I bought her about 6 months ago after totaling my 98 4runner. i named her goldie because i had a 92 ranger that was similar in color and was named goldie. by the way the gold makes me want to vomit. so heres where she stood when i bought her.
95 4runner limited 3.slow 4x4 180,000 miles
total chaos gen 2 caddy kit w/tc idler arm, weld on truss and shock hoop
t100 axles
2.5 fox c/o with res
ome 2" lift coils in the rear w/ stock shocks
i wish i was smart enough to get a pic before i did anything but i wasnt. first thing goldie got was 33" hankook m/t's, winch and bumper, bilstien 5150's for the rear, 2 7" kragen hid's and headlights replaced with hid's all from totaled 98 runner. took her out to cal city for the weekend and 2 things were obvious right off the bat. 1. 3.0 is a pile of shit 2. need rear shocks bad. front was doing ok while the rear was all over the place.
next i drained all fluids and replaced with swepco lubes. just for a piece of mind. rattle caned her black. bought a set of used 12" king double bypass w/ remote res for the rear and 8" saw double bypass w/remote res for the front. all the front needed was tabs welded to the hoop the fit the passes in front but the rear was another story. at this point i decided it was going to be in my best interest financially to buy a bender. got a new jd2 model 32 and 1 3/4.
die. bend some mounts for the rear, cycled the suspension and mounted up the bypasses between the frame and tire. they rubbed. changed the lower mounts and and added some 1" wheel spacers. slight rub...but still a rub. made some new hoses at work with a 45 degree fitting and stopped the rubbing on the hoses. im still rubbing shock body when one tire is all the way up and the other is down. so i came to the conclusion that i need to build a bed cage and scrap the idea of having them in between the frame and tire. and since im going through the cab with a bypass i might as well run a c/o too.
in order to do that i need to remove the panhard bar and crossmember and do a true 4 link correct? right now it has the factory 4 link.![]()
