damn man that thing is fuckin rad!!!
Who built the exhaust?
That car is turning out bad ass Jason! Did you make those mufflers? Seems kinda restictive going in and out the same end?
62-67 bolt in DSE Full Floater.... with GMR PT-R shocks....
Uber!
jason
Pro-Touring Full Floater Expert!
so how much travel are you pullin? :P
OHHH MAN!! Do want!
jason had spin tech i believe build the mufflers, ts on one of the videos..... i really want one of those gmr fill caps for my rear end, but it is prob bigger then the kartek one?
www.fast-fabrication.com www.facebook.com/fast-fabrication
FAST Racing thanks FK Rod Ends, Yukon Gear, Glassworks Unlimited, Sway-A-Way, The GMR, JuanCo Performance Engineering, Raceline Wheels, General Tire, Icom America, Vision X, JBA Headers, MOMO, PRP Seats, Fragola Performance Systems, Optima Batteries, Powermaster, & Eibach Springs
GMR - C6 rear clip....
-GMR9 Housing
-GMR C6 rear hubs
-GMR PT-R shocks
-GMR Bulkhead
Jason
---------- Post added at 11:43 AM ---------- Previous post was at 11:42 AM ----------
I think they are the same size as the kartek ones. Im not sure because I never used the kartek large ones.
BAD
ASS
keep shredding
The faster you get into the sport, the faster you get out.
"You said rape twice.."
using stock control arms and spindles?
Looks awesome!!! My buddy just got his 66 nova back from Detroit Speed a couple weeks ago.
Giant Motorsports
Can you pm me a price for a 64 elco front end
Moving Forward.
Jason
...dayum... :O
0311 USMC 2/3 ISLAND WARRIORS (EAS)
6.5 Camburg Limo Beams & SAW's/Deavers with Dixon Bros bedcage & King double bypasses
Rear Sway bar setup...
Jason
That sway bar setup is bad ass. I always wondered why more people don't use stainless for axles and stuff. Love me that heat sig.
DONT STEAL
THE GOVERNMENT HATES COMPETITION
HNNNGGGGGGG!
beautiful
once you go black...
Jason
god damn, jason that is so beautiful... we definately need to get together about a center mount setup.
Looks awesome, can't wait to see this thing done.
But, since this is DR, I have to add IT'LL NEVER WORK! NO BYPASSES? WHY NOT UNIBALLS? WILL IT FIT A RANGER? SIKKKKKKK...
American Racing - Autofab - Bilstein - Clay Smith Engineering - GMR
Here is something the hot rod guys will like!
GMR9-TX Rear End Tooling System
Are you a little overwhelmed by the thought of installing your new GMR PT-R rear hubs? Are you worried that this is something above you skill set? Do you think there is a special science to getting everything to line up? Well, there is… but The GMR has everything figured out for you. If the Snouts are not properly welded into the housing then it will be susceptible to premature axle / gear wear along with tire issues due to mis-alignment of the snouts. For the first time ever The GMR9-TX Tooling System for welding in rear hub snouts is available to the home/ professional fabricator.
The solution to this dilemma is the new GMR9-TX Tooling System. This tooling system was purpose CAD designed and CNC constructed to ensure perfect fitment and alignment each and every time. Take all the guess work out of your install and perform your install just like the professionals at The GMR.
The starting point to any rear end fixture is the center section, the main body that bolts everything together. Typically builders will use an empty center section case with bushings for the alignment bar. This is a good way to set the ends, but not the best. The GMR has taken it a step further by custom CAD designing a fake center section just for snout end placement.
This center section is constructed of 6061 aluminum that is 2 inches thick. It is then machined to provide a perfectly flat surface to bolt your GMR9 housing face-plate too.
On the backside, the main faceplate stud holes are recessed into the fixture piece so that you can set the entire unit flat on a bench / table.
To locate the alignment bar, GMR machines two incredibly sturdy and beefy alignment bar retainers that are 1.25 inches thick.
Each alignment bar retainer is designed to slightly press fit into the tooling system and four recessed cap head bolts hold it in place. By having the retainers slightly press fit into the fixture main plate it ensures that the retainers are located in the perfect spot, then the bolts simply hold the retainers perfectly against the main tooling plate.
After the precision machine process all the parts then receive the same high quality HARD anodize that the GMR PT-R Hubs have. This will strengthen the part and keep it nice for years of abuse to come.
The workhorse of The GMR9-TX system is the alignment bar, so naturally it must be quality beyond industry standards. The GMR starts off with a 90 inch piece of 4130 solid bar stock that has a diameter of 1.75 inches. This piece of very strong material is then ran through a process called “center-less grinding” to get it perfectly straight and tolerance to exactly a hair under 1.56 inches (the ID of the GMR snouts).
The process of “center-less grinding” is simply a large grinding wheel backed up to a regulating wheel, the material is then slowly worked down to the specified tolerance and diameter. This process is very effective at keeping the overall length perfectly straight.
The key to a prefect alignment bar is a tight tolerance diameter while maintaining perfect straightness. To further enhance the professional quality of the alignment bar we then take the 90 inch piece of grinded material and cut 10 inches off each side. This was we are using the most accurate section of the alignment bar, the center. The result is the industries most accurate and straight alignment bar, period.
If you are at all familiar with The GMR then you know that we do not stop at simple, or standard, but rather blow right by it! Well, this next piece to the GMR9-TX system completely blows the competition out of the water!
Even though GMR precision machines the insides of the snouts and “center-less grinds” the alignment bar we wanted something even more accurate. Included in your GMR9-TX system is a large end cap alignment tool. This cylinder is the key to the precision behind the GMR9-TX system. It works by adding another very accurate surface to locate the GMR snouts relative to the gear-set in the housing.
This end cap slides over the alignment bar and snout entirely. IT then locates the snout via the most accurate machined surface on the snout, the bearing surfaces. It contacts both bearing surfaces with a slight slip fit then grabs the alignments bar just to the outside of the snout.
This system of alignment is hands down the best and most accurate system in the industry, it should not be a surprise that The GMR offers this system to complement your GMR PT-R hubs.
You will also notice that on the outside of the ends caps there is a series of tapped holes, this is for additional machined fixtures for caliper mounts. Again, something above and beyond already in the works here at The GMR…
This system is available to purchase for either personal use or professional fabrication facility use. Investment structure will be posted soon, please contact Jason@thegmr.com if you have any questions.
amazing work as always Jason cant wait to see this thing done
If you can't explain it simply, you don't understand it well enough - Albert Einstein
Very impressive product, everything looks top notch.
Looks so awesome Jason! Wish I wasnt a broke college studenthaha Keep up the amazing work and can't wait to see the car finished.
08 Ford Ranger, Burg 5.5 kit, fox 2.0 upgrade, F31s, simple bedcage with King smoothies
wait i saw that car on JCGrestorationandcustoms.com and they are claiming they did the car.so who built it? its werid because it was part of a forum that is "part of the g-machine network". That makes me think you guys built it.
Also, justin_mx, where do you go to school?
West Coast lites #949
Thanks to: OTD cyclesports, PWR radiator, Troy Lee, Alpinestar, and Tokyo Mods( for one bad-ass motor)
Diggin on these cars your doing these days Jason.
We just do complete rear ends, front hub packages, and brake setups. This car WAS having problems... until we upgraded it! GMR does not do any builds / fabrication anymore. Although, we do quite a bit of setups for the industries top builders, we are very busy just with rear end components right now.
one of the issues...
new GMR floater -
jason
