Page 1 of 2 12 LastLast
Results 1 to 40 of 78
2Likes
Thread: 97 DD/Weekend Runner Ranger
    Senior Member Losi's Avatar
    Long Beach, ca
    Default 97 DD/Weekend Runner Ranger
    So figured i would make a thread. After having my fair share of chevys. I figured i would give it a go for a ford. I traded my 97 Silverado for this 97 Ranger. Got the truck with Camburg 4.5 over beams, radius arms and the trans X members, with 12" Saws up front. In the rear it has f23 pack with bms extended shackles and i believe kartek hangers. A bed cage built by Solo Motorsports with 14 in kings remotes. Interior was stock with a 12" sub in back with a big box. It has the 3.0 with 5 speed and a re geared 7.5 with 4:11's
    Previous trucks. The white one is the one i traded for ranger.
    0116011715.jpgThere she is. 154952_167859819916651_100000779032122_307868_6793290_n.jpgThe driver front fender was broken.
    So when i got the truck all 4 shocks where in need of a rebuild. With the help of Kevin (ooracing) i learned how to rebuild shocks. The rears where rebuilt fronts still needed to be done but wanting to go out and play. Went out with Kevin, Andrew, Matt, Bryan, Alon to 15 and the 138 spot. Needless to say a ditch grabbed my truck and turned a good night bad.
    Aftermath was slightly Bent frame and Bent passenger tie rod. In turn driving back from there to home completely made my passenger front tire bald.
    So i stripped the whole front end off and took it to camburg for them to look it over make sure it was ok. Found a bad heim so that was replaced. Since the truck was down took the time to rebuild the saws with new shafts and oil/seals. Got the truck back together aligned it and continued on.
    Next project i tackled was the bed one of the previous owners had done a nasty job rhino lining the bed. So with the help of aircraft stripped the tubes where cleaned up.
    Next was the job of trying to fix the front fender. Thankfully i had the piece that broke off.
    0409011455.jpg0409011456.jpg0409011655.jpg0409011648.jpg0409011733.jpg0410011404.jpg0410011700.jpg
    It turned out better then it looked before so i was happy. then came around the Barstow poker run. Right before the poker run i found some Bucket on race-dezert. Went and bought those and got them installed before the run.
    After the poker run i realized the big box moved around to much and put 2 little holes in the back of the seats so that had to go. replaced it with the smallest box possible and mounted to the back of cab
    During the poker run i had a accident with my battery which is mounted in bed. it happen to move back in the holder a little bit and the side post grounded out in turn killing my battery. After using a battery to get my truck started got to autozone and bought a new battery that was sold to me at used cost because of the age to get me home.
    btw its for sale for what i paid for it $40 normally $160 800 cca 1000 cranking amps.
    So time went by havnt really did much other then move my Hangers back from stock location to front mounting holes to the back mounting holes which corrected my shackle angle
    Before
    After.
    Then saw brodozer MS selling some fenders so i had to jump on them. Painted them to the factory color of my truck to match.
    Here is a recent picture.
    Future plans are to fix the frame, then front and rear bumpers. Paint bedsides to match rest of truck
    Radflo Suspension Technology
    Greazy_Meatball! 02dangeranger2wd's Avatar
    Feb 2009
    LB
    O snap....check out devin, I still need to go to that spot.....wtf, I guess im not cool...
    keep it up! your always doing something with that bad boy, maybe now you can keep up
    -------The wine blooded pasta eater--------
    http://www.btf-fabrication.com/ http://www.clean-dezert.org/
    1448--Watch out!!
    Long Beach, ca
    pssshhhhh lol. With the new valving in rear and more psi it was so much better yesterday in barstow. maybe if your trucks ever hit dirt we can go play lol
    Feb 2009
    LB
    /\/\Well if you go when I dont work it would be all good....My truck handles like shit anyway, it just looks cool kinda!
    1448--Watch out!!
    Long Beach, ca
    hey you didnt work yesterday man
    TONY Ivanhoer's Avatar
    May 2010
    Visalia CA
    Truck looks real good sucks to hear about the frame
    Quote Originally Posted by NODNARB View Post
    Will there be a free bandana giveaway with paid subscription?
    http://www.dezertrangers.com/vb/dr-rides/131172.htm
    F-O-A jake weed's Avatar
    Sep 2010
    Tustin, Menifee, CA
    truck looked really good devin at the race, i like the new front glass.
    TOGETHER WE STAND...
    Originally Posted by jackdeant
    nah it is and so is 99% of the trucks out there there alll junk lol
    Long Beach, ca
    thanks guys. hey jake how did it go with ur radiator i couldnt find u after u went to del taco
    OEF Veteran r1d3snowboards's Avatar
    So Cal
    Saw ur truck at the race, looked sweet keep up the work
    Sent from my DROID X2
    0311 USMC 2/3 ISLAND WARRIORS (EAS)
    6.5 Camburg Limo Beams & SAW's/Deavers with Dixon Bros bedcage & King double bypasses
    Long Beach, ca
    thanks, where you in your ranger? don't recall seeing it.
    Sep 2010
    Tustin, Menifee, CA
    Quote Originally Posted by Losi View Post
    just ended up driving it home. and stopping every 20 or so miles to fill it up.
    Long Beach, ca
    damn that sucks. i went back to play when i saw you go in del taco. then drove through pits trying to figure out where you went lol
    Senior Member mx33kalil's Avatar
    Nice build man! Was it a big difference in the rear when u flipped and moved the shackles back?
    Senior Member 714banshee380's Avatar
    dude the white silverado was so clean!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    So Cal
    Yes, I was driving up and down main pit sat morning and I think I saw you at the top. And then drove by you a few more times..you know what I drive?
    BDM NICK brodozer motorsports's Avatar
    Jun 2005
    San Diego California
    Yeaaahhh!!!!
    BRO-DOZER
    M O T O R S P O R T S
    San Diego, California,
    HATES LS1'S. "Beds are for sleeping not prerunners"
    www.phantom-lighting.com
    Long Beach, ca
    mx33kalil when i got the truck the hangers were flipped. something you do on all rangers? after i moved the hangers back the rear felt alot of better and corrected my shackle angle.
    pretty sure u drive a ranger looked through ur threads
    Yeah I'm getting Deavers soon and i just wanted to hear first hand about what difference it made. Thanks man
    Long Beach, ca
    Default updates
    So i got tired of not being able to fill my gas tank up all the way. due to my filler neck not seating on the gas tank all the way so made it custom
    Then traded cbrewer bedsides. Mine had the gas door hole and since i am not using it anymore didnt need them
    I then sanded and painted them to match the rest of the truck
    I also bought from the dealer the plastic pieces for the tail lights that the screws go into and fiberglassed them in. NO more losing tail lights.
    I also went to the Mdr Memorial run and tested out the new valving in rear and Jumped the truck for the first time. Didn't do any major huck but got all 4 tires off the ground.
    All 'N One - YouTube a video of me and my buddies my truck had black bedsides at the time
    Mega Member cbrewer22's Avatar
    Aug 2008
    Looks good man.
    Long Beach, ca
    thanks man get yours painted!
    Aug 2008
    Not yet I had the day off the other day and had to do the tie rods,plugs and oil change. This Saturday if I don't have work I'm going to do that and change the cats and balljoints. Good idea on glassing in the plastic things for the lights.
    Long Beach, ca
    yea the right one fell off at the memorial run i got it back so fiber-glassed and epoxied the clips in from dealer
    Long Beach, ca
    sooooo time to update this thread some more
    So after alot of talk from someone i decided to give it a whirl of polishing up my wheels. then afterwards decided no more murdered out so. cleaned up the grill and De smoked my tail lights and 3rd brake light
    Buddy was selling a 8.8 with 4.88 so got that and installed it. week later my coworker was selling a 8.8 with a ls so picked that up off him for 20 bucks and a tall can. possibly going to rebuild it and then throw it in my new axle.
    got my shock rebuild set up going on my table
    Couple months ago i bought saw 14" housings and i still need to get the shafts and then springs off my buddy to go with my camburg hoops i just bought. have to cut off my old stuff then install the hoops and shocks. then i should be strapped at 18" up front
    May 2010
    Visalia CA
    I like the de smoked look
    Long Beach, ca
    i was hesitant at first but im starting to like it.
    May 2010
    Visalia CA
    Black wheels I dont mind but I'm so tired of tinted taillights and headlights.
    Long Beach, ca
    headlights are just plain stupid
    May 2010
    Visalia CA
    got that right!
    Laguna Niguel
    looking killer devin. i ditched the murdered out look aswell. i think it looks cleaner and draws less attention. thats bryans engine cage huh?
    Huge Thanks To Kevin at Good Knight Racing and Fabrication. Amazing Fabwork, Even More Amazing Price!
    Find another sport, your truck will never be finished.
    Long Beach, ca
    yep bryans picked it up last night. been wanting to ditch the white paint and go with a flat Grey color. still up in the air though
    Senior Member mounty71's Avatar
    LB/Simi
    That would look pretty good, here's my friend's old explorer for reference:
    Quote Originally Posted by Jimmy Baja View Post
    ... this takes to much of my time, the internet is ignorant and you only lean how to push buttons...
    Long Beach, ca
    yea ive been wanting to do it for a long time. seeing a ranger on the freeway to work that has it done makes me want to more and more
    Long Beach, ca
    Truck got a new heart and engine cage should be a lot better
    Attached Thumbnails Attached Thumbnails imageuploadedbytapatalk1328979537.667802.jpg   imageuploadedbytapatalk1328979552.966022.jpg   imageuploadedbytapatalk1328979574.975248.jpg
    Long Beach, ca
    Going through truck for a prep. Had my leaves rearched and added the triple wrap onto the pack. Revalved shocks. Front end is in progress of being gone through. Will post up some pics tommorow
    Long Beach, ca
    Not to much progress today got more parts needed painted 1 side beam and radius arm
    Attached Thumbnails Attached Thumbnails imageuploadedbytapatalk1334548017.985962.jpg
    Can you say sketchy? Lol looks good man keep up the updates
    3 Seater Whoop Eater? murderedoutranger's Avatar
    glendale az
    like the dirtbike stands
    Originally Posted by OC96Ranger The thing looked clean as a whistle but smelled like the deadliest catch.
    Long Beach, ca
    Lol it is sketchy have done it a couple times like that though and no problems there is another jack stand further back on frame
    Long Beach, ca
    Well I should say two more jack stands
  1. Project Retro-Runner's First Event This Weekend...
    By spalind in forum General Off-road Talk
    Last Post: 07-13-2011, 10:13 AM
  2. 93 ranger pre runner
    By fourbyrunner in forum Trucks & Buggies
    Last Post: 01-14-2011, 11:33 AM
  3. 00' Ranger XLT Pre-runner....in AZ....again
    By joshy219 in forum Trucks & Buggies
    Last Post: 09-03-2008, 01:07 PM
  4. 00' Ranger XLT Pre-Runner......in AZ
    Last Post: 05-06-2008, 09:55 PM
  5. 1998 4-runner...linked dezert runner
    By burDom13 in forum Trucks & Buggies
    Last Post: 07-07-2007, 11:25 AM
