Yep, got them. Thanks dude. I'll be in town and working on the truck tonight, tomorrow night, and all this weekend. School and work has been hectic so my mom gave me an extension.![]()
8/14/2010
==Only the ones like us that were there and lived the event will understand.==
Got it on all fours and rolling, so I washed it. Shocks are in the bypass location till I borrow an engine hoist to get the rear end high enough...
Got the spare tire mount welded up and in. Added some miter cut tubes under the tires to keep them from getting wedged in.
Then got the X behind the fuel cell tacked in:
8/14/2010
Really wish I would have kept those outlaws.....
Truck looks good
Wahoo a month later and Jake tacked in an X behind the fuel cell!!!!
looks good jake i got worried there for a minute thought you forgot about it. you going to the swapmeet?
Yeah, I'll be there starting saturday around noon with my tax return.
8/14/2010
what who are you going with im going to role out of here at about 3am on sunday morning
Travis and should be heading out nice and early
06 ranger, superstock lt arms, deavers, bad cage, bypasses, and tt bedsides, and blue bead locks to match the paint.
nice work man looks awesome
It's all about dirt miles...
DMC
Not really rolling out with anyone. The sooner I get there saturday the sooner I can start swooping on trailers as they pull in!
---------- Post added at 05:04 PM ---------- Previous post was at 05:03 PM ----------
Um, I mean... you're only allowed to start buying stuff sunday morning, so don't show up saturday around noon. :P
8/14/2010
haha ya i want to go but i have work till 5 and kristina has work till 8 maybe we will go and pull a all nighter. have any trips planed for the pig soon
Yeah, I'm rolling it in and out of the garage every weekend. At least till I get the fuel cell/pump/filter plumbed and wired. After that's done I'm going to do some sick ass 3 wheel donuts around the cul-de-sac
8/14/2010
dont forget the dirt road with all the bumps on it leading to the house
Just urban prerun that shit, speed bump jumping competition.
Not a lot of progress:
8/14/2010
Truck looks bad ass man
sent from my droid 2 using a syringe
finally man getting it done again. I love the build and glad is getting some more progress done to it!
looks good!
Hold My Stones..
Spaced tire holders for 35s.
Got all the diagonals fitted.
Swap meet finds: pro 4 custom sway bar and arms, brand new saw bumps, limit straps and other goodies.
8/14/2010
I hope those mounts for the 35s were made larger than the in punted tire.
We did that on mine, and once the tire is mounted it grows a good amount. Kind of leading to why mu tires are on the outside now.
Yeah, I left some extra room.![]()
8/14/2010
Broke my foot. FML. I'll be getting a real cast on once the swelling goes down.
8/14/2010
Dude that blows. At least you can still weld! Or maybe, is a cast flammable?
Who cares, welding blanket....
WTF did you do?
Was kickstarting a bike and the lever broke. My right foot crashed into the floor super hard and I was only wearing tennis shoes, so I broke the metatarsal (the bone my big toe connects to)
8/14/2010
you will thank me later. the progress of the truck is great.
WTT: My Deaver F-31's for Your G-50's
WTT: My Fox 2.0 x 8.5" for Your SAWS 2.0 x 12"
Itcher scratcher ^
Either that or he knocked some girl up. HAHAHHA
Na thats too messy stairs work just fine
Cast is off! Almost have the fuel cell all hooked up, but need wiring help. Chime in here.
Pulled the foam out of it and put the foam up for sale here, rebuilt all the fittings and sealed everything up with new gaskets/rubbers.
Completely welded the entire backhalf, built bump stop pads and bump stop mounts, and limit strap tabs, then welded all of that up.
Next is building a fuel cell hold down system and fender mounts, then painting the backhalf.
Revalved my SAW 16's with all 3 bleed screws, but the truck won't sit down, so I need to pull them back apart to remove one of the 3 screws... d'oh.
Here's my e2000 mounted where the stock fuel filter goes... Clips right into the stock fuel line. Generic fuel filter from Kragen makes sure no crap makes it into the pump:
And here's pictures of bump and droop. (limit straps not installed in these ones)
8/14/2010
Glad your making progress! My back half is finally taking shape!
The bleed screws don't determine ride height, they are for slow shaft speed.
If your truck sits high, either you have the wrong spring rate or your IFP has bottomed out.
But with all 3 bleed screws in and stiff stacks, the fluid won't flow through the piston.
8/14/2010
