Page 1 of 4 1234 LastLast
Results 1 to 40 of 147
    The Dude Slablocal's Avatar
    May 2005
    Newport Beach
    Default Speed Unlimited F150 Build
    Well we thought we would bring you all along for the build on this F150. As of now we are about a week into it and have finished a majority of the cab cage. I'll be updating the pictures a few times a week, so check back often!
    Attached Thumbnails Attached Thumbnails f150build-007.jpg   f150build-009.jpg   f150build-010.jpg
    Hampton Bro's Racing rharleyrider's Avatar
    oc
    Dont like how they did the top front window tube.
    DON’T JUDGE MY BELONGINGS TO YOURS
    Senior Member tre5's Avatar
    Goodyear, AZ
    Quote Originally Posted by rharleyrider View Post
    If it is the same shop. I think they know what they are doing...
    http://www.speedunl.com/webpages.asp?wpid=8
    Senior Member HiTaRut's Avatar
    Sep 2004
    costa mesa ca
    looks good john. pre runner? race? what r the plans?
    GiTsiKWiDiT
    May 2005
    Newport Beach
    It is a prerunner, but the customer wants to be able to enter it in a race if he wants.
    rharleyrider - If there is something that you dont like (everyone has something they don't like or would do differently), at least explain your reasoning. Of all the areas of the roof, that is the least important area. The fullsize V-bars will continue through the firewall directly into the frame and the corners of the upper window tubes will get a corner gusset once the tubes are welded. Which will be MORE than strong enough.
    Pomona, CA
    Looks like a clean build, great job. Looking forward to seeing the suspension built
    AXISoffroad
    1s1k motorsports
    Likes to Party! esbyota's Avatar
    AZ
    I don't think he questioned the stregnth or what you guys produce at all. Only stating the front overhead window bar LOOKS ugly with one bend in the center. Other then that looks bitchin...
    -Brad
    *NOCTURNAL INDUSTRIES* Your local AZ fabricator, PM me if you need any fab done from bumpers to full race truck builds
    EL CARLOS TheTequilaWorms's Avatar
    Anaheim, CA
    looks clean.. keep up the good work.. keep those pics commin!
    -Carlos
    RSP Shock Prep - Camburg - BTF Fabrication - Good Knight Racing - Clean-Dezert.org
    Quote Originally Posted by cjlprerunner View Post
    Mods, please close this thread, there's people of dr who are fucking low life losers
    "THE GMR" jason@gmachine's Avatar
    signal hill
    Quote Originally Posted by Slablocal View Post
    It is more of a style thing, some may think it needs to be more forward and tucked with the window line otherwise it looks ugly. The way SU is doing this bar is not my style but that does not mean its weaker. It is not even done yet, and im sure by the time its done it will be plenty strong. SU does great work and i would assume they know what they are doing with this project.
    looks good man.
    jason
    oc
    My comment was 100% more about fashion than function. I just see that as more of a pain to build a corner gusset that would keep the corner bend of the a-pillar strong with that top tube so out of the junction??
    May 2005
    Newport Beach
    Wont be much harder, just a little more angle on both notches. Once its all plated in it will all tie together fine.
    central coast
    nice work cant wait to see it done. if i had the $$$ SU would be see my bronco for sure.
    ps any idea when the Bronco will be done
    esmf
    May 2005
    Newport Beach
    A couple more..
    ninja member beandiggity-o's Avatar
    brea
    awesome plate work yo
    "too close for missiles, switching to guns"
    Yeah, it's like that. Cerberus2k7's Avatar
    Tempe, AZ
    Ok, really REALLY stupid question, but what is the process of making those dimples and what's their main purpose?
    Truck looks bitchin though. I would love to be able to weld that clean. Well, I would love to be able to weld well period, but you know what I mean.
    Senior Member promoto164's Avatar
    Paso
    the purpuse of the holes is to tie the plate into the frame more so it becomes more like one piece than a piece put on top of the frame. gives more welding contact to the frame so the plate wont rip off. very wise thing to do and very strong. also a great way to tie in those tubes to the frame. this method (plating of the frame) is called hard facing if i am not mistaking
    good looking build. SU always puts out top notch work
    -mitch
    The problem is the people who really know how to run the country spend all their time working on trucks.
    for all you need off road---> PolyPerformance.com
    Tempe, AZ
    Quote Originally Posted by promoto164 View Post
    -mitch
    Sweet, thanks. What about punching holes in the gusset like I see on rollbars and bed cages? Don't mean to hijack, just been wondering for a few days.
    Pomona, CA
    Quote Originally Posted by Cerberus2k7 View Post
    To get chicks. Seriously.
    AXISoffroad
    1s1k motorsports
    May 2005
    Newport Beach
    exactly like promoto said. if that plate were solid with no welds in the holes, it would be depending only on the edges which are welded on. now with the holes welded in, i can mount a bump stop or lay another tube into it... without having to worry about the bump "peeling" the plate work off. without the holes, the plate would work back and forth enough and eventually do the paper clip effect, and crack or break.
    I'm a DAD and its RAD! flomaster's Avatar
    Jul 2003
    Chino Valley, Az
    Dimple Died holes make the piece of metal stronger and less likely to bend when done correctly.
    -=Jason=-
    p.s. plus its got the Bling Factor and that pulls Nanny
    97 4Runner SR5 4x4
    RIP Ranger 06/2003-10/2008
    Racer GFORacing1404DJF's Avatar
    Camarillo
    another thing. bringing that front bar back like that makes the very top roof bar angled more rearward, makes for less head room IMO.
    GFO Racing
    BMS*Sud Productions*DW Photo*FastTech Designs
    PORKSODA BLACKULA's Avatar
    TEMECULA CA
    Quote Originally Posted by GFORacing1404DJF View Post
    if you really think about it, your not loosing much head room.. when is your head really at the same place as that tube? and if your head WAS there, wouldnt it be hitting the tube if it were where most everyones tubes are (slightly forward)?
    i aint baggin on ya, i just dont it makes enough difference to where you really loose head room. i mean, when your sittin in your seat, your head really isnt even close to those tubes anyways.
    looks good though man, looks tuff!
    myspace.com/black_metal_works
    Quote Originally Posted by I Love Tacos View Post
    \just for the record, i pissed in the sink of girls loccer room at temescal canyon. TWICE!
    Quote Originally Posted by FCOD View Post
    If there's no grass on the field, flip 'er over and play in the mud.
    Senior Member Inde-Fab's Avatar
    Jun 2008
    Santa Cruz
    thats funny, the first thing I noticed was the windshield head tube too, but I like it, it creates another slight angle to the piece in question as well as locating the joint behind the bend. I think this is probly a stronger design than streight . It looks like cage strengths and frame integrity is the last thing this truck will have problems with. Props on all the fab work
    Independent Fabrication
    indefab@yahoo.com
    my rep. was 1 mill before jodaddy23's Avatar
    tucson *az.
    topnotch ? maybe middle notch , what happened on the right circle . ?
    Quote Originally Posted by roostthemoon View Post
    Dude...there real if you can touch them.
    Quote Originally Posted by GREGASAURUS REX View Post
    I don't think they work very well because I can't STOP winning races. haha
    May 2005
    Newport Beach
    Quote Originally Posted by jodaddy23 View Post
    I decided to throw symmetry out the window to make way for function. Which is tying tubes into the frame, adding strength to the frame notch, and making sure I wont be welding through a hole when I add a bump stop.
    Anaheim, CA
    nice plate work.. that center circle looks a little funky haha.. no biggie.. good job
    -Carlos
    May 2005
    Newport Beach
    No more stamped mild ball joint beams...
    Senior Member steveG's Avatar
    Arroyo Grande, CA
    You guys are animals! I can't wait to see the final product.
    How about a pic of the passenger beam?
    central coast
    iam with Steve more pics please
    esmf
    Tempe, AZ
    Is the engine using a custom mount? Or is it bolted into the stock location?
    signal hill
    Why keep it a beam truck?
    Kinda seems like going backwards. All this work and technology, i think it would cost the same to do an a-arm 4x4 that will handle better.
    looks good either way, just curious because i know SU is not cheap.
    jason
    May 2005
    Newport Beach
    The engine is in the stock location.
    Jason - doing a whole a-arm 4x4 front end would be bad ass, but its a whole new can of worms. We want to keep the vehicle true to its roots, and while it isnt the most modern of suspension designs, the D44 TTB front ends is still a good handling, proven strong front end. And the thing that gets me is that the weakest points (balljoints & knuckles) have never been eliminated to make an even stronger setup. I want to raise the bar on the 4x4 beam design... there are still tons of people running D35/D44 beam setups, and its time to give them some options.
    Gamer
    SD
    And the thing that gets me is that the weakest points (balljoints & knuckles) have never been eliminated to make an even stronger setup. I want to raise the bar on the 4x4 beam design....
    Just out of curiosity, have you personally ever seen a D44 ball joint failure? I know that in theory the ball joint is a weak point, and everybofy says that, but I've never seen a good set fail, even on race applications.
    94' Lightning (Oprah)
    Arroyo Grande, CA
    Quote Originally Posted by Sites View Post
    Same here. I've seen them fail, but improper installation, lack of maintenance or worn parts were to blame in the cases I've seen.
    BUT, That's just for conversation. I'm really looking forward to seeing more of the project.
    signal hill
    oh, makes sense. Im not a beam guy myself but i cant wait to see the detail in the welding on these beams. Are they going to make them similar to the Bronco ones with the TIG action?
    jason
    May 2005
    Newport Beach
    I have never personally seen a bj fail completly, But they wear out constantly. If you race a D44 beam truck with 35" or 37" tires, you will first wear the bj's out, then crack/tear the snout off the knuckle, and have too small of brakes for the application. Uniballs will last longer, be easier to change out, the knuckle assembly will handle the abuse, and you will have 14" rotors with massive brake calipers.
    Jason - These beams will have almost identical styling to that of the bronco, but much easier to build in a repeatability standpoint. They will also be mig welded. We will be offering a complete front end kit after this project, so its being cut and bent for mig tolerances. Should come out real nice still.
    I dont know why the picture on the last page shrunk either, so here is the fullsize of the beam...steve...haha.
    Arroyo Grande, CA
    Is this going to use the stock pivots?
    May 2005
    Newport Beach
    No, it has a 1" uniball and were building 2" drop brackets
    Racer only1mikey's Avatar
    looking at the drawings it doesn't look like there is going to be any camber adjustability. Since the beams are going to have a fixed ride height how much lift are you building into them?
    Arroyo Grande, CA
    Cool. Is the distance between the differential and pivot end the same as stock or are you extending the beam there as well?
There are currently 2 users browsing this thread. (0 members and 2 guests)
  1. Speed Unlimited Canti-Lever Kit
    By Slablocal in forum Fab Shop
    Last Post: 10-10-2011, 02:29 PM
  2. Speed Unlimited Chase Truck Rack
    Last Post: 01-10-2008, 02:02 PM
  3. Speed Unlimited Motorsports
    By Slablocal in forum General Off-road Talk
    Last Post: 07-16-2007, 10:49 AM
  4. F150 build
    By GarageRanger. in forum Fab Shop
    Last Post: 04-02-2006, 10:45 PM
  5. Speed Unlimited Trophy Truck
    Last Post: 04-02-2006, 03:42 AM
