Page 4 of 43 FirstFirst 1234567814 ... LastLast
Results 121 to 160 of 1718
213Likes
Thread: my 98 chevy race build
  1. #121
    Stigs Dezert Lovin Cousin prerunin554's Avatar
    Lakeside, Ca
    Quote Originally Posted by glamiskid395 View Post
    why do i need to lean them in more? what will i gain? (trying to learn)
    its the elusive 90* at full bump theory that almost everyone is after. Basically for fine tuning the shocks. There are tons of threads on it with people on both sides of the argument.
    Searching could help find all your answers!
  2. #122
    Senior Member 85tacoguy's Avatar
    rule of thumb, 90* at bump. Not to sure if the way you have it will make a difference. The only thing i would have done different is put the bypass out front because the further out on the arm, the more responsive it can be.
    I need: 16" Fox C/O shocks, 18" Fox bypass shocks, PM me if you have something
  3. #123
    Prerunnin beat me to it, and also, rack with cross over would be pretty difficult not to mention waste of money. get some swingers from threat and make custom steering, you will be in it for close to 600 with the box. Thats not to shabby
  4. #124
    Seabeck 4x4 and Fab 4x4x's Avatar
    Backwoods, WA
    Build looks sweet! A lot better than a lot of the internet fabbers on here can build. The only "constructive criticism" i can add is that you should have built some positive caster into your radius arms to aid in the truck tracking straight and returning to center. Keep up the good work.
    00 Ford Ranger 4x4
    05 Dodge Cummins 4x4
    06 KTM 450XC
    Seattle Area Thread
  5. #125
    15 Year Old Magic glamiskid395's Avatar
    Nov 2009
    Moreno Valley,CA
    if i move the coilover to the back i cant lean the shocks in, so i think im going to leave the upper mounts alone and switch the shocks.
    the guy that did my engine (B&K) is offering to do the steering too, using a nascar rack and pinion. to me it doesnt seem like it would be that hard to use a rack..
    heres how i think it could work?
    Attached Thumbnails Attached Thumbnails giant_motorsports_customer_trucks_brian_bonham_2.jpg
  6. #126
    old matt_helton's Avatar
    Yorba Linda, CA
    Um do not let him do that. Lol
  7. #127
    Nov 2009
    Moreno Valley,CA
    Quote Originally Posted by matt_helton View Post
    why? whats so bad about the rack and pinion.
  8. #128
    Yorba Linda, CA
    oh man, you just gotta trust me here son.
  9. #129
    Nov 2009
    Moreno Valley,CA
    alright so i trust ya, now tell me whats wrong with it? lol
  10. #130
    Tin Foil Hat Brigade NeverLift's Avatar
    NB, PRK
    x2!!!
  11. #131
    You said it yourself, Nascar rack. Dont do it. THe problem is racks arnt made for the abuse a box can handle unless you like spending 1000$ a rack. Do youself a favor and get a ford box from Howe with ram assist, the only problems you might have with that setup is how to mount it.
  12. #132
    Who's ShiTalKing? partybarge_pilot's Avatar
    Leucadia
    Neckcar rack will explode in short order.
    I would also try to avoid using one long bolt for the upper shock mounts. Long bolts stretch way more than short ones and it's hard to keep proper tension on them. Also, if you have any problems with that long bolt it's going to be a royal mother fucker to remove.
    As for the shock angle, going over 90 at bump will make it harder to tune as the geometry as built will make it harsher in the mid stroke and easier to bottom. Not a good combo. You can tune around it, but it doesn't make your life any easier. A little extra work now will pay off big later on..........
    Monkey fab
    Quote Originally Posted by mcdirt@1s1k View Post
    also what makes him a "pro" because hes done it for 25 yrs? well fuck me ive been taking shits for 25 yrs! does that mean im a pro shitter? fuck no i still get the beer shits!
  13. #133
    Lakeside, Ca
    Quote Originally Posted by partybarge_pilot View Post
    there are two bolts in there. they go in opposed to each other, I didn't notice it at first either
  14. #134
    People with way more experience than you have tried to make a crossover rack setup work, and ultimately failed. This is your first project, don't try something like that, go tried and true and come up with exotic ideas for your next build.
  15. #135
    Nov 2009
    Moreno Valley,CA
    Default Re: my 98 chevy race build
    Okay quick question I have to put the coilover in back on the passenger side, aside from asthetics what will this cause problems with? Do I need to just mount the coil on the rad arm on both sides so that it will clear the beam mounts? Thanks. Need an answer quick.
    1420 Fox Racing
    Thanks: KING Shocks, Cal-Mesa Steel, CBR, B&K, Hall's, Napa-Moreno Valley CA, SLIME, Inland Powder Coating
    Quote Originally Posted by slater1472 View Post
    What? she's 14, excuse me for a sec...
  16. #136
    Nov 2009
    Moreno Valley,CA
    And yes two bolts are being used, the middle boss is going to be threaded. All bolts on suspension are F-911.
    1420 Fox Racing
  17. #137
    Leucadia
    Blind bolts also cause their own set of headaches and should be avoided.
    If your mounting your C/O's to the radius arm, plate that thing to the beam when you get everything lined up. The 2 mounting tabs will flex and break eventually.
    Monkey fab
  18. #138
    OG Member fleshwound's Avatar
    Orange, CA
    did u not pay attention to what others were saying? bypass out front more will give u more control so if ur gonna have a bypass in the back on the driver side and a bypass up front on the pass side what do u think its gonna do? probably act different cuz its further back... keep it all the same
  19. #139
    Nov 2009
    Moreno Valley,CA
    I redid it so the coil mounts on the rad arms. I will plate in the rad arms also.
    1420 Fox Racing
  20. #140
    Orange, CA
    u dedicate all of ur time to this build huh? seems like u work non stop on it
  21. #141
    DR Mod oorracing's Avatar
    Jan 2006
    Long Beach Ca
    The rack travels in a straight line, the swingers travel in an arc. It could work if you used short links connecting the swingers to the rack, but that's a whole different ball game with angles/ratios. More moving parts=more to break/fail.
    Keep it simple.
    "Better to stand there quietly and have people question if you're a fool, then to open your mouth and remove all doubt."
    "Imagination is more important then knowledge." Knowledge is limited to what we already know and understand, Imagination is limitless."
  22. #142
    DR Maitre'D DirtFiend602's Avatar
    Scottsdale
    i posted above but you might have missed it? did u get both rad arms finished? howd the caster angle come out?
    DSR, Nocturnal Fabrication, Gort Chop Shop.
    Instructions? Wtf are those?
    Things women use when they pretend they're men?
  23. #143
    Nov 2009
    Moreno Valley,CA
    Quote Originally Posted by fleshwound
    I've been on spring break these last two weeks so yes I have.
    Well I'm going to wait for Dave to have him help me mount the shocks, I'm just not sure what I'm doing wrong.
    Both shocks are 16" but when cycled, the coilover only travels 14". So I should have got a 18" B/P right?giant told me 16's because he was going to do the front before I decided to do it.
    I can post pics if needed.
    1420 Fox Racing
  24. #144
    Orange, CA
    u can make those shocks work u might just have to mount the tops differently and it might be more difficult but thats the name of the game
  25. #145
    Nov 2009
    Moreno Valley,CA
    Quote Originally Posted by DirtFiend602
    I haven't measure the caster angle.
    Not sure how to. I have the 2 piece caster/camber adjusters.
    1420 Fox Racing
  26. #146
    Scottsdale
    only reason i ask was one of your pics, the knuckle looked way in the negative, photos distort everything though... you could do something as simple as finding true zero with a plumb bob and a digital angle finder. btw awesome build, it seems like you update everyday!
  27. #147
    Nov 2009
    Moreno Valley,CA
    only reason i ask was one of your pics, the knuckle looked way in the negative, photos distort everythign though... you could do something as simple as finding true zero with a plumb bob and a digital angle finder. btw awesome build, it seems like you update everyday!
    Do I do this at ride height?
    I try to because I always have questions.
    1420 Fox Racing
  28. #148
    Scottsdale
    haha i wish i had 1/4 of this time you dedicate to this.... you said Dave is going to help you with the shocks? ask him hes the beam king lol. and im not 100% sure, you could cycle them and just check it both ways, at ride height and at 90.. its mainly going to affect steering ackerman and departures out of corners, ruts, etc
  29. #149
    Asshole/ helpful ovrebo1's Avatar
    I measure my caster and camber angles with a magnetic base angle finder.
    I have 14" stroke shocks and not as much room to work with as you do and I get 18"
  30. #150
    Nov 2009
    Moreno Valley,CA
    I think I just realized my problem, the fox body is 1.5" shorter than the king bp body. Are the king coils the save body size as fox coils?
    The fox body is 23.5" from bottom of body to center of eye.
    1420 Fox Racing
  31. #151
    I bet shock dimensions are on either companies sites.
  32. #152
    Nov 2009
    Moreno Valley,CA
    got the mounts all figured out. the bypass compresses and extends the full 16". the coilover extends 16" but only compresses 14.25"..
    the upper mounts and lower C/O mounts were done with a band saw, hole saw, and grinder. been working on it for 6 hours...
    i dont have pics and full bump because i was too lazy to lift it back up.
    oh and 23 1/4" of travel will strapp at 22"
    Attached Thumbnails Attached Thumbnails dscn0486.jpg   dscn0487.jpg   dscn0489.jpg   dscn0488.jpg
  33. #153
    Leucadia
    Much better.
    Monkey fab
  34. #154
    Nov 2009
    Moreno Valley,CA
    thanks
    is this a good idea for tube placement?
    Attached Thumbnails Attached Thumbnails dscn0490.jpg   dscn0491.jpg   dscn0492.jpg
  35. #155
    Leucadia
    The down tube next to the cab, I would move the bottom of it as far back as possible.
    You putting the radiator in the rear?
    Monkey fab
  36. #156
    Nov 2009
    Moreno Valley,CA
    I will do that. The radiator will stay up front. Electric fans If the stocker doesn't fit.
  37. #157
    Leucadia
    Hmmmm, doesn't look like you left yourself a lot of room for the radiator width wise.
    Monkey fab
  38. #158
    Nov 2009
    Moreno Valley,CA
    Well the stock radiator will not work, if we can't find a 4 core one that will fit, we will put it in the back.
    1420 Fox Racing
  39. #159
    Mega Member burDom13's Avatar
    Aug 2004
    Chino Hills CA
    def looks alot better man. when you take your time and think everything out, te work turns out better than rushing through. and for your first build, the work is is lookin pretty good man. i bet your stoked
    Bbr is no longer doing any more fab work
  40. #160
    Leucadia
    4 core to thick unless your going 140MPH LOL.......
    In the back it goes........
    Monkey fab
  1. 90 chevy build
    By 90chevy in forum DR Rides
    Last Post: 05-09-2011, 01:08 AM
  2. 85 chevy build
    By k pizzle in forum DR Rides
    Last Post: 09-07-2008, 04:37 PM
  3. 95 chevy! want to build it
    By jakeroxdc in forum Truck Talk
    Last Post: 08-24-2008, 10:39 PM
  4. 90 chevy build
    By 90chevy in forum General Off-road Talk
    Last Post: 01-03-2007, 11:35 AM
  5. 01' chevy build
    By fab101 in forum Fab Shop
    Last Post: 03-27-2006, 01:58 PM
