Here are a couple pictures of my personal set.
Need to get my radius arms mocked up.
1987 BroncoIV. Runner in the works. '92 4.0L, A4LD, manual t-case. D44 TTB Long travel, 8.8 spooled rear axle with durango leaf springs, 5.13 gears. 35" ProComp muds.
My Truck Build on DR
1992 Slammed Ford Ranger DD.
Bump! Who would be interested in these brackets? I know I am! And I need two other people for these to be made again! Who's in?
im interested how much pm me if you can let me know ill get the payment ready
PM sent cdn runner
So there are 2 people interested. Where's the 3rd?!
I may have another guy interested from GFB.com.
You guys might be in luck!
But if more are interested, now is the time!
Awesome
Canadian_runner may have another guy. I'll wait for an email then I'll notify you guys.
Sounds like this is a go for 3 sets.
Order goes in Monday.
I want some!
SMT Racing-Co-Dog! 7100
Common sense isn't so common...
Here is a question for the guys setting up the d44 in their RBVs. I just got done with my d44 conversion in my 93 ranger. I originally was going to run the beams at the stock width but that seemed to put the pinion and driveshaft almost directly under the frame-rail. In the interest of maximizing bump travel and keeping clearances sane i ended up with the stock beams in the ranger pivot locations to tuck the track width in a bit.
Joel, now that you have yours mocked up, do you think that will be an issue?
93 Ranger 4.0 4wd - Under Construction -
During mock up I lifted the tire and beam up till the beam hit the frame and it does stuff the 35" tire up fairly high. Enough that turning a stuffed tire will not go lock to lock on the steering. The tire contacts the inner fender support. A small notch in the frame under the coil bucket would help alot with straight ahead bump travel. Remember that the brackets I have made offer a 1.5" lift (STX geometry) and that does help with bump travel, over the stock brackets. Air bumps would be a plus.. As I see it 20"+ travel up front is achievable before any bind is seen in the u-joints. The droop travel is impressive. "Pulls the Bitches!" as the Bro's would say.
I'm going to be notching my frame a bit to help and will add strength back in with my coil bucket design.
Order was put in today for 3 sets.
Sick can't wait to get them in the truck goin to try and get my axles today
Is there any one with a completed set up?
What is putting a hold on them?
I have no clue!
You guys seem fairly well versed in this ttb 44 conversion stuff so I hope you don't mind I thread jack for a moment. Is it correct to say that in order to fit a ttb 44 under the front of a 2nd gen ranger, you have to clearance the frame a little to clear for the pig? Also, is it fair to say you are increasing your trackwidth 8" overall going from a 35 to a 44? Thanks
-Dan
POLY GOAT
My Build: 1994 4x4 Ext Cab Abominable Snowman
"I like dirt so much, the first time I ever ate at Quiznos I ordered the BAJA CHICKEN!"
I moved out here to set the pace. Let's live, let's learn, let's race!
You don't need to clearance the frame for the Pig. The brackets drop everything down 1.5" so you gain a bit more uptravel. Bumpstops are recomended however. For the width is the reason for going D44. Saves from having to get all the fancy machining and custom parts needed for an extended D35 setup.
Wat coil springs are u looking at running
I'm going to be using the deaver 5.5" coils for mine.
I think I mitee go coilover haven't really decided yet have to when its together to figure out wat route I wana go
How are they coming?
I have them just need to box them up and ship them.
There has been more interest in these so if you want a set then find atleast 3 guys with cash in hand.
Interested in a set.
PM Sent
Kevin
Still interested but haven't heard back.
Anyone with info?
Kevin
I need a set very very soon. Are there any other guys willing to put their order in right now so that we can get our brackets made pronto? If I have to wait till later February, then I'll be forced to build them myself, and I'm not looking forward to that nightmare.
If you are ready, please PM Joel that you are interested NOW and we can all send money.
-Dan
POLY GOAT
I am very interested in a set as well. Pm me with pricing and all that good stuff...thanks
Will be ordering 4 sets Next week Tuesday. 2 sets already sold.
POLY GOAT
Parts ordered. Should have them at your door in about 3 weeks.
Three spoken for. One left.
Sent from Satan, using Tapatalk
