Results 1 to 22 of 22
    Member dirtbagcfh's Avatar
    Sep 2010
    Default 99 ranger 4x4 build
    So i picked up this ranger for $3500 with 30,000 miles on it. Its a 4x4 3.0 stick. So heres a few pictures of the process.
    Took out the stock deck and threw in a Pioneer AVH-3200BT
    new 31x10.50x15 BFG AT's
    Start of the front bumper (MCM FAB)
    (4) Hella 500's
    img00442-20110313-1337.jpgimg00450-20110315-1550.jpgimg00441-20110313-1336.jpgimg00455-20110315-1619.jpgimg00451-20110315-1551.jpgimg00459-20110315-1906.jpgimg00458-20110315-1905.jpgimg00456-20110315-1633.jpg
    Kyle Shapiro LVbLaCkRaNgEr's Avatar
    las vegas
    sick truck bro!!
    www.f-o-a.com
    Shock Technician
    Flowline Racing badapple724's Avatar
    Mar 2005
    HOME: Las Vegas, NV STATIONED: Anchorage, Alaska
    Great buy!
    sent by Tapatalk Pro and Flowline Racing
    2002 Ranger Edge 4X4, 4.0, PWR everything, cold AC- Front: DBR , FOX, GLASSWORKS- Rear: DEAVERS, CAMBURG Tig'd shackles, 16" FOA's, GLASSWORKS TT bedsides- Custom WOOLWORTH work: cab cage, bedcage tied into cab, front/rear bumpers, front/rear light bars
    Pack it in, PACK IT OUT!!!
    Sep 2010
    thanks, now just to decide to go long travel or mid travel
    HUCK IT! xSM1THY's Avatar
    Sep 2010
    Rsm california
    Lt it will cost u less in the long run
    Sep 2010
    ya, but is LT reliable? I drive 600 miles a week for work, and need it to be as reliable as possible
    Feb 2011
    from what i understand the long travel kit adds tons of strengh and travel there no real down side if you were asking me and from what i hear going from a tbar ifs to a long travel coilover ifs it rides a lot better
    Senior Member 86 yota runnr's Avatar
    yucca valley,ca
    their are pros and cons. yes your gonna have more travel and more adjustability from a coilover setup but with that comes more roll from your ttruck in turns and if you want it to not bottom out a lot in the desert your gonna need a stiffer valving which is gonna suck for driving on the road. Its all about what you wanna do though.
    Sep 2010
    well i drive a shitload for work. so its gonna be 80% daily driving 20% weekend fun. I talked to my buddy who is a Ford Mechanic. He told me that with my hubs (pulse vacuum) I can eliminate my 4x4 axles and basically convert to 2wd. That opens up alot of options. Aaron from Dixon quoted me $1500 for axles alone. Now i just have to make the decision to commit to long travel... Or just have MCM build a new upper and lower off my stock spindle and go coil-overs.
    yucca valley,ca
    Also Long travel kits don't neccesarily add strength. Think about how much stress you put on your truck now with stock width arms and mild offroading. Now think about how much more stress is added on your mounting points when you go 4 inches over and are able to go faster in the desert. The only way a long travel kit is going to add strength is if you plate your frame and plateing has nothing to do with a long travel kit.
    Sep 2010
    ***UPDATE***
    - Bumper gets powdercoated next week
    - Skidplate gets machined next week
    So I just picked up my coil-overs today. 6" FOA 2.0 with reservoirs. I've heard bad things about Blue Coils which is what comes on these. Im gonna go with Eibach Springs. So what spring rate do you guys recommend? Like it was mentioned above. This will be a DD for 80% of the time with 500+ miles a week.
    Rape Murder Arson & Rape DuctTapeRacing's Avatar
    BLF/LBC/OC
    Quote Originally Posted by dirtbagcfh View Post
    Click image for larger version.
    Good choice!
    The faster you get into the sport, the faster you get out.
    "You said rape twice.."
    Sep 2010
    no opinions on Spring weight?
    Sep 2010
    MCM removed the bumper today. Also cut out the skid plate and sent both of them to Powdercoat. Hopefully have it back and welded back on friday. Got a picture of the skidplate after it was cut on the plasma table. XXX stands for straight edge if you were wondering.
    Eddie V. yellowranger1's Avatar
    Sylmar/Northridge, Ca.
    I'm running a king 18" 600lb spring on a fox 2.5x8" coil over the front of my 4x4, very happy with the ride on and off road. Good luck, cool to see more 4x4's!
    - Eddie
    Sep 2010
    thanks for the reply !!! ill try out the 600lb spring first.
    I've got an F and a C. I got a K too. The only thing that's missing is a bitch like U
    MCM Fab & Design
    las vegas
    jared im running the same thing as eddie on my truck but i have a 16" spring
    www.f-o-a.com
    Shock Technician
    Sep 2010
    thanks for your input guys. Im going to Butch's to get springs whenever i get time. Than ill get those bitches mounted and start planning the next step
    MCM Fab & Design
    Sep 2010
    bumper is done !!! Got it all welded up today at MCM. Satin Black Powdercoat.
    MCM Fab & Design
    Sep 2010
    well... got all my shocks front and rear and new bumps ready to go in. but some asshole jumped the curb today and plowed into my front end and destroyed the front end... insurance adjuster meeting is monday. GOD FUCKING DAMNIT
    289638_227678097277601_100001062379375_682868_6408273_o.jpg286445_227635903948487_100001062379375_682805_8120431_o.jpg
    TO BE CONTINUED
    MCM Fab & Design
    Senior Member 1999fordranger's Avatar
    Oct 2010
    Fallbrook,Ca
    so whats up with the truck
    Sep 2010
    frame is twisted, cab is twisted, core support is wasted, all the headlights need replaced, both fenders and hood are ruined... insurance totaled the truck and wanted 1500 to buy it back. so i got my insurance check and just bought an 01 ranger... off to start another build !!
    MCM Fab & Design
  1. DD Ranger build
    By GRRANGER in forum DR Rides
    Last Post: Yesterday, 05:11 PM
  2. 88 ranger build. NEED EVERYTHING
    By VINTAGESPEED in forum Wanted
    Last Post: 01-06-2010, 02:37 PM
  3. 86' Ranger Build
    By Dugout_Myles in forum Fab Shop
    Last Post: 05-28-2008, 04:36 PM
  4. 92 ranger build up
    By volume351 in forum Fab Shop
    Last Post: 09-19-2007, 08:15 AM
  5. 89 Ranger build
    By Class7 in forum Fab Shop
    Last Post: 08-01-2006, 04:26 PM
