^^^x2. My dad helped me with mine cause he knows all the tricks, but it still took two of us with no power bleeder.
First if you removed the master cylinder you can bleed it off the truck, then put in on and hook everything up.
Then fill up the reservoir and pump the brakes a few times and your suppose to start at the rear right tire(furthest away from the reservoir.) However if you didn't pull off your rear brake lines then you should just get the majority of the air out of the front lines.
When you bleed the brakes you just have someone hold the brake pedal down while you open the bleeder on the caliper until it the line looses the pressure(once the pedal hits the floor) then close the bleeder valve, pump the brakes and repeat. And you will have to do this with each caliper until no bubbles are come out of the line when you bleed it. One little thing I did that helped was get the majority out of it, let it sit over night with the cap off the reservoir, then bleed it again the next day because a lot of the bubbles will rise and then you won't have to bleed them out.
It's a little time consuming without a bleeder haha.
