Hydroboost is cool, but it costs a lot of money to do properly. You have to shell out the money to upgrade your power-steering pump in order to compensate for the extra work you're asking it to do on top of increased tire size.
James
James
i had all the same problems when i put a kit on my 06 silverado. for the brake lines on the driver side just roll them up off the frame, but be careful not to kink em. and the booster was a big pain in the ass for me to, but with putting your bypasses in its gonna be even harder to fab a hoop on that side. I pulled a bit of my hair out doin it, but im sure you'll make it all fit. good luck.
MILLER OFF-ROAD MOTORSPORTS
FRONTIER FENCE | E&L | ORW | GMACHINE | CAMBURG | PERFORMANCE WATERJET
1999 5.3 Single Cab Silverado - LINK TO THREAD
1996 2.3 Single Cab Ranger - LINK TO THREAD
how does that piggyback fit at full bump? have you cycled it yet?
MORE 1419 Snore 1499 Taco with a side of Beams!
Trinity Motorsports
PolyPerformance.com
Powered by Jesus!
Cheap aint good and good aint Cheap!
the UCA hits the resi on bump and i knew this was going to happen. basically i didnt want to wait another 6 weeks to get the shocks custom made to have a remote resi. so i called up kartek, purchased them in piggy back, and will have them converted to resi.how does that piggyback fit at full bump? have you cycled it yet?
Finally welded up the frame plating, 1/8" cold rolled.
Looking good man. Build up is great.
Thanks for the shocks by the way
truck looks awesome. i can only dream of the day i tear mine apart to do the same... i am worklin on that day though lol
Fear brings hesitation, Hesitation makes that fear a reality...
engine cage moving right along, got both hoops tacked in last night.
Nice build. I have a 04 silverado with the camburg long travel kit. I am having alittle trouble with the truck wandering on the road/ freeways. Have you experienced this problem? The kit has about 30k miles on it and it did it from day one. Before that kit I had the camburg performance kit and that did not wander. Other than that, its a great system. Let me know if you know anything?
colin
Engine cage welded up last week so my buddy Jacob and I fabbed up the cross brace between the two shock towers. Came out perfect. I still can get to my trans oil dipstick/fill, my engine oil cap, and other vital parts without having to take it off evertime I want to do motor service. I got better at my tubing to tubing welding too.
nice job man lets see it on all 4's
Just read the entire thread. Truck is coming out really well. Looks like you have paid very close attention to detail, and I think it paid off. Well done
Ryland
2004 EXT Cab Tacoma 4x4
Custom LT w/ Tundra front axles
62" Deavers TC shackles
finally almost done! looksgood man. love th ebuild. any more pics of th elowers. look slike we got the same idea on the lowers. you gonna plate the lower shock mounts at all?
Bbr is no longer doing any more fab work
i just read the whole thread! its an awesome thread too!!im goin to be doin a story just like urs on my colorado! thanks for the inspiration!
looking good. It must feel good knowing that the truck can almost stand on its own. How are the bumps coming?
any updates on the build?
right now my computer is broken so i cant post pictures but i got the engine cage all welded up and plated, finished the bedcage and painted it, purchased 2 rims for the baja tas, and started welding up the arms.
Everything is looking good Miller. One thing, bail those polly bushing for your cross member or your towers will flew like a mofo. Run some Delrin or get some harder ones machined.
where could i find these delrin bushings online?
Right here http://dezertnation.com/ Email us if there is something you done see
Nice build BTW![]()
FOKUSINDUSTRIES.COM
SUDPRODUCTIONS.COM
I believe he is doing a V8 swap as well
"Your bed is a racecar? Yea, but its a sweet racecar"
02 Silverado-Fugitive front end-Cone 9in floater-F87's-3.0 tripples-SOLD
02 Z06 Vette-MS3 Cam-Kooks LT's-440RWHP-Tuned by Jim at Cal Speed and Performance
07 Street Glide
man, thats some nice work. i cant wait to see the action shots of this, theyve been a long wait
alright cagework is done, arms all welded up just need to plate in the LCA but i can do that later. aiming to get the truck on all 4s by the end of this weekend. also making the two battery boxes and the mounts on the back of the truck and going to try to put on the corr style bumper i made months ago.
fuck ya, i cant wait for this truck to be done.
-brock
gaaahhhh damn i just spent an hour reading this whole build badass build man keep it up!!! everything looks titties!!
bitch it aint broke yet! just throttle down and it'll be smoothy smooth trust me
the internet is loaded with pussys that cry about what my sig says!So i deleted it!!!!
ya i just read the whole thing, somehow i missed it it all looks sweet
so i checked out the desertnations site. do the killer pushing kits come with delrin bushings or poly because i have those bushing kits on my truck. the brace for the engine cage has 2 and the arms have 4 except they are 5/8 ID and 1" OD on the inner sleeve. it says "These bushing assemblies are for severe duty locations such as pivots for trailing arms ect".
Just a heads up, I have a very similar style setup on my F-1. The bends on that cross-brace will continue to bend with time and will cause your frame rails to roll inward at the top. Also, those shock mount tabs will put TONS of twisting force on the tubing and will eventually tear. Mine are plated in joining the inner mounts on both the coilover and bypass and they still tore.
James
The "Killer Bushing Kit" is from Poly. IF you want to run Delrin then look at Item #61 the 1.75 Delrin like for .120 wall tube.
FOKUSINDUSTRIES.COM
SUDPRODUCTIONS.COM
pulled the truck out after getting a whole bunch done. i have tons of pics to post but can only post this for now (due to my comp deciding to fail and having to use other peoples comps)
Have you fixed your computer yet? I need more!
what did you do to clean the frame so well? and are your mis-alignments for the upper arm the blitz ones?
when i did mine i used engine degreaser, and a putty knife, had the back half done in a half hour then wiped it down with brake cleaner and a rag.
i also found out you can use just brake cleaner and a rag, will prob take longer and youll go through a shit load of rags lol
what about a scraper? i noticed its like a rubber coating on the frame? then obviously clean it afterwards. and how is the truck coming along? any new pics?
