Page 5 of 79 FirstFirst 1234567891555 ... LastLast
Results 161 to 200 of 3125
791Likes
Thread: FAST-Fabrication class 7 unlimited build
  1. #161
    OnLy A cHaSe TrUcK CVP PRERUNNERS's Avatar
    Jun 2007
    CaLiFoRnIa
    Quote Originally Posted by trfytoy View Post
    What springs are you guys running on beams? This is ride height. 95% up travel.
    were running 12'' 2.5 swayaways with a 400/500 spring rate. they are 12 inch coils.
    looks like you have 14's with 16 inch coils???
    Brian Baker
  2. #162
    Racer trfytoy's Avatar
    Jun 2006
    Buellton, CA
    He got 14" coilovers with 16" lower springs 450lb and 14" upper 300lb. Im not sure why its sitting so high..
  3. #163
    Racer/ Photog Go Go Gadget Arms's Avatar
    Somis, CA
    dayum!!! you need about 6" less spring. a little more leverage on the coil over would help. Why did you mount the bypass on the inside? who do you think you are??? mike smith?
    GFO Racing 1408
    Giant Motorsports
    Pure Power!
  4. #164
    Racer 85yota's Avatar
    SLO
    14" SAWS use 2 14" springs. I'd go with a 300lb top over a 450lb lower.
  5. #165
    Jun 2006
    Buellton, CA
    Quote Originally Posted by Go Go Gadget Arms View Post
    lol...sorry, I figured the coilover should be mounted on top of the beam.
    Quote Originally Posted by 85yota View Post
    Thats what I was thinking. Oh well, thats what happens when the customer orders parts and not the builder.
  6. #166
    Grumpy Old Man F1sleepy's Avatar
    Aug 2006
    Escondido/Cuyamaca
    Damn, I sense a little hostility in here...
  7. #167
    Somis, CA
    in most scenarios you want the bypass as close to the wheel as possible so you get the most control and adjustment out of it. if you put the coilover closer to the fulcrum it may help your ride height by increasing leverage onto the coilover. minor adjustments should be able to get the height shorted out
    GFO Racing 1408
    Giant Motorsports
    Pure Power!
  8. #168
    Jun 2006
    Buellton, CA
    That makes sense, I was more concerned with the coilover trying to rip off the mount. Ill swap the bypass and coilover and see what that does. Thanks for your input.
  9. #169
    Senior Member V8ranger's Avatar
    Jan 2009
    L.A.
    I understand on an A Arm truck with an inner & outer shock setup to put the bypass on the outside. But on a beam truck, how much closer to the wheel is the bypass when it it off the front of the beam vs. the front of the radius arm? And aren't you concerned with ever hitting a big rock(sorry gregasauras rex!) & wiping out the bypass in that scenerio?
  10. #170
    RSP Shock Prep Chase550's Avatar
    Jul 2004
    Westminster, CA
    I would do the swap, a bypass sees WAY more leverage than a coil over could ever see under normal conditions.
    Hauber Motorsports - RSP Shock Prep - Team CANIDAE Racing
    Welding Innovations - The GMR - King Shock - Alliance Fab CNC Plasma
  11. #171
    Somis, CA
    Quote Originally Posted by V8ranger View Post
    If my bypass gets taken out by a rock, ive got much bigger problems to worry about. You really dont want to make the coil over do too much work or the seals will melt in a few minutes. the coil over does not have speed sensitive control and is not built to take the load that a bypass can take.
    GFO Racing 1408
    Giant Motorsports
    Pure Power!
  12. #172
    Mega Member F.A.S.T.clothing's Avatar
    Irvine, CA
    your joking right josh your going to say something like that... for months i asked you what springs to run, you finally said to ask someone else so i asked rob anderson
  13. #173
    Racer only1mikey's Avatar
    It's fine as long as the coils haven't be scratched return the 16's for some 14's, that should do it.
  14. #174
    Irvine, CA
    and josh
    I sent you 2 350lb 14" coils and 2" 450lb 16" coils for front
    the 300lb 16" coil goes in the rear
    300/450 for the rear
  15. #175
    SLO
    that's only 6 springs, I think he needs 8??? Also SAW shocks don't use a 14" and a 16" spring like King and Fox. Just 2 14" springs.
  16. #176
    Another thing I run 300 over 350 on my truck with the coil overs mounted off the front of the beam. To me 350 450 seems pretty damn stiff, but I guess it's the norm.
  17. #177
    Irvine, CA
    i sent him 4 16" 450lb springs he has 8 springs.... i just did what rob anderson of deznation told me to order
  18. #178
    Irvine, CA
    ill get another 14" when i get the truck back
  19. #179
    Jun 2006
    Buellton, CA
    I told you what length to get, wasn't sure on weight. Either way, doesn't really matter now.
  20. #180
    Rob told you to order springs for a fox or king as mentioned above. Less bickering and most pics please.
  21. #181
    Irvine, CA
    have you got the bump cans up and mounted lets see a full bump pic?
  22. #182
    Irvine, CA
    btw i think the tires wont toe in so much once the correct spindle and hub is on.... right now thats a 5/8 stud rim sitting on std size studs.... but i could be wrong... its a beam truck lol.....
    josh i sent you8 straps right to dual front and rear? been so long since we bought them at the offroad swap meet
  23. #183
    Minot, North Dakota
    Are you refering to me? Being as my name is mike smith and that is how my shocks are set up on my truck lmao.
    By the way with my 14" kings, I have 14" 300 over a 16" 400.
  24. #184
    I'm a DAD and its RAD! flomaster's Avatar
    Jul 2003
    Chino Valley, Az
    DR stands for DRAMA!
    -=Jason=-
    97 4Runner SR5 4x4
    RIP Ranger 06/2003-10/2008
  25. #185
    Somis, CA
    Double crossed!!!!!!
    GFO Racing 1408
    Giant Motorsports
    Pure Power!
  26. #186
    Somis, CA
    Quote Originally Posted by 04yfzkid View Post
    Uhh no.. lol i meant the REAL Mike Smith... ya know the dude who builds trophy trucks and shocks for a little team called Terrible Herbst.
    no hard feelings on the name mike
    GFO Racing 1408
    Giant Motorsports
    Pure Power!
  27. #187
    Minot, North Dakota
    It's all good, I figured that is who you were talking about.
  28. #188
    Irvine, CA
    im not to worried on the springs, just getting fab work done the truck is probably going to go through a lot of shock changes once we start driving and tuning it.
    btw those are suspension spring specialist coils, so will see how they do
  29. #189
    OG Member fleshwound's Avatar
    Orange, CA
    sounds like things are getting sour between builder and customer?
  30. #190
    Jan 2009
    L.A.
    I'm still wondering how much farther the the bypass would to the wheel from the radius arm vs. the front of the beam? Doesn't really seem like much to me... guess I'll have to measure it on my truck.
  31. #191
    Irvine, CA
    things are not getting sour... just been a really long build and stressful on both sides for josh and I from acquiring parts to other set backs...but were still cool
  32. #192
    Orange, CA
    good to hear
  33. #193
    Denial is more than a river in Egypt.
  34. #194
    Threat Motorsports Threat Motorsports's Avatar
    I personally would just change out the top spring. Also dont be afraid to move the truck around just to double check your ride height. You wont be able to tell unless you do. You cant just put an I-beam truck on the ground and expect it to sit where it needs to after installing coilovers. Move that bitch forward and backwards a few times
  35. #195
    Jan 2009
    L.A.
    Quote Originally Posted by Threat Motorsports View Post
    What's your take on the shock placement Dizzzzave?
  36. #196
    Jun 2006
    Buellton, CA
    Thanks for the info Dave. You kit went on amazingly well and cycles awesome!
  37. #197
    Its fine how it is and is more then sufficient. If they were flip flopped its not going to make a "huge" difference. I would just leave it how it is.
    Thanks man!
  38. #198
    Irvine, CA
    Thanks man!
    dave i see from that pic you got the glassworks clip on.. do u have better pics or how you mounted the grill? also how did you connect the clip to the qtr panels.... im going to have to install the clip myself
  39. #199
    Irvine, CA
    still need info and help on how this glasswork clip mounts.... josh told me it will be ready for pickup at xmas, so that gives me a month to get a lot of work done. First thing will be getting everything powdercoated and getting rearend done with all the internals and driveshafts built.
    I need the nodular case, f.f. axles and brake parts and drive shaft
  40. #200
    Jun 2006
    Buellton, CA
    Cab welded up and upper links done..
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. Scott F
  1. Class 7200 BITD Class 7 SNORE Unlimited Ranger
    By rg1baja in forum We Trade?
    Last Post: 09-04-2010, 03:19 PM
  2. My Uncles Class 5 Unlimited
    By jeepspeed in forum Buggies
    Last Post: 12-18-2009, 11:55 AM
  3. Class 7 Unlimited
    By jeepgrand in forum Trucks & Buggies
    Last Post: 10-14-2009, 01:30 PM
  4. bitd 7 unlimited class ?
    By Good Knight Racing in forum General Off-road Talk
    Last Post: 07-14-2007, 02:02 PM
  5. Class 7 Unlimited
    By Class7 in forum Trucks & Buggies
    Last Post: 03-13-2007, 11:07 AM
