Hey guys,
I JUST finished college at Art Center College of Design in Pasadena. Its finally time to take my Explore back out of the trailer and get the ball rolling... My first go around with this thing had a 4.0L and coilovers up front. both the engine and roll cage were just sketchy fabwork I did when I was younger. Gotta learn somehow right?? But I got this truck when I was 16 and I just cant except having it the rest of my life with jank ass work on it.
Soo, I have started from the ground up doing it right. These pics are from 2007 before I left for school full-time. Its now resides in a enclosed trailer, safe and NOT rusted! But its time to take it out for good....
So heres a few specs/parts I already own or have built. Im getting tired of typing, cause I just posted a "introduction" before this...
-frame pulled forward 7" reinforced throughout with 1/8" and 3/16" cold roll plate. (chopped about 16" after the B pillar)
-Solo motorsports 4wd beams extended 7" per side. With custom axles. and cut/turned. (84.75" Track)
-unequal length swing steer
-body completely gutted, no floor pan, no fire wall. inner rocker panels reinforced with platework.
-custom radius arms with 1 1/4 hiems blah blah...
-2" 4130 cage throughout, all TIG
-started bracing the body to the cage via plate but have not finished.
-460CI big block(iron block) built by SpeedOmotive in covina. 550bhp on engine dyno.
-Art Carr C6
-dont have a rearend yet or fuel cell etc.
-35" projects
plans: Set up the truck for 100% all wheel drive. Full sealed cabin(or at least appear sealed) not luxury prerunner status, just some boat carpeting, A/C, heater, and windows that work. Probably a floater rearend if I can afford it, but it's important that the rear track is relatively the same as the front. 1 spare standing up outside behind the hatch. low-pro roof rack. 2 buckets, 1 bench.
Its likely the front will be strapped and pull a clean, working 4wd 20". Coilovers/bypasses mounted far back on the trailing arms for interior packaging reasons
im going to build aluminum fuel cell to fit wherever there is space.
...and thats all i got right now. Of course i'm here to answer questions
