You can run it in 1400 or 1450, not the new 1500 class.
::: CAMBURG ENGINEERING ::: 714-848-8880 ::: "Race proven & championship winning suspension"
Thanks scott
OG Member
Then conquer we must, when our cause it is just,
And this be our motto: "In God is our trust."
And the star-spangled banner in triumph shall wave
O'er the land of the free and the home of the brave!
"The Star-Spangled Banner"
I am having a tough time reading some of these posts already.....
I will try and cover what is obvious that I feel is being overlooked.
Simon.... 1400 has NOT changed. If you wanted to race that class last week, then you will still want to this week. NOTHING has changed.
AJ.... Your truck will be good to go as the upper arm is still in the stock location. Just without the cross shaft, along with the lower arm being mounted to the stock mount.
Tool.... You are killing me brother!! I think the class is going to be a huge success. Mini trucks must run a 4 or 6 cyl that is manufactured for the make/model of the truck that does not exceed the 4 or 6 cyl rule. Full size trucks can run the same 6 cyl or V8s offered in there trucks or current models.
T100s NEVER came with a V8, so no the 4.7(not 4.8) is NOT legal in it. yes, you can update your older Tundra to the newer 5.7 Toyota V8 if you choose.
SUVs can run the same V8 that is offered for them. If you want to run a leaf sprung 4 runner or explorer with the V8s offered for them then it is legal. I don't see ANY showing up though.
Tom.... No equal length beams. They travel on a totally different arc than the factory mounted beams, and are not on the factory beam mount, so they are out. Equal length beams are getting too far away from a production bolt on class also.
As for 1500 being a pro class... This is what the class is. We DON'T need another sportsman class. The target trucks for this class will be 7s, 7sx, class 3, stock mini, stock full, and leaf sprung legal 1450s. All but one of those classes is a pro class. You will NOT draw ANY of the other trucks out of their outdated pro classes with 1500 being a sportsman class. We don't need another 4 truck class in the field. This class will draw high numbers once it get rolling. Also as I said, WE as racers don't need ANOTHER Sportsman class. All the laps is part of ALL pro classes also.
Dan Vance
so quick question, an old explorer can run a 302 since it came in the new explorer's correct?? If so I might know what i'm gonna build if I sell my truck..
An Explorer is a mini truck though.
FiberwerX - Summers Brothers - Total Chaos - Down South Motorsports - San Diego Carburetors - LC Engineering - iForce Graphics
Bring out the old explorer with a 302 in it. Just make sure it fits the cab rules. Must have a complete steel cab. Also, all doors must open and close from inside and out using factory hinges and latches along with functioning handles.
If you can do that with an Explorer or 4Runner, and want to spend the time/money to put an updated make/model specific V8 in it, then you are good to go.
I have yet to see one with this setup work anything worth mentioning in the dirt vs. a mini truck so your work will be cut out for you. Good Times!!
Dan Vance
May as well just draw the line on all minis being 4 or 6 cylinders, and fullsize 6 or 8 cylinders. I'd say bore/stroke should be stock as well.
This makes me wish i had my truck the way it use to be at the end of 06. Minus breaking the leaf springs every 15 milesI do miss getting to screw with AJ though
GFO RACING 1445
Total Chaos Fabrication
Ricor Shocks
Sud Productions
Sounds good Dan! Have you guys started talking with any companies to get some large paybacks for this class? That will attract the numbers alone. I think a company like Deaver or National should jump at the opportunity to put some money into this class, this class is a perfect representation of their products!
TSU Motorsports #1495
dmzfab.com
sudproductions.com
offsetphotography.com
I like this new class. Pretty much like 7s though with some changes or updates if you will. I think you should at least allow a frame notch though. I wanna build another truck now. Someone bring your truck by so I can get started building it. lol
"Make em big!"
Actually, i think that is a good question.
"Make em big!"
It's a LEAF spring class. If you have a vehicle that came stock with links then race another class.
The rules need to eliminate as much interpretation of the rules as possible.
The questions/ideas being put up on this board should really be taken into consideration.
All great questions ... 1500 is a rear leaf spring class (read first post), so no links allowed. If you want to enter a Expedition or new explorer and convert it to leaf springs, go for it ... one more 1500 entry. I dont see that happening though. If not, 1400 or 1450 is your class to enter.
Once the rules are available from MDR their will be no mis-understanding of what the new class requires.
- Scott
what about a v8 in a 2 door exploder? is that ok?
I have a new idea for everyone with questions. First, read the damn thread! They have answered most of them already....read slower if needed! Second, WAIT TILL MDR POSTS THE RULES! The race isn't tomorrow and I bet you aren't making that cruitial decision that makes you in or out of 1500 tomorrow....just wait!
I am not a racer by any means, but I would like to race one day.
I think it would be cool for it also be single shock per corner along with a 6cly maximum. I know that is not going to happen, but that would keep it more budget in my mind. Full sizes came with 6clys too
It seems to me like the truck would be an extra cab or single cab f-1 with a 351, 64 pack, and wide beams.
Maybe I will race this race one of these days![]()
alright, tried looking through but maybe im missing somthing.
1400 can have F/G cabs now? as stated in the first post. Was that a rule change from the beginning of this year that i missed since the later posts say nothing has changed for 1400?
Just need some clarification.
appreciate you guys taking initiative to do what you can to bring more people out to the races.
then everyone would build a fullsize. they can be somewhat light weight and handle. keep the rules how they are, and put a max trackwidth otherwise I could see some wide ass rangers with 64"s racing this class.
In the spirit off keeping a budget class, 84" which is 7 feet, is the about as wide as you can make the inner loading area of a regular, dual axle, car hauler trailer. After the fenders and wheels are on, it's just under needing a wide load sign. Any wider than 84" and you would need a rollover trailer, which adds a good amount to the overall cost of the trailer.
Random .02 cents
carry on
Never thought about it this way, but that is very true.
On the motor though, why wouldn't everyone build as light as they can full size with a big v8? That seems like it would be the ticket. In my opinion that would through the whole 4cyl mini truck out the window. I know I have a lot to learn, so if anyone could point out a reason why people wouldn't do this (other then cost), I am all ears
I think with limitations you would need to spend more money to gain an advantage, if there’s less rules you can have good speeds with less spending.
The limitations just need to be well thought out so as to not allow 4.0 shocks, 4.3 liter Busch motors, etc.
A revision of 7s is how I see it.
I'm still up in the air about the full sizes running with the minis. The production based classes have always been divided by the size of the vehicle.
GFO Racing
BMS*Sud Productions*DW Photo*FastTech Designs
