Results 1 to 35 of 35
  • 1 Post By howey
Thread: project . mr saturday night special
    333 im only half evil howey's Avatar
    hanford
    Default project . mr saturday night special
    ok so i just picked up this ranger jan 19th it needed a clutch and who knows what else but i got a killer deal on it so i put a clutch in it found it had a check eng code replaced the camshaft pos sensor and got it smoged with flying colors haha a 95 with a 4.0 with 48k org miles i picked up some beams from kurt in lompoc and started to extend them 4''s and moving the ball joints out heres some pic's of those . i socred some f23's last week with hangers shackles and spring plates cleaned them up got new wear pads and hard ware so heres the pics its going to be a long journeydanger-ranger-001.jpg
    GOVERNMENT makes HEALTH CARE better
    like WISKEY makes you more SOBER
    hanford
    ranger-008.jpg i got a cheapo hf sand blaster and blasted the driver side beam
    GNAR member jonerton15's Avatar
    Fallbrook/ Long beach CA
    why didn't you just use the beams on the truck? Starting off good. TTB beams ftw
    1549-Tonelli Motorsports, 1st place Baja 1000, 1st Place San Felipe 250, 1st place LDC, 1st place Primm 300. DR, SUCK IT
    Richer Racing Offroad Fabrication- Misery Motorsports
    4130-Builtbymedia.com -HOSTILITY CLOTHING
    hanford
    well im collecting parts rite now so when i get an eng cage and c/o's ill do it to but rite now im driving the piss out of it hahaha
    hanford
    well i put on my deavers today fliped the hangers and put on 8inch long shackles and cut a monsteres hole in the bed but no lift height gained its fine for now but whem i get my beams done im going to need a lil more lift so should get new lower hangers or put the stock shackles on ? here's the picsranger-001.jpg
    ranger-004.jpg ride heigth now
    ranger-005.jpg full drop with kick ass factory shocks
    ranger-006.jpg full bump with shocks
    hanford
    just got a dixon bro bed cage to day so now im on the hunt for shock's im thinkin foa's 2.5 with bypass but its all about money will get pic up some time just not sure when
    hanford
    so i got some work done this past weekend got my front end up in there axel shafts made and got her rollin now its the lil shit i need to do
    ranger-front-end-010.jpg the ass end is sittin low with the 7.5" long shackels
    danger-ranger-008.jpg i put the stock shackels on and raised it up a lil
    danger-ranger-004.jpgthere it is in all its glory hahahahaha
    hanford
    Click image for larger version.
Name:	ranger front end 009.JPG
Name:	ranger front end 001.JPG
Name:	ranger front end 010.JPG
ID:	72061 the ass end is sittin low with the 7.5" long shackels
Name:	danger ranger 008.JPG
ID:	72063 i put the stock shackels on and raised it up a lil
Name:	danger ranger 004.JPG
ID:	72064there it is in all its glory hahahahaha
    hanford
    epic fail with the pics sorry
    hanford
    and here the axel shafts
    bull-shit-097.jpg cut in the lathe and hole drilled 1/2"
    bull-shit-099.jpg extension 4'' longer with a 1/2'' nipple and a welding groove
    bull-shit-100.jpg end of the extension
    bull-shit-101.jpgan exploed view before being pressed together
    bull-shit-095.jpg up close pressed fit
    bull-shit-094.jpgshitty iphone pic but thats it
    bull-shit-103.jpg and sleeved
    hanford
    so next its make shock brackets, get brakelines, limit straps, do the steering and uh buy shocks
    Senior Member mt93ranger's Avatar
    MT
    are you keeping the d35 hubs? if you used d44's instead, you could have used a d35 inner shaft and a d44 outer shaft, cut and made to length, then sleeved. would have saved a lot of time instead of machining those axle extentions. looks good!
    hanford
    Well my next go around. Is a d44 and a 9". But that's a long time away. No the 35 hubs will be fine for now
    i wouldn't run the truck hard with those stock shackles. there is a good chance they will bind before the springs fully dearch. you get get drop hangers and run the longer shackles, that will put the ride height somewhere around where it is with the stock shackles.
    other then that you might need new leafs or get them re-arched.
    hanford
    There an old set of f23's so they mite need to be rearched. But ya I do need drop hangers for sure
    Senior Member 93LTranger's Avatar
    Havasu
    Still need a set of rear shocks? I got a set of 2.0x14 fox smooth bodys for sale. Like new.
    hanford
    How does your truck do with the 456 gears and what size are your tires . I think iam going to run 2.5 all the way aroud
    Havasu
    33x12.5's they work great. Throw a locker in the rear and you'll have no troubles.
    hanford
    ranger-bumper-003.jpgso i have been laggin on the pic takein but here are some up dates got the top half of the bumper made i had a set ranger-bumper-001.jpgof 98 fenders layin around so i stuck them on flared the bed 1.5 got the bed cage in mode the got kartec hangers ans moved them to the rear ranger-bumper-002.jpg
    hanford
    needed shocks 14's and 12's
    OEF Veteran r1d3snowboards's Avatar
    So Cal
    where did you get that bed cage? doesn't look like a DBR one..
    0311 USMC 2/3 ISLAND WARRIORS (EAS)
    6.5 Camburg Limo Beams & SAW's/Deavers with Dixon Bros bedcage & King double bypasses
    hanford
    Ya it's an old skool dbr and for 150 bucks. I couldn't pass it up
    hanford
    ranger-rear-shix-005.jpgranger-rear-shix-004.jpgranger-rear-shix-006.jpgranger-rear-shix-002.jpgso i got a lil more work done mounted the bypasses finished the bottom part of my bumper just need to put a skid plate on and them start building my eng cage
    So Cal
    no..pretty sure its not old school..just an old knock off lol
    hanford
    Holy hell I need to up date the build. I just got my jmr bender now it's time for a bed cage and new bumPer pics will be coming
    hanford
    well its been a while havent done much lately but i went to pick n pull in fresno and found a wrecked 07 ranger so i got the seats, mirrors, tail lights so heres a lil up date on that [IMG][/IMG]ranger-103.jpgranger-105.jpgranger-106.jpg
    hanford
    the mirrors stuck out at the bottom so i had to cut the riser off they fit better but theres still a lil gap some weather strippin can fillranger-082.jpgranger-083.jpg
    hanford
    well its bed cage time pulled the old one off and started on the new one ranger-shock-angle-104.jpgranger-shock-angle-105.jpgranger-shock-angle-106.jpgranger-shock-angle-108.jpgranger-shock-angle-110.jpg
    i was on the desert rides website and heres the where the shocks intersectranger-shock-angle-116.jpgranger-shock-angle-121.jpgranger-shock-angle-118.jpg
    where looking at 35* at bump and 25 at droop so then i went to the 1;1 ratio ranger-shock-angle-114.jpgranger-shock-angle-115.jpgranger-shock-angle-119.jpg
    which then put me at 11* forward at bump and 6* at droop the string line is straight with the leaf and the line is at 11* im i trying to get to much bump out of an old set of f23's " it just seems like the shock is a mile high off the top of the bed rail" just a thought
    (clever user title here) zac92ranger's Avatar
    Nipomo, CA
    whats the plan with the front? if you are keeping it coil sprung for a while i have 10" smooth body ressys
    hanford
    I guess I need to up date some pics. The front Is done I have a giant eng cage and 2x12 rad flo's
    hanford
    i rolled her out side so i could clean my shop so i thought id take some pics
    hanford
    014.jpgya got the cage done for now ill get more pics of some other stuff
    fishridendrive likes this.
    Senior Member mikeestep's Avatar
    fresno
    looks good
    were having a meet in fresno next week. you should bring it down
    GET THAT SHIT OUT OF SECOND SKEETER
    FUCK! its tequila, not rum!
    OG Member OC96Ranger's Avatar
    On the flip side
    Great song.
    I'm Dave
    hanford
  1. night run this saturday the 5th!!!
    By brodozer motorsports in forum So Cal
    Last Post: 09-09-2009, 06:32 PM
  2. SATURDAY NIGHT TUFF TRUCKS!
    By matt_helton in forum Racing Events
    Last Post: 07-11-2004, 12:01 PM
  3. ocotillo this saturday night...?
    By in forum Racing Events
    Last Post: 09-20-2003, 05:01 PM
