Results 1 to 10 of 10
    no me llames beaner DannyRobot's Avatar
    San Dizzle
    Default Ford 8.8 and 9 Axle Tube Diameter?
    Is it the same? What is the size?
    I want to order this:Deaver LT Spring Under WIY Kit, Partial [DEAV70] - $120.00
    Which I intend to run on my stock nissan axle with 3" OD Axle tubes.
    Thanks
    DR Mod oorracing's Avatar
    Jan 2006
    Long Beach Ca
    My 9" axle is 3.25" diameter... If that helps anything.
    "Better to stand there quietly and have people question if you're a fool than to open your mouth and remove all doubt."
    "Imagination is more important then knowledge. Knowledge is limited to what we already know and understand, Imagination is limitless."
    flux core champion 1981 kylesgorter's Avatar
    Nipomo, CA
    measure it!
    axle tube diameter varies upon model, type, year, etc. Theres more than a few 9" and 8.8" applications.
    3" is prob close though, if not its going to be bigger so maybe a little grinder work and you will be good to go.
    Classifieds Mod paranoid56's Avatar
    San Diego, CA
    measure what? did you even read his post? lol
    Quote Originally Posted by kylesgorter View Post
    measure it!
    Senior Member tacorunner87's Avatar
    Chino
    I think most 9" rearends are 3.25" I got a cad file from a friend to build u-bolt eliminator setup. The cad file was designed for a ford 9" and the hole for the tube was 3.25" Its also the same diameter as a toyota 8.4" rearend. Don't know if that helps any since your using it for a Nissan
    BUILD THREAD
    BBMoffroad.com
    Follow Us on Instagram! @BBM_OFFROAD
    San Dizzle
    ^ The input still helps. The primary concern for my question is U-bolt width. How bad can it be if I run those made for 3.25" width on my 3" width axle?
    Chino
    Thats roughly 1/8" on each side of the axle. I wouldnt recommend using 3.25" ubolts on a 3" housing. That makes it where the ubolt is only contacting 1 spot on the housing. where if you have the 3" ubolts its making contact on the top half of the housing.
    BUILD THREAD
    BBMoffroad.com
    San Dizzle
    Im going to call ruff stuff and see is they will sell me just the Ubolt plates.
    Chino
    TC sells them for 80 bucks. Im sure that if ruff stuff will sell them separate it will be a hell of a lot cheaper
    BUILD THREAD
    BBMoffroad.com
    Threat Motorsports Threat Motorsports's Avatar
    Quote Originally Posted by DannyRobot View Post
    Never run a 3.25 U-bolt on rearends with 3" axle tubes...
  1. bypass diameter
    By gotfmx1 in forum Truck Talk
    Last Post: 05-12-2013, 12:32 PM
  2. 99 ford expedition axle for ford ranger?
    By mxrider36 in forum Truck Talk
    Last Post: 10-29-2012, 08:55 PM
  3. Shock diameter comparison
    By Brandon_Charley in forum Truck Talk
    Last Post: 09-04-2007, 11:26 PM
  4. 7.5 axle with 4.10's and new ford lsd
    By noneed117 in forum Parts & Accessories
    Last Post: 01-18-2007, 09:42 AM
  5. big diameter brake line
    By dakotafroader in forum Truck Talk
    Last Post: 05-16-2004, 07:28 AM
