-TC kit up front with coil-overs/bypasses and MF spindle gussets.
-Full MF cage front-to-back. 1.75" main tubes with 1.5" supports, all DOM.
-The bed cage will leave space in the bed, as well as feature storage boxes built in near the cab. The cab cage will not exit at the top of the cab for a clean look. The spare will be mounted under neath the bed (as far as possible). The truck will run bypasses in the rear with 62s and MF shackles.
-The cab cage will be welded 360* and fit tightly. The stock dash will be put back in and there will be not V bars in the windshield.
Overall this truck will be a very clean and capable prerunner. If the rain holds out, I should have it all wrapped up in 2-3 weeks.
Photos:
I'll post some more updates on Monday.
MF
