Page 9 of 13 FirstFirst ... 5678910111213 LastLast
Results 321 to 360 of 481
25Likes
Thread: Street Legal 1450 Build
  1. #321
    Senior Member azranger157's Avatar
    Jul 2008
    Surprise, AZ
    Its all good life is busy... we will get it done.
    Sent from my DROIDX using Tapatalk
  2. #322
    Vaya con Dios!! Aguilar's Avatar
    El Paso TX
    Quote Originally Posted by azranger157 View Post
    Started making the link tabs. Dropped the template off at the water jet place.
    And one more of the track width
    Very Frickin Awesome ..!!! anxious to keep seeing more .. hope this helps me !!
  3. #323
    Senior Member the willis's Avatar
    Surprise, AZ
    some progress
    Attached Thumbnails Attached Thumbnails johns-cage-3.gif   johns-cage-2.png   johns-cage-1.png
  4. #324
    Surprise, AZ
    one more
  5. #325
    Jul 2008
    Surprise, AZ
    Beat me to it...lol... but a few more...
  6. #326
    Jul 2008
    Surprise, AZ
    Picked up the lower link tabs from water jet place...
  7. #327
    Jul 2008
    Surprise, AZ
    Tacked on lower tabs. Now gotta make upper tabs and links!
  8. #328
    DOKS Race Support WanaBrunner's Avatar
    Peoria az
    what are you doing with the old btf links? and whats wrong with that rear setup that your building new? whats the plans exactly? im curious
  9. #329
    Jul 2008
    Surprise, AZ
    Im gonna run my BTF links still. Since im now doing the whole build and the front is 85" wide the back needed a 9in so picked up an econline rear so the back will be 82" wide.
  10. #330
    Jul 2008
    Surprise, AZ
    I think this is about where the tyranny will sit... gotta put the motor in so we can make sure cage and engine will be done properly without any interference!
  11. #331
    OnLy A cHaSe TrUcK CVP PRERUNNERS's Avatar
    Jun 2007
    CaLiFoRnIa
    You can push those tabs towards the end of the houseing ends for more clearence.. looking good by the way,cage too
    Brian Baker
  12. #332
    Jul 2008
    Surprise, AZ
    Was going to push them out but I didn't want to redo the frame mounts unless it needs to be done. But it will work where they are at im just gonna leave it like that.
  13. #333
    Jul 2008
    Surprise, AZ
    Been busy with life so here is a small update. Hope to get rolling on cage again soon. Made 3 of the upper 4 link tabs... obviously there is alot more plate to these. Just the start... and made plates for lower link tabs.
  14. #334
    whatever goofballracer's Avatar
    I've always put the bolt for the lower links centered of the axle for un wanted twisting of the axle more load on upper links
  15. #335
    Jul 2008
    Surprise, AZ
    Im confused do mean centered at off bottom or coming straight off front of housing?
  16. #336
    Centered of the axle tubes on the bottom straight up and down
  17. #337
    Jul 2008
    Surprise, AZ
    On the last rear I put them at a 15* angle off the bottom center these are just a little more still favoring the bottom. Trying to get more ground clearance on links.
  18. #338
    Jul 2008
    Surprise, AZ
    Some progress
  19. #339
    Jul 2008
    Surprise, AZ
  20. #340
    Jul 2008
    Surprise, AZ
    New whip!
  21. #341
    3 Seater Whoop Eater? murderedoutranger's Avatar
    glendale az
    wtf! when did you get that those are so badass
    Originally Posted by OC96Ranger The thing looked clean as a whistle but smelled like the deadliest catch.
  22. #342
    Jul 2008
    Surprise, AZ
    Ordered it two months ago and got it yesterday finally!
  23. #343
    glendale az
    what year is it brand new? i assume because you ordered it
  24. #344
    Jul 2008
    Surprise, AZ
    2012... took it off the lot with 6 miles on it!
  25. #345
    Senior Member paranoid56's Avatar
    San Diego, CA
    what no STI? car looks good. always nice to see a fellow suby owner
  26. #346
    Jul 2008
    Surprise, AZ
    Sti's are just plain expensive... had an evo in 05 and this would out perform that car and it was 10g's less... becoming an old man... wrx is my style....lol thanks man.. the car is awesome!
  27. #347
    Jul 2008
    Surprise, AZ
    Tuned Port Injection for the ranger!
  28. #348
    Jul 2008
    Surprise, AZ
    Got in the garage for a little bit today... got C pillar tacked in place on drivers side and lower rear tabs welded on. Just need to put top and bottom braces on another day when its cool.
  29. #349
    glendale az
    nice man keep the updates coming
  30. #350
    Likes to Party! esbyota's Avatar
    AZ
    quit trigger welding
    redsilvy and cllake like this.
    -Brad
    *NOCTURNAL INDUSTRIES* Your local AZ fabricator, PM me if you need any fab done from bumpers to full race truck builds
  31. #351
    Jul 2008
    Surprise, AZ
    Why?
  32. #352
    Jul 2008
    Surprise, AZ
    C pillar tacked on both sides now!
  33. #353
    Jul 2008
    Surprise, AZ
    Some more progress!
  34. #354
    Senior Member Ulloa's Performance's Avatar
    Yuma, AZ
    2
    everytime you trigger weld or whatever can cause a higher chance between each lil tack weld for a stress riser causing stuff to tear apart. versus a continuous weld is solid without a chance of fail, it gives a chance for the material to heat up for better fusion, and it looks cleaner without that brown caca ha. that would be my guess. truck is coming out pretty good! like the front end!
  35. #355
    Jul 2008
    Surprise, AZ
    Gotcha.... the guy doing 95% of my welding does continuous welding. Ive always trigger welded and have just made sure there are no air pockets between welds and made sure there was good penetration. But thanks for advice! I appreciate it!
  36. #356
    Jul 2008
    Surprise, AZ
    Mocking the upper 4 link bars
  37. #357
    Jul 2008
    Surprise, AZ
    Sold my current BTF links and Brandon is currently welding up my new BTF canoe style links. Thanks again to Brandon and Travis for supplying great products! Stand up guys all around!
  38. #358
    Im Tripping Out Man!!! 310kid187's Avatar
    Jan 2010
    310 PEDRO 310
    that is wrong sorry for putting you on blast, but continous vs. pulsing is no differnence in heating the matierial continous does look alot cleaner but if you know how to do pulse and make it clean it can turn out way better. And for the stress rising i have never heard of that maybe it could be from now joint the weld all the way together half my truck is pulse welded and half is continous.
    "DONUTS ARE AWESOME , THEY ARE DELICIOUS."
  39. #359
    Jul 2008
    Surprise, AZ
    Well im going to do continuous welds from here on out when I weld. Just gotta practice cuz like I said I have always trigger welded and have never had anything break from it so that's why I continued to do it.
  40. #360
    Jul 2008
    Surprise, AZ
    And as far as brown caca when trigger welding if you push the weld it doesn't turn out brown.
  1. new build street legal
    By hondaracer312314 in forum Buggies
    Last Post: 10-22-2009, 09:08 PM
  2. RANGER Prerunner CA PLATED STREET LEGAL RACE truck ****1450 class****
    By malicious mayhem in forum Trucks & Buggies
    Last Post: 06-12-2009, 02:07 PM
  3. street legal race truck, tacoma 1450
    By johnalagna in forum Trucks & Buggies
    Last Post: 06-01-2009, 09:47 AM
  4. Street / 1450 Legal Fuel Cell
    By ibanez270dx in forum Fab Shop
    Last Post: 03-10-2008, 07:40 PM
  5. 97' Ranger, Street legal 1450
    By tvoymang in forum Trucks & Buggies
    Last Post: 03-07-2008, 08:50 PM
