I haven't really gotten around to the suspension stuff that would qualify this as a prerunner type build yet, but someone might find the build so far interesting.
It started out as a DNR truck, painted a hideous bright green, so I painted it OD green with a brush. It doesn't look too bad from a distance. lol
One of the front spring pockets rusted into nothing and dropped the truck on its bumpstop in that corner. So, I made a new one outta 1/4" plate.
[/SPOILER]
Used an AC buzz box at 110 amps with 1/8" 6011 electrodes.
Also put new brake lines into it at that point, all of them were gone and I had to use the E brake to move it, and it stuck on...
Gonna be doing a 63/64" spring swap on it too, the springs came off of a 1500 suburban. From what I hear the 1500 pickup springs have 2 less leaves than mine, so I guess these might be like 2500 pickup springs... I should probably take a leaf or 2 out, but I dunno if I'm gonna just yet considering my axle choice.
It needs rear wheel bearings in the 7.5", but then I got a deal on a corp. 14 bolt DRW axle with 4.10 gears.
I've already got it cut and shortened. The stock axle takes a long shaft and a short one, the difference between them being 6", so I got 2 short shafts and the pinion will just be 3" offset to the passenger side.
I'll post pics of the shortened axle housing as soon as I can get pics. It's sitting at my dad's shop right now, 11 miles away, so I can't exactly walk out and take pics.
Sorry if formatting is a bit funky, I copy/pasted most of this from another forum...
[/SPOILER]
