So I have been trying to convince my friend Scott (T.C.TACOMA) to start up a build thread like I did for Reno. He doesn't spend a whole lot of time online so he told me to write one up for him. He may not even post up on here a whole lot, but I will try and keep updating as the progresses.
Scott and I (Curtis) have been going to the desert together for close to 10 years now. Back in 2005 we lost our good friend Tim, the 3 of us went on all of our desert trips together. After Tim passed I feel Scott and I became a lot closer. I started getting into prerunner trucks and began doing lots of research and collecting parts for my truck. Scott caught the disease and started to follow me. Scott however built his truck with the mentality of keeping the truck in the dirt and doing upgrades little by little (especially since this is hisDD ). This is something that I wish I too had done from the start, and would tell anybody the same thing looking to build a truck. Enough with the background, onto the truck.....
The truck is a 2000 Tacoma with a 3.4L v6, he originally got the truck back in 2002. When he first got the truck it had a doetsch tech coilover kit in the front and 33" tires on weld wheels. He at one point got rear ended and decided to have a roll pan installed on the truck and shaved his tailgate. At the time we were into custom trucks and went to a lot of truck shows. This however will end up helping with his build and come into play down the road.
After he got the prerunner itch he began collecting parts. The first thing he bought was a set of 8" Racerunner coilovers and held onto those for awhile. He also got a pair of glassworks 4.5" front fender that were already painted silver. Eventually he saved up enough for the Total Chaos Long Travel kit that he got directly through TC. We installed the kit and poly urethane bushing upgrade on the side of his house using a pretty minimal selection of tools. Looking back at these pictures I laughed my ass of at how fucking sketch the jackstands were. We took the truck to a friends shop and welded on TC spindle gussets and made the start of his bumper. He took the truck out to glamis for its maiden journey with the LT kit. He was stoked how well the front rode, but realized right away how much the stock rear sucked and started saving/collecting right away.
We started roaming all the classifieds and picked up a set of deaver F67 leafs, u-bolt plates, 16" Racerunner smoothbodies and a T100 rearend. He and I both got 32 gallon fuel cells from the group buy that HITMAN on DR put together years ago. He later went to TC and picked up the hangers, 12" shackles, shackle gussets and spring perches.
Since Scott was working with a very minimal budget we were forced to sell basically everything that we took off of his truck in order to fund the rest of it. And we literally sold every little piece, most of which we got high value for. We sold his bed/shaved tailgate for $800 and his stock rearend with electronic locker for $850. Items like this definitely helped fund a lot of his build.
We took the truck to our friend Dan's house in Lake Mathews and started tearing into it. This is about the time that our friend Reno also came into the picture. In fact me and Reno went and worked on Scott's truck one weekend while Scott was at some family reunion in Nebraska or some shit. He put a lot of trust in us considering it was our first build!
We stripped the frame down to nothing and then boxed the frame from the cab back, welded the hangers, shackle pivots and spring perches on the truck. We drove the truck up the street (with just the main leaf to the pack bolted up, thing sat low) to my grandparents house also in Lake Mathews and began working on the bedcage. We read the bedcage how to build on desertrides.com and used the board method. Drew arches at full bump and droop to determine where to mount the shock. Went to G&J aircraft in Ontario for extended brake line and all fuel cell lines. Plumbed the fuel cell using the stock internal fuel pump. When we finished the bedcage he drove the truck home using tie downs to hold the cell down. The next week we went to a friends shop and made some cell straps.
He drove around for a months after that with no bedsides. We decided that the 4.5" glassworks bedsides he had were not going to cut it with the wider T100 rear on it and the wide offset weld wheels. So he decided to go with the fiberwerx 8" bedsides.
After finishing up the rear Scott went out and used the truck a lot. The only problem he encountered with the kit while he owned it was that he bent one of the stock tie rods. Over the next few years he had a lot of smaller upgrades. He built a bumper, and mounted 4 hella black magic lights on it. He sold his 4.5" glassworks front fenders and got a set of Chad McNeil 6" fenders. Added a 4 pin Glassworks hood with scoop. Mounted some PRP seats to sliders that bolted to the factory mounts in the cab. I finally convinced him to ditch his old sub box so he would have room for camping gear since he no longer had a bed. He eventually also got rid of his weld wheels and got a set of KMC enduro's in a black finish. He went from a 15x8 with a large offset to a 15x7 with a smaller offset. This made his trackwidth shorten up a bit.
We scored a killer deal on a set of Fox double bypass shocks on RDC and he installed those using a the TC secondary shock hoop. This made a huge difference on the kits performance. He noticed the difference right away his first trip out. He and Reno later changed the valving around some and was able to get the shocks to work very well together.
He found a set of Racerunner 16" triple bypass shocks at the swapmeet one year and swapped those out for the smoothbodies. He also added a set of 2.0x4" Racerunner bumpstops in the rear. He traded his deaver F67 pack with desert_silverado from DR for his All-Pro 50T pack. And eventually he got the truck painted one color again.
[IMG}http://i92.photobucket.com/albums/l32/xjohnnyy5/taco/ocotilla.jpg[/IMG]
We found a Camburg Race kit in the DR classifieds for a pretty good price and Scott jumped on it. Sold the TC kit and bolted on the Camburg Race kit, while still utilizing the stock coil bucket.
The new Camburg kit runs wilwood 4 piston calipers up front so he had the stock front calipers laying around. He swapped them into the rear using bolt on brackets from ruffstuffspecialties.com.
After having the new kit on he took it out a few times and was very happy with the kit. He started to push the truck a lot harder with the assurance of the stronger hubs and components in the new kit. On one of these trips to Reno's place in Johnson Valley he ran into trouble with his bypass shock rubbing into his tires. The smaller offset wheels along with the addition of the bypass tubes meant there was a lot less clearance between the two. The first night we were there he blew through two tires and was forced to drive to Apple Valley to pick up a new tire. He took it easy on the truck the rest of the weekend and made it home.
That trip Reno, Scott and I came to the conclusion that he should have wheel spacers made. He ordered a set of 1.25" spacers that he had made both hub and wheel centric. He also had the spacers made to convert from the stock lug size to a 5/8" lug in order to match his front lugs. The spacers also helped the rear match closer to the width of the new wider front kit. On top of that it also gave him the clearance he needed for his bypasses to not rub anymore as well as helped fill the rear fenders like they had before.
Here are a few random shots of the truck out in the dirt....
DR Meet in Riverside
Pitting for friends at MORE Night Race
El Mirage
Glamis
Johnson Valley with Reno
We went out to Ocotillo Wells for New Years 2010/2011 and Scott got in an accident. Scott not being very familiar with Ocotillo was out driving around at night and he ran into a ditch that snuck up on him real quick. The rain that had come earlier that week had basically made a large rain rut and the drivers side of his truck took the blunt of the impact.. The drivers side frame got bent up a little bit and he cracked his steering rack (thank you autozone lifetime warranty!!). He took the truck to a body shop and had the frame straightened.
After the accident happened he couldn't be out of a vehicle to get him around so he bought an F250.
Now that he had aDD his original plan was to tear apart the Tacoma and build a cab cage and engine cage for it. On top of that he wanted to run longer shocks in the front in order to obtain the maximum potential out of his Race kit that his 8" shocks wouldn't let him get. However after doing lots of thinking he realized he wanted to be able to use the truck this season, and with the amount of time he had to devote that wouldn't be possible. He decided to just concentrate on the front. He is in the process of reinforcing the frame up front, running an engine cage, and running 2.5x12" Racerunner coilovers and triple bypass. This has already been started, but pictures are soon to come.
