After years of dreaming about ramming the gnar in the t-ruck, the time came. I know very little about this stuff and everything has been a huge learning process. Please speak up if you notice me doing anything horribly wrong.
This is what the truck looked like when my dad bought it for just over $3k in 2004. This photo is from 2009, but it did not change at all in that time. It's a 4.0 automatic 2wd with bucket seats and manual windows/door locks and a limited slip rear end.
The plan is to keep the build very mild, relatively cheap, and geared towards fast dirt roads and long freeway drives rather than desert stuff. Here in NorCal there's no desert, but we do have lots of sweet dirt roads. Rally, yo.
I blew out a tire and ruined a wheel up in Pinecrest during Labor day weekend so I pulled my head out of my ass and decided it was time to step up to the plate. $70 on Craigslist got some old aluminum Ranger wheels. After a few weeks of painting, I sucked it up and bought some 31x10.5x15 tires.
(in that pic you can see me in the background with the forks pulled off a YZF426. My axle nut was frozen in place so we just dropped the front end in order to fix a flat tire and get back on the tail)
The tires are great. But the stock suspension bottoms out 4-5 times just when driving across town. Drooped out with the stock suspension:
A guy on Craigslist was selling some half-begun Ranger project. He was down to part out the front end. I came home with a set of Threat 4.5" over beams, some Fabtech radius arms and brackets, Camburg coil buckets, a pair of Fox 2.0 resi shocks, some random red lift springs of un-known lift height, some alignment shims, '87 spindles and rotors, limit straps, some random bolts, and some brand new calipers. A few days later he gave me a pair of extended brakelines. I was stoked, but everything looked super clapped out.
Shocks, boots, laundry.
A few days later and I end up getting some Threat radius arms, brackets, and transmission cross member from the same guy. It was a good deal, but dirty bung holes rained on my parade.
After a month or so of scrounging for parts, pouring over DR, and just riding my bicycle a ton, I had New Years weekend free to install everything. My friend Dan helped me out tons, and this kit would never have made it together if it wasn't for him. But don't talk about Dan, as he is a creature of mystery.
Removing the stock crap was quite a hassle. Goddamn rivets.
We guessed on where to mount the transmission on the new cross member. I currently believe we are too far forwards, as my wheelbase is now 126", an inch longer than stock, and the truck makes a very noticeable vibration under mild acceleration.
Where we drilled the mounts:
We also had to extend the slot for the x-member so it wasn't totally bottomed (topped?) out on the extreme end of the slot.
Commitment to getting it all done. Sometime Saturday morning.
Starting to lay it all out:
Notice the coil buckets. We decided it might be wise to ditch the old hockey puck bump stops and just use 2 passenger side OEM Ranger bump stops. While these don't hold up to desert racing, I'm hoping they'll work for the fire road driving that I do. I can only find photos of the tack welds, and none of the perfect tig welds that hold them together.
Steering:
Measuring to figure out how to extend this showed that the "4.5" extended beams" are only 3" extended.
Sometime late Sunday evening.
With the wheels back on:
I made it to work Monday morning with no problems, but I've still got a bunch of small bugs to work out. The truck turns way better to the left than the right. The vibration under mild acceleration does not seem right. My brakelines seem too tight on full lock. I think the left side shock might need new seals. Still have to get an alignment done. These lift springs are sized perfectly for my limit straps and shocks, but the front end sits about 2" higher than we want it to.
Immediate plans for the rear end are Explorer leaf springs and some Fox 2.0 reservoir shocks. Are 10" stroke shocks going to be the correct size?
Plans for three or four weeks down the road are for an Explorer rear end with 3.55 gears and a locker and some sweet bumpers.
It will never end!
