open those tubes up yo!
And yes, a true dual rate would help on that, your top one is just acting like a tender the way you have it
very nice build up....alot of hard work has gone into it...makes me want to start on my truck now...
Thanks dude.
Well I started on the front bumper last night, its going to be bad ass when its done.
MILLER OFF-ROAD MOTORSPORTS
FRONTIER FENCE | E&L | ORW | GMACHINE | CAMBURG | PERFORMANCE WATERJET
1999 5.3 Single Cab Silverado - LINK TO THREAD
1996 2.3 Single Cab Ranger - LINK TO THREAD
Unreal build. Kudos is all I can say, stellar patience, work ethic, and attention to detail. Very inspiring.
Thanks dude.
Well with the help of my best friend Justin, we were able to get the main hoop bent up and tacked up to the truck yesterday!
you can be patient with your fab work but stop being patient with the pics!!
Can't believe I spent two days of testing at work to read through this thread. Holy crap.
I must say though, some damn amazing work on that truck. Makes me want to get into my project even worse...and I can't weld half as good.
Nice work dude.
Ohhkay havent posted some Silvy updates in a while. Here is the bumper I have been working on a little at a time. What do you guys think?
The lower hoop is driving me nuts, its 1/2" higher than the lowest part of that cross member but it looks way low to me.
I think it looks good but why dont you just run those skid tubes directly to the subframe?
I say scrap it and use the money for some new rims on the ranger!
No, seriously I think you should leave it if your not gonna tie it directly into the subframe. It looks really good where it is. I just prefer the other way.
Every bolt comes out with plenty of room except for that right off setted one. Ill have to make that down tube removable because there is just no way around it if you want a nice looking skid plate.
Ya I can still get the rack out but that bolt wont come all the way out on mine
Its simple and clean. Nothing to flashy about it i dont think. Run it!
it looks good nice and simple then once you put the skid plate on there itll look even better.
J C Engineering
That looks good! Very clean!
hey i had a question. You braced your core support with these and i was just wondering if you any problem with spider cracks in the glass from the flexing since its somewhat hard mounted and you bolt your glass to it.I know it most likely has bushings where it connects to the shock hoop. I have no inner fenders and my core support shakes a lot with just the one little brace it has. Where else do you mount your glass to?
Counter-sink some stainless allens in that skid. And im still waiting for a side view!! Looks real good.
And when the fuck did you get those projects???!!!
since like page 6 or something! get with it dale!
That was the old setup going from the cage to the stock mounts on the core support. I had to ditch them and make new ones when I put the bigger radiator in with the motor swap. It held the core support super firm to where I was able to lean and stand on it. As for the spider cracks I couldnt tell you because I never took this setup to the testing grounds. Give it a try dude.
your work is so clean! What radiator/ fan setup is that? Just a fan out of an hd or ls1 or something?
haha i dont remember all the details. my apologies!
and have you had any problems with it hardmounted like that since the body moves on bushings but the radiator is solid and glass bolts to both?
Not done yet but here is a preview of the bolt on nerf/light bar. It sits infront of the main hoop 3". Its hard to tell cause I matched it well but from the side you will see when I take a picture. Trophy Silvy?
Dam you have a few lights now. So how much more till this thing sees dirt again. Are you still going to be able to have your head lights and everything in there?
J C Engineering
You worried about airflow to the radiator at all?
If you havent heard this enough your truck is bad ass man. Was this your first build? How long have you been working on this one?
you need to post some pics up with your new hids!!
there ya go johnny thanks for the lights man
