Page 3 of 30 FirstFirst 123456713 ... LastLast
Results 81 to 120 of 1184
26Likes
Thread: 93 Toyota 2wd first build
  1. #81
    DR Mod Travisfab's Avatar
    El Cajon
    Quote Originally Posted by rider4christ999 View Post
    lif i wrapped the front strap a few times around the frame/cage.
    There's your problem. Secure your truck with straps around the lower arms, and 2 around the rear end. Putting straps on the cage/bumper/frame are almost guaranteed to loosen up.
    FiberwerX - Summers Brothers - Total Chaos - Down South Motorsports - San Diego Carburetors - LC Engineering - iForce Graphics
  2. #82
    RACER slater1472's Avatar
    chino
    yep as soon as u hit a good mump or pot hole the suspension is gunna move and the strap will come right off. a good way is those trailer that have all the grooves on the floor so u can put a strap over each tire.
    SLATER RACING 1460---Drinking team with a racing problem.
    Quote Originally Posted by matt_helton View Post
    jeep cherokee?
    hmm id look into racing the mall crawler class. its a new class built just for your type of vehicle.....but be sure to carry your onboard welder cus those speed bumps can wreak havoc on your fail of a chassis or unibody as those in the know call it. good luck!
  3. #83
    Mega Member 93TCYOTA's Avatar
    AZ
    Quote Originally Posted by LTFJC View Post
    Nice truck man. Your build makes me want a truck to build up..Keep up the good work-
    thanks man!
    Gort Chop Shop-Total Chaos-AllPro-Fox-Corbeau
    http://www.dezertrangers.com/vb/dr-rides/93898.htm
  4. #84
    AZ
    never had an issue before lol but ill move them next time thats for sure
    http://www.dezertrangers.com/vb/showthread.php?t=93898
  5. #85
    AZ
    aside from all that
    clutch replacement is complete and works perfect. in two weeks truck will be going to the body shop for cab and fiberglass repair. in the mean time going to get the buckets in, and look for 4x4 spindles and rotors to convert the front to 6 lug.
  6. #86
    Senior Member 951yota's Avatar
    Murrieta
    - Anthony
    1996 T100 - 2000 Tundra
  7. #87
    Random and offensive slcpunk74's Avatar
    WB,UT
    I'm glad your truck is not hurt too bad. One thing to consider is that you need to make sure you cure the problem that made the trailer sway. Just make sure your brakes on the trailer work good and if it sways you can just manually slide the brake controller instead of using the vehicle brakes. Also make sure you have enough of the load on the front of the trailer.
    Sorry not trying to sound like an ass or like your dad or something but I just don't wanna see a thread about how a nice toyota got killed from a trailer malfunction.
  8. #88
    AZ
    Quote Originally Posted by slcpunk74 View Post
    me too! it wasnt on the usual trailer or behind the usual truck with the normal driver. which is what sucks. the trailer has gone into a sway many times with or without a load from which i later found out. trailer brakes went out which i didnt know. my truck was all the way forward with a quad behind it. plus the guy went to pass someone doing 85+ lol
    lets just say it wont be on that trailer or pulled by him again. only reason it went on the trailer in the first place is because the clutch fried. but hey i did learn that i need to strap it down a little better. im just happy its "minor" damage
  9. #89
    3 Seater Whoop Eater? murderedoutranger's Avatar
    glendale az
    one thing that know one has noticed is the guy who was pulling it was doing upwards of 90 to 95 mph from what josh has told me. you dont tow a trailer that fast espically with 4000 extra pounds, that is just common sense, that could have very well been the cause of the sway espically if a big gust of wind hit them.
  10. #90
    AZ
    Quote Originally Posted by murderedoutranger View Post
    exactly! thanks taylor
  11. #91
    AZ
    front steering is binding up. whats the best fix for this? king kong upgrade or ??
    its eating up some of the hardware on the front end
  12. #92
    chino
    king kong is a good design but i had problems with it bending so i ended up making my one out of solid stock.
    jeep cherokee?
  13. #93
    AZ
    the plan for the next 6 mos or so: as long as i continue to get the overtime ive been getting
    -upgraded front steering
    -4x4 spindles and rotors
    -air bumps and cans in the rear
    -finish rear cage
    -front bumper
  14. #94
    AZ
    finally some action shots and not being stuck or broke down lol
  15. #95
    WB,UT
    Sick! Why the name change?
  16. #96
    AZ
    fits better!
  17. #97
    Senior Member azranger157's Avatar
    Jul 2008
    Surprise, AZ
    sweet pics!!! good times!!
  18. #98
    ------------------------- Twisted Sid's Avatar
    Apple Valley
    if you are still having the steering bind issue, check your idler arm. that same thing was happening to my truck a few weeks ago when i swapped on a new idler arm because the old ones bushings were shot. the problem i found was on the new idler arm, where the hole for the centerlinks tie rod goes through, the angle was way off and it was causing the center link to be pushed back on the driverside. i changed back to the old idler arm and made some new bushings from some scrap aluminum spacers i had laying around and the binding problem was gone. i know the aluminum probably isnt ideal but it seems to be holding up for now and the steering is very smooth.
  19. #99
    AZ
    Quote Originally Posted by JDUBRANGER View Post
    yeah for sure! it was a blast
  20. #100
    AZ
    Quote Originally Posted by Twisted Sid View Post
    can u take some pics?
  21. #101
    AZ
    Quote Originally Posted by 93TCYOTA View Post
    -finish rear cage
    -front bumper
    now added to this list is bypasses along with the bumps in the rear!! too many rough times lately
  22. #102
    Apple Valley
    yeah i can, what part do you want a pic of?
  23. #103
    AZ
    the bushings u made and also if u have both idler arms pics of those so i can see the difference
  24. #104
    Apple Valley
    it might take a few days because it my DD but i will try.
  25. #105
    AZ
    thats fine no rush. thanks alot.
  26. #106
    one thing to conisder, if your not racing it you dont really need the 4x4 spindle strength. 2wd t100 spindles and brakes are an easier swap. only thing that is need is some custom steering arms on the spindle but i have some if you decide to go that route.
    there are pics of the t100 lift spindles i built in my build thread.
  27. #107
    AZ
    not planning on racing it but never know. i have seen the t100 spindles you did and they turned out good! whats easier about doing the t100 lift spindles?
  28. #108
    never built 4x4 ones or even looked at them up close, but the 2wd t100 ones look identical to the 2wd pickup spindles just alittle beefier. one thing i do know if that you dont have to deal with the big ass hole in the bottom of the spindle where the balljoint usually bolts on.
  29. #109
    Mega Member cllake's Avatar
    Goodyear, AZ
    Where were those pics taken? Looks like a fun spot.
  30. #110
    Jul 2008
    Surprise, AZ
    pics were done behind speedworld.. small little area... need a bigger area next time! pima and jomax for sure!
  31. #111
    Apple Valley
    well its not the best pics but it kind of show what i mean. see the different arm angle? i also just noticed that the one im not using arm seems to be about a 1/2'' longer too.
    and this is an extra spacer i have laying around but it just like the ones i used to make the bushings. i drilled out the middle hole to fit the OD of the idler arm shaft and then filed down the outside to fit into the body of the idler arm housing.
  32. #112
    WOW why is there such a difference in length??
  33. #113
    Apple Valley
    i dont know, my guess would be a cheap chinese knock off part but thats what was causing my steering to bind just like his is doing. it was scary as hell when i would turn a corner and the steering would lock up for a second.
  34. #114
    Montrose, Co.
    My old truck used to do that for about a week until I found out why. One of the bolts on the steering shaft came loose, where it bolts to that rubber thing, between the steering shaft and the steering box. When I would turn the truck the head of the loose bolt would hang up on the ridges on the steering box until I turned the wheel hard enough that the bolt slid back up and over the ridge, and would do the same thing on the next ridge.
  35. #115
    i dont get how his steering is hitting the a-arm bolt, my steering is no where near the bolts, it is at least an inch above them.
  36. #116
    AZ
    i dont think its the idler arm. if you look at the second pic you can see that the joint on my center link on the driver side is pulled towards the rear of the truck.
    looks as if the center link is bent back and down??
  37. #117
    they arent stright from the factory. let me see if i can find a good pic of mine.
  38. #118
    her you can see how high mine is compared to yours. it has custom ends on the center link but its in the stock location.
  39. #119
    AZ
    do u have a driver side pic where the tie rod connects to the center link so i can see where its at in comparison to my lower arm bolt
  40. #120
    very old pic but you can kinda see it
  1. toyota build-up
    By 2.9raceranger in forum Truck Talk
    Last Post: 05-29-2009, 01:07 PM
  2. 91 Toyota Front End Build
    By MAD MILLER in forum Fab Shop
    Last Post: 07-19-2008, 11:32 PM
  3. 92 toyota build
    By sdecurti in forum Fab Shop
    Last Post: 03-12-2008, 07:15 PM
  4. 94 Toyota build
    By xmikedentx in forum Fab Shop
    Last Post: 10-22-2007, 09:18 PM
  5. toyota 1450 build
    By fleshwound in forum Fab Shop
    Last Post: 06-19-2007, 08:29 AM
