Rear: Kibbetech 9" full-floater rear end housing 100% tig welded, yukon 3rd member with Daytona bearing support, 35 spline full spool, 1350 yoke, Camburg 2.5 hubs, Wilwood 12" rotors and Wilwood 4 piston calipers. Kibbetech 4130 prerunner 4 link kit, King 2.5 coil-over and bypass and Fox 2.0 bumps. Kibbetech bolt-on 4130 kicked frame rails for 4 link. Glassworks 7" bed sides. 32 gallon.
Front: Camburg race LT kit with King 2.5 coil-over and bypass, Fox 2.0 bumps. Camburg 2.5 hubs, Wilwood 12" rotors and Wilwood 4 piston calipers. PWR radiator w/dual electric fans. Juanco built 4.0 SOHC, head work and race cams, shortened wiring harness and tuned computer
1 3/4" 4130 tig welded cage, front to rear.
Here are some before photos:
