Results 1 to 18 of 18
    Dulce Bellum Inexpertis shaun_kite's Avatar
    Las Vegas, NV/Ft. Irwin, CA
    Default Removing spray paint from.. .rims..
    The genius I bought my truck from spray painted the forged alcoas black.. Is there any way to remove all this without royally fucking up the rim or am i shit out of luck and just need to buy new ones.
    Senior Member RicherRacingKyle's Avatar
    Carlsbad
    Try a decent pressure washer, up close and it *Should* chip it off. Acetone?
    Learn by doing.
    OG A.J.'s Avatar
    Jan 2002
    Yuma, Az
    honestly there isnt anything your going to do to them that will mess them up beyond recognition..
    the best part about Aluminum is its ability to polish back to a gorgeous shine..
    if it gets scratches.. workin your way up in Wetsand grits will bring it back to a perfect shine...
    if your willing to dismount the wheels/tires it would probably make things easier..
    DR Mod oorracing's Avatar
    Jan 2006
    Long Beach Ca
    x2.
    Start with a heavy grit wetsand, and as it comes off work your way to fine grit. Finish off with a Mothers Powerball and some Mag polish and they will bling.
    Or just take them in to get powdercoated, because they sandlbasted mine before they coated them. Or get them converted to beadlocks, then powdercoat.
    "Better to stand there quietly and have people question if you're a fool, then to open your mouth and remove all doubt."
    "Imagination is more important then knowledge." Knowledge is limited to what we already know and understand, Imagination is limitless."
    i was thinking that too.. how much does it usually cost to convert to beadlocks?
    Senior Member 40oztofreedom's Avatar
    Yorba Linda
    None of those!
    Jasco Paint Stripper, you can buy it at home depot... works fuckin awsome. Burns if you get it on your skin, cleans up with water.
    Used it on my beams and radius arms to get off a couple nasty, thick coats of paint and primer.
    Might take a couple applications depending how thick the paint is. Secret is, put it on and let it sit for like 10 or 15 min. then the paint just falls off.
    Need Shocks Rebuilt or Correctly Valved?
    feel free to ask.
    -Dan Guido a.k.a. Toe
    Sea Bin Warrior
    Ridgecrest, California
    x2 for Jasco.
    It won't get all of it off though. Come through with a gallon of Acetone and go to town.
    Then begin wet-sanding with super fine paper and step down, it will make for a much nicer finish once you begin polishing.
    Buy a power-ball and use mothers mag polish. Those Alcoa wheels will look like mirrors with a little work.
    I have done this before.
    awesome- appreciate all the help. If Jasco gets on my tires is it gonna fuck them up or should I seperate them first? Secondly, what the hell is a power ball. Thanks!
    You cant afford me SIK_kreations's Avatar
    never used jasco... but if u go to vato zone or kragen u can get paint stripper that will eat up rattle can in a second. and it wont hurt tires.
    Please do not hit me up about doing a cheap paint job on ur dd or prerunner. http://maaco.com/ is ur friend.
    **WANTED** Stock bedsides for a 07 and up GMC sierra (not chevy) hit me up before u cut your stock bedsides off for glass!!
    RDCJuanB John_Bitting's Avatar
    Apr 2003
    Rancho Santa Margarita
    Will brake cleaner work? I had rattle canned the blazer and would use brake cleaner to clean it off and check it out and repaint.
    www.race-dezert.com
    #1prerun - why do her specs say 34a? shouldntit just say 34?
    so pretty much..
    jasco/paint stripper
    wet sand
    mothers mag polish
    Racer SF@DERTCO's Avatar
    Nov 2006
    C!
    The people who survive the sword will find favor in the desert. [Jeremiah 31:2]
    y do u need to wetsand if the aluminum is fine? paint stripper wont put scratches in it. and no one has recommended a grit to sand with either lol.
    Senior Member STATUS PITS's Avatar
    AZUSA CA
    try accetone and some rags and get to work
    no need to sand, youll just make more work for yourself
    Quote Originally Posted by murf1976 View Post
    I hate the fact that chicks on this site tend to pick GTFO rather than tits.
    Jan 2006
    Long Beach Ca
    OMF and CHAMPION both quoted me about $200 a wheel done out the door.
    Tin Foil Hat Brigade NeverLift's Avatar
    NB, PRK
    Quote Originally Posted by 40oztofreedom View Post
    WHOA, that shit is nasty!!!!!! I used it to strip the factory clearcoat off my ar-23's. Use in the open air NOT in an enclosed area, wear thick long rubber gloves and some sort of chemical filter for breathing. It works wonders but is some brutal shit. I believe it is originally used as aircraft paint stripper? I like how when you open the container and then close it all the fumes cause the can to suck in on itself lol
    Jan 2009
    Long Beach, CA
    i used paint stropper let it soak then pressure washed it most of it comes off then i tryed accetone and stuff
    4 stroke? HappyGilmore's Avatar
    LONG BEACH/ Los Alamitos
    i have scars from the paint stripper eating my skin. Be careful it burns.
    2003 Tundra
  1. Replies: 16
    Last Post: 05-04-2009, 02:48 PM
  2. Duplicolor spray paint
    By LethalRanger in forum Truck Talk
    Last Post: 02-06-2009, 12:47 AM
  3. removing bumper paint
    By ridered4life250 in forum Truck Talk
    Last Post: 11-07-2008, 10:37 AM
  4. which spray paint
    By b1z in forum Truck Talk
    Last Post: 04-24-2008, 01:50 PM
  5. removing paint off fiberglass
    By osker in forum Truck Talk
    Last Post: 08-03-2005, 04:23 PM
