Not gonna lie, looks better than I thought it would.
I like prerunners and I don't care who knows.
Oh shoot dang that's pretty slick
NOR*CAL
one piece mounting is under way. Taking the hole saw to it was scary.
NOR*CAL
Start of the new cross shaft mount.
Tabs are just mock up
NOR*CAL
That's a big change, should be cool. What kind of coupling do you have connecting your steering shaft to the box?
zac
Just a regular borgeson joint. There's one more just before the blitzkrieg steering column.
NOR*CAL
Oh ok, hard to tell in the picture. Thanks.
zac
Drilled the cross shaft out for 5/8 bolts and welded some lock nuts in. Turned out alright. Still need to add tabs so make it double sheer
NOR*CAL
Back on the ground and the start of a new bumper.
NOR*CAL
sweet
WTT: My Deaver F-31's for Your G-50's
WTT: My Fox 2.0 x 8.5" for Your SAWS 2.0 x 12"
Kinda crazy looking but it should fit and protect a 20" led bar.
NOR*CAL
I like it
love it.
Got a crap ton of good stuff at the leduc swap meet. Bajas, wheels (to be converted to bead locks), a complete tranny, the rest of my fuel system, little HID's ( didn't want to buy a led bar) and a buncha little stuff
NOR*CAL
Tried reading through but couldn't find anything, I was wondering who's clip that is? It looks killer!
It's Hellion Race Products out of AZ
NOR*CAL
fuckin sick!!!
I don't always go to races...but when i do, i prefer dezert racing.
did you start with a set of cast mounts? kinda looks like it. i have a set of cast ones but instead used some non cast ones to make my mounts.
Yeah, pretty sure those are the cast ones. I would try and not use either type of stock motor mounts. I did mine the same as that and eventaully the cracked in the corners where they bolt onto the block. Eventually cracking my block...
-Brad
*NOCTURNAL INDUSTRIES* Your local AZ fabricator, PM me if you need any fab done from bumpers to full race truck builds
Wrong! They started as these ;-)
NOR*CAL
Start of the frame mounts
Too cheap for an LED bar
NOR*CAL
Engine is finally running. There's a lot of little stuff to do but it's getting there.
Exhaust kicks out through the bedside after the cab.
NOR*CAL
Fuel pump is sucking air and causing it to run poorly but its all getting slowly figured out
http://youtu.be/zzX60VZa_6Y
NOR*CAL
Why is it sucking air? How much fuel do you have in it and is this a cell?
Because I stripped the threads on the inlet of the pump lol. Yes it's a 22 gal jazz cell and it's got about 10 gallons of gas in it.
Initially it was sucking air at the filter before the pump. Fixed that and wrecked the threads on the pump while double checking the rest of the fittings.
But now it's hard to diagnose other problems until I replace the pump. Im just running a simple inline pump that puts out 125psi that I got from a friend. Any recommendations on a new pump on a budget. I was thinking about a walbro 255.
NOR*CAL
I have a piersburg(sp?) And they are not a budget pump. Don't really have any recommendations, I've only known of two decent pumps and that's the piers and I can't remember the other one
Im running one of these on my 3.4, no issues at all.
Amazon.com: Holley 12-927 Universal In-Line Fuel Pump: Automotive
How much psi?
I'm wondering if my 125psi is too much for my fuel system and making it run weird. You can hear in the video it struggles to idle but as soon as you give it throttle it snaps to life.
I donno. I'm learning lol
NOR*CAL
i dont feel like going back through everything, what motor? PSI on the pump doesnt really matter as long as it meets the minimum requirement of the motor, you should have a regulator on the fuel rail the regulates the pressure and sends the extra back to the cell via the return line.
It's a 3.4. I just need to fix the fuel problem and go from there I guess.
NOR*CAL
so close and yet so far. its good to see that the truck is running.
its kinda funny that your truck and ryan's both have fuel issues
Yes sir. At first it wasn't and had priming problems. But now it is about 3in below the lowest point of the cell.
NOR*CAL
