Been putting this off for a little while. Started this truck back on May 3rd, 2004.
Picked her up at Drew Ford for $17,000, its a 2001 SuperCrew XLT with a 4.6L Triton V8 it had a little more then 46,000 miles on the odometer.
Went to Iraq for 7 months and dropped it off at ORC motorsports for the front Long Travel kit. So after a full year of owning the truck it turned into this. Full custom upper, lower, spindle, 2.5 10" Kings and Fiberwerx 6" front fiberglass.
Then came the fun part. After a few trips on the truck the engine cage failed. Due to the fact that ORC built the engine cage out of Mild thin wall when DOM was suppose to be used.
These pictures are after the failure and in order to get it up to be replaced by Kenny at Alliance Fab it was hack welded to get the cross bar back in that had ripped off.
And this is what was found when Kenny removed the prior engine cage!
So kenny replaced that cage with a Chromoly Cage the truck has now. He also added 2.5 King Bumps. Very happy with what Alliance has done for me.
So I have Kenny build me a bolt in bed cage, with 2.5 Kings, Deaver Racepack, 6" Fiberwerx bedsides, and a two piece driveshaft by East County Driveshaft.
So after close to a year Jason at Fiberwerx asked me to use the truck to Prototype a new front one piece clip on the truck.
After that the rearend blew on me so I called on Alliance once again to supply me with a new axle. He answered with a Currie 9" with Strange 3rd member, 4.56 gears, 40 spline axles, and a full spool. I took the time to add Fox Bypasses to the rear and dual stand ups.
That brings us to now. I have been playing with motor issues for the last year or so. With getting out of the Marines and moving the truck has sat the whole time. I finally got a house to work on the toy. So over the last two months Nick (allupinsideya) and I have done some work to the truck. So far the start to a new Bed Cage its still got alot of cross bracing to go. Not to mention the fenders getting mounted and things jack, on board air tank, dual spares, dust lights, limit straps, and bump stops.
I will be adding more as this project continues.
we are hoping.
