figured id start a whole thread for my truck since its starting to come along.
its a 94 toyota 4x4
specs:
Front: Matt Heltons gen 3 kit - coil-over - bypass - bump
Rear: Back-halfed with Custom 4 link - coil-over - bypass - bump
custom currie axle with all tig welded dimple die trusses, 40 spline axles, 5/8 lugs, spooled, 4:56 gears, strange nodular case.
32 gallon jaz fuel cell
35 inch tires
caged front to back all DOM and almost all 1 3/4 .120 tubing
beard race seats
blitzkrieg steering column with tenzo steering wheel mated with a sweet disconnect.
heres some pics:
this is my first build and of course my first 4 link set up. i have so far barely any drive shaft plunge as far as i can see and very little pinion change but im not sure if u can see in the pic if things look right.
this is drooped out and the pinion is pointing down just a tad probably only a couple to few degrees, its not very drastic at all and i dont think there would be any binding. i think this was a pic at almost 30 or so inches of travel
let me know what you guys think
