Its definitely a work of art, the guys over at Camburg put out some amazing stuff. Couldnt be happier with the work they did.
I have a couple questions mostly pertaining to how your glass is mounted.... since i have same glass and having issues (mostly cause my cab is 3/8 to one side and the cage work gets an 1" wider as you go back, not my work)
anyways i notice camburg has the rear bumps right at the frame, allowing the tires to bump all the way up just before metal... i do not know how close your fiberglass cab sits to the height of a stock cab, but have you bump your tires out and articulate the suspension? We built the glass with it bump and put a 2x4 in between giving about 1 5/8 gap, but after we unbolted the sway bar and articulated it the front edge of tire does godes un into the glass, only way we could fix that would be by lowering bump stops a little lower.
Just curious if you had the same issue, i hardly doubt it being that camburg built it, but these glass do not have the trophy hump in them so maybe you did. Did camburg or you shave any part of the rear glass?
Also on your front clip, is their a hood pin or some type of mount down by the lights on the edge where that lil flange is, cannot see in your pics?
How did you connect your qtr fenders to the main clip?
Are you going to run a stock dash or leave the clip the way it is?
cut your glass its easy as that.
"adam im done even listening to you... your a hipocrit and more and im not going to even acknowledge you anymore... please dont start crap in this guys thread... "
FTW
can you post pic of your qtr fender mount, is it the hinge latch style that you see in clip with the lil inset for it.
can i c a pic of the bedside like the back lip and wheel well curious what you trimmed out
does your glass spread wider s it gets to the back and does it slant down a lil from inside of glass to outside of flare
what is the wire on the rotors for?
I need to safety wire my rotor adapter bolts, I have to check them all the time and they have been loose before.
hey were you the guy i talked to here in ridgecrest?
hey r those the pwr or fluidyne coolers? are they both for tranny? if so what are you doing for engine cooler? also what electronics are you going to run (2 way, intercom, gps, etc) models please?
why not just call up the distrubuters and see what they sell? or you going to copy the entire truck. lol an engine cooler is called a radiator. lmao
FTW
pretty much every truck out there is going to be running the same electronics. Call up PCI, Racer X, they will set you up with everything you need. Even my 1450 trucks run close to the same stuff as a TT, minus the giant ass GPS and higher powered race radio. But these companies specialize in this stuff from TT - sand toys.
FTW
hey have you done your brake pedals, im having trouble getting a definate answer on which size bores to get for front and rear? I forget are you just using a 4.0l with some bolt on or are you dropping in a high horsepower v6 because that may make a difference i guess. Right now we have 4 piston calipers and 11.75x1.25 rotor in rear going to step up to at least a 12.19 maybe even more for the front now since we are switching to a 17" beadlock.
If you can help me with brake or refer to someone that be great... ive called a few people but havent got a definate answer all saying it depends or they are not the right perspn to ask for my setup
The brake pedal is just sitting in there with some clamps, havnt done the final placement yet because we just got the seats and we need to adjust the pedal to the driver specs. As far as the motor goes we have two, one is an 07 SOHC 4.0 that were gonna put some different heads, cams, intake and exhaust, nothing too major. The other motor were still in the process of building, been talking with Tom Morana and were gonna get a stroker kit, different heads, cams and some other stuff for it. Shooting to have around 300hp with that motor.
have u gotten your master cyclinders for your pedal
any updates?i want to see this finished already! haha
any updates?
www.fast-fabrication.com www.facebook.com/fast-fabrication
FAST Racing thanks FK Rod Ends, Yukon Gear, Glassworks Unlimited, Sway-A-Way, The GMR, JuanCo Performance Engineering, Raceline Wheels, General Tire, Icom America, Vision X, JBA Headers, MOMO, PRP Seats, Fragola Performance Systems, Optima Batteries, Powermaster, & Eibach Springs
I coulda swore this thread was dead lol, hopefully not. I love this truck
Call me Dylan if you want
Ohh she's so beautiful...
