Page 3 of 15 FirstFirst 123456713 ... LastLast
Results 81 to 120 of 566
7Likes
Thread: Arkansas Toyota
  1. #81
    zac
    zac is offline
    Senior Member zac's Avatar
    May 2006
    arkansas
    Quote Originally Posted by Adam Baker View Post
    Not a problm man,I am loving the cage looks reAlly good laid out real nice gona be sic once completed. Yea I was just looking at the pic of it bumped in the reAr and it would be diffrent to put bumps right there . Haha did you plan that or is that just the way it came together.?
    Once the rest of the rear half of the tubing is all added I will just run the bump off the side pretty much in line with that vertical tube. I think that is pretty similar to most others. And basically like this BMS truck.
    zac
  2. #82
    zac
    zac is offline
    May 2006
    arkansas
    I got a start on the shock mounts today. Still have alot to do but it took me forever to just get to cutting metal. The pictures are bad, hopefully I will get one side done tomorrow and get better pictures.
    zac
  3. #83
    winter sucks! il. prerunner's Avatar
    peoria Illinois
    sweet, are those foa bypass shocks?
  4. #84
    TOI
    TOI is offline
    Sep 2009
    atlanta, GA
    Quote Originally Posted by zac View Post
    Yeah about 8 hours.
    haha thats right i dont live in texas anymore. i really want to see this thing when its done
    -Ian
  5. #85
    zac
    zac is offline
    May 2006
    arkansas
    Quote Originally Posted by il. prerunner View Post
    Yeah, FOA bypass and c/o.
    zac
  6. #86
    zac
    zac is offline
    May 2006
    arkansas
    Quote Originally Posted by TOI View Post
    -Ian
    Maybe there's some where down towards you for me to bring it next year.
    zac
  7. #87
    OG Member Adam Baker's Avatar
    Jul 2008
    The whole!!
    Ok I see now haha looks bitchen man keep it up...goodluck man
    1996 ranger ext cab, Yep (project#3)
    Threatmotorsports
    Goodknightracing
    King shocks
    BakerMotorsports
  8. #88
    zac
    zac is offline
    May 2006
    arkansas
    Not much of an update but I welded up the pieces that I had on there. Going to try to cut out the rest of the plate work today because my goal is to have the shocks mounted this time next week.
    zac
  9. #89
    Senior Member mounty71's Avatar
    LB/Simi
    What's your plan for closing in the body where the shocks and mounts are?
    Quote Originally Posted by Jimmy Baja View Post
    ... this takes to much of my time, the internet is ignorant and you only lean how to push buttons...
  10. #90
    TOI
    TOI is offline
    Sep 2009
    atlanta, GA
    actually i keep hearing about some place in southern oklahoma that has some sand and what not. i never got around to going, but i plan on checking it out when i go back to texas this christmas.
  11. #91
    zac
    zac is offline
    May 2006
    arkansas
    It's called Little Sahara if we are talking about the same place, and I'm hoping to take it there when I get done. There's videos on youtube, it looks pretty fun for this area.
    zac
  12. #92
    zac
    zac is offline
    May 2006
    arkansas
    Quote Originally Posted by mounty71 View Post
    Not sure I know exactly what you mean but when the roof goes back on, it will clear everything thats on it now. And from the cross tube that would be under where a rear window would go and down, I will just be doing sheet metal, so the area around the shocks will just get boxed in and welded to the cab.
    zac
  13. #93
    zac
    zac is offline
    May 2006
    arkansas
    Last picture for a week. I got one more plate in.
    zac
  14. #94
    LB/Simi
    Looking at the first pic in post 82, your shocks go right through where the rear wall of the cab would be, so you're saying you will put sheet metal in front of the shocks, then bring it back to meet up with the back of the cab and the rear window? If you don't understand, don't worry about it, i'll just have to wait to see what you end up doing.
  15. #95
    OG Member fleshwound's Avatar
    Orange, CA
    how do u plan on drilling your holes for the shocks?
  16. #96
    zac
    zac is offline
    May 2006
    arkansas
    Oh ok, yeah that's what I meant. The sheet metal will just do what you said and kind of box in the the front of the coilover.
    zac
  17. #97
    zac
    zac is offline
    May 2006
    arkansas
    Quote Originally Posted by fleshwound View Post
    I was having problems holding everything and getting it lined up so I wanted to wait til it was all on and then put the shocks back at the right position and drill them. I'm planning to just start on the outside and go straight through both sides. I'm going to do a 3/4" hole and use 3/4-1/2 tube so I can align the shock in the middle and then weld the spacers. Hope it works out ok.
    zac
  18. #98
    TOI
    TOI is offline
    Sep 2009
    atlanta, GA
    yea thats the place, i never seem to remember that. it does look like fun.
  19. #99
    OG Member Dirt E Dreamer's Avatar
    the seven seas
    bad ass build this thing will kill
  20. #100
    Junior Member phansigar0614's Avatar
    Northwest Arkansas
    Nice Build... I am in early stages of an '86 Toyota extended cab build.
    Question... I have the stock 22re motor with the stock 4x4 trans and transfer case in right now. I am planning on eventually getting a V-8 with TH400 trans. You mentioned you moved the cab back 3". Was that just to move the firewall back and give room for the V-8 or is there something else.
    Also, is there any particular reason for setting the wheelbase to 120" as opposed to the stock 122"? Just wondering.
  21. #101
    zac
    zac is offline
    May 2006
    arkansas
    Quote Originally Posted by phansigar0614 View Post
    Moving the cab back will help with moving the engine back some, but I mostly did it for clearing the 35's at bump. The cab could've been clearanced for it but to make other things easier such as bypass mounting location and master cylinders, I went ahead and moved it back. As for the shortened wheelbase, it was a mistake, I had it in my head that 120" was stock so when I mocked up the links, that's where I set it. It would've been easy to change at that point but after reading and seeing other wheelbase numbers, I thought I would just leave it there and see how it worked out. Good luck with your build.
    zac
  22. #102
    Northwest Arkansas
    Thanks... I didn't think that with the front track width so wide that would be an issue, but I guess with 35" tires it makes sense.
    Arkansas is cool though, my wife has some family in Springdale and Harrison and I have a friend in Jonesboro.
  23. #103
    zac
    zac is offline
    May 2006
    arkansas
    The main problem with clearance is with the wheels turned.
    That's cool, I'm in Jonesboro right now, it's where I go to school. Who is the friend?
    zac
  24. #104
    Asshole/ helpful ovrebo1's Avatar
    Man I still can't believe you live in Arkansas. Looks really good
  25. #105
    zac
    zac is offline
    May 2006
    arkansas
    Haha, I've lived here all my life.
    zac
  26. #106
    Northwest Arkansas
    Vic Mastronardi. I was in the Navy with him and later in a metal band. He was our band manager. I think he works Civil Service or for the Corps of Engineers. I think he's doing stock or modified circle track racing with an old Mustang.
  27. #107
    zac
    zac is offline
    May 2006
    arkansas
    He probably races at Crowley's Ridge Raceway if he's from here, never heard the name though.
    zac
  28. #108
    zac
    zac is offline
    May 2006
    arkansas
    Finished the truck tonight, got the wooden bumpstops installed and the solid steel front suspension welded up........well at least it rolls in and out of the shop now. First time it's moved from the jack stands in over a year.
    zac
  29. #109
    zac
    zac is offline
    May 2006
    arkansas
    Those pictures look pretty bad, I'll take better ones tomorrow.
    zac
  30. #110
    SICKK camber brah..jk
    looks badass man, keep up the good work.
  31. #111
    zac
    zac is offline
    May 2006
    arkansas
    Haha it's hard to see but one of the lower control arms is held on with a long 3/8 extension, not the best for keeping alignment.
    zac
  32. #112
    Laguna Niguel
    thing looks mean as hell dude. keep it up cant wait to see it done
    Huge Thanks To Kevin at Good Knight Racing and Fabrication. Amazing Fabwork, Even More Amazing Price!
    Find another sport, your truck will never be finished.
  33. #113
    peoria Illinois
    Thumbs up
    good progress. It's got to feel good to get it rolling now. Is it going to be street leagal when it is done?
  34. #114
    zac
    zac is offline
    May 2006
    arkansas
    Quote Originally Posted by jeepspeed View Post
    Thanks.
    Yeah, since I don't have any way to haul it right now, I will have to drive it on the street. There is no inspection here so really anything is street legal.
    zac
  35. #115
    zac
    zac is offline
    May 2006
    arkansas
    Not much of an update but the bedsides came in today. Going to have to get new wheels soon because these are so deep that the bedsides need to go in about 6". I'm not even sure new wheels will fix that.
    zac
  36. #116
    Racer 85yota's Avatar
    SLO
    How wide is the rear of that truck. Looks really wide like 86ish.
  37. #117
    Senior Member bt-427's Avatar
    Sep 2009
    you can dove tail them and get a different offset
  38. #118
    zac
    zac is offline
    May 2006
    arkansas
    Quote Originally Posted by 85yota View Post
    not sure right now but the goal was 83" with new wheels
    zac
  39. #119
    zac
    zac is offline
    May 2006
    arkansas
    Finished up a little more on the rear of the cage today. Still have to add the lower part and then the bracing. Going to use 1.5" for the bracing.
    zac
  40. #120
    OnLy A cHaSe TrUcK CVP PRERUNNERS's Avatar
    Jun 2007
    CaLiFoRnIa
    looks badass
    Brian Baker
  1. Lexus / Toyota SC430 3UZ V8 and Toyota 1MZ 3.0 crate motors
    By PSmith in forum Parts & Accessories
    Last Post: 05-13-2008, 03:23 PM
  2. 2wd toyota toyota numbers
    By mr dank in forum Fab Shop
    Last Post: 12-14-2007, 10:19 PM
  3. need toyota spindles and stock toyota parts
    By mr dank in forum Wanted
    Last Post: 09-18-2007, 10:49 AM
