alright i live in the desert and i hate whoops and having 9 inches of travel soooo i either have to move out of the state or build a truck that can handle the desert floor and i chose :icon_welder:
i first pulled my doner beams out from underneath a 1993 expo. with 99000 mi on it leave it to me not to take any pix of it before any work was done on it but it looked stock so u get the picture lol my first job was to clean em and pull the diff.,axles,spindles,seals,brakes, off and to get started plating the bottom of them i chose 1/8 plate for this job because well I'm pretty sure I'm going to thank my self later for that :icon_idea:
then i figured i should cleean um up a bit and make em look purdy and give me one less excuse on why my welds look like shit
then i got me some cardbord and started playing around with som patterns for the remaning plating that needs to be done
then i turned the cardbord into metal magicaliy using cut off wheels and lots of them lol
them test fitted them and started bending and forming
today i just started dinking around with some radius arm idias lol u get the idia i think im going to use the one with less bend it puts less stress on the steel
did some cutting today got the driver side beam cleaned up and ready to be finished welded and also got to cutting on the beam for my 2.5 inch extension =]
any ways i got all of the plating done and also got the extension done 2.5 inches on each side =] there almost done just gotta add the truss and relocate the lower ball
not bad for a 18 yo in his garage eh?
o and by the way since I'm new please help me with my design im not pro and i love learning [looks like some should take a hint huh] i frequent therangerstation.com and can be found under the same user name but this is as far as i have gotten so far i look forward to the comments and opinons lol thanks a bunch =]
yea updated today i relocated the lower ball joint both out about an inch 1/4 and welded it up real good not bad for my 110v lincon i just turned up the heat and dowm the wire speed and slowed way down and pulled the putle along slowly lol and the last couple of pix im thinking about welding that on th add reenforcment to the lower ball i dont kno i looks a little wird but i does look like a strong what do u think
keep up the good work!
