and his ranger was heavy. The rear-end is swapping back and forth because your springs are too stiff which means you have no droop. Your rebound has to be slow to accomodate the high spring rate, and you axle is not dropping out fast enough because of this. This is bad x 2.
Before I left Deaver, I designed and tested a new light, high-travel spring that I was very happy with. With Jeff's blessing I tried to private label it, but no one wanted to buy it. Still have the design print though...and I do happen to know where 1 never used set is...
Dan: your first pack was 7 leaves. The x-pack was 9 I think with the bottom 3 flattened. I've just now gotten my x-pack to work how I want it (thanks to some help from Pete, like usual). It is, as always, in the rebound damping.
