I'm building a 2000 silverado. It was a BBR long travel kit which was AWESOME... but I've decided (along with some other friends influence) to go crazy and take my perfectly good runing truck and basically cut it apart!!!!
So here I am, I'll post pics as it goes. I'm getting help from some friends that actually know what they're doing so things should come out pretty good!
Plans:
Center Pivot front suspension
Motor moved back approx. 15"
Linked rear
Full Tube chassis
Etc....
This build will take some time basically because I'm not rich! but with doing as much of it as I can myself and the help from friends (which I'm very appreciative of) hopefully it only cost me around 50k'ish.
Please give your input good or bad on things. I appreciate anyones help or opinions.
heres some pics of where I'm at and whats going on...
In one pic, you can see the front bulkhead in pieces.
I have the engine roughed in to start getting an idea of where things are going
I'm building the cab cage and landing the tubes to some "pontoons/outriggers" underneath the frame that you cant see. Once the cab cage is built, I'll weld the body/cab to the cage to make it a solid unit. then I'll remove the stock frame rails underneath and set the approx. ride hieght of the truck. it's pretty close now but I want to make it sit a little bit lower. then ill just start throwing tubes underneath and so forth.. I dont know if this is the best plan.. but it's my plan as of today!!! haha...
john
!!! haha...
