Set things up at full bump, like said before.
"I know not what weapons world war three will be fought with, but world war four will be fought with sticks and stones"
A. Einstein
Yes it does and the 4x4 spindles push the wheels out more as well. I was just posting that for reference.
My old truck ran 2.5" extended arms on BJs with stock 2wd spindles and I cleared 33x10.50s with a little fire wall massaging (a la a giant hammer). The wheels were not pushed forward at all either.
nothing wrong with it, but it really wouldnt be cost effective, which i think he was kinda going with this, as he wants to keep it balljoints. but yeah, yotas on beams are awesome!
I know this question probably negates being cost effective since its from a company, and I'll stop with the beam comments since I'm kinda jacking your thread, but how much does the Giant conversion kit cost.
How much metal is roughly needed to make,the lower arms? I need to get a plan together.
You guys are being little bitches about rubbing.
I clearance a Gen II Caddy kit to fit 315's (real 35's as those fags with Generals say lol) on a 4x4 Toyota with no lift spindle obviously
I had to do some cutting, hammering, and reshaping but it wasn't that bad only took a few hours per side.
yeah, but you actually have skill. something i dont have
Andrew, I will get a fucking 42 inch project to clear (sarcasm), it's just metal and fiberglass, just keep trimming and hammering till it clears. It can be done, I know it's possible.
yeah, you might want to use your brain and move the ECU out of the way before you start hammering.
a metal wheel barrow makes good metal for new wheel tubs, split it down the center and start fitting, should be able to do both sides with one cut down the middle, alot of fitting though.
I cost more and take 3 times as long, but i have a waiting list, so that must say something! heres a link vv
Dangerous Pirates / Johnny Branch Engineering and Design- 951 591 8982
Ranger build-http://www.dezertrangers.com/vb/dr-rides/129575.htm
Old pic of mine, it was still in progess, but it's a sheetmetal/fiberglass colaboration.
FiberwerX - Summers Brothers - Total Chaos - Down South Motorsports - San Diego Carburetors - LC Engineering - iForce Graphics
My truck build - BG Fabrication
http://www.dezertrangers.com/vb/dr-rides/96854.htm
"build a yota and then a ranger so you can use the yota to tow the ranger=D" -toyotabuilder
yeah, all that hassle, or no added time in adjusting the jigpoints and benefit from tires forward not just in clearance but weight balance.
Maybe not everyone wants to run tc mikey.
yes, you can clearance firewall till the cows come home, but at the sacrifice of legroom as well.
Independent Fabrication
indefab@yahoo.com
The first part, i don't know what you are trying to say.... but weight balance really? moving the tires forward 1.25" is going to change the weight balance? Put the pipe down dude, if you are that worried about weight balance you should start building F1 cars, not simple off road truck with stock pivot points....
With that said, anytime I've done my own suspension stuff and not just an install, the front tire gets pushed forward as much as possible (within reason) so I don't have to do as much clearing and trimming. My point was that the OP should be able to fit 33's in his truck with his current setup with firewall mods, that's it.
The second part, I never said anything about persuading people to run a TC kit, I was just saying that I've seen and personally make bigger tires fit on toyota cabs with long travel and no lift spindle.
The third part, Yes you will sacrifice cab space, but the space that's being sacrificed is dead space anyways, I mean who puts there foot on the out most part of the leg compartment? Your leg and knee would be rubbing on the door, window crank etc. The only bummer on a street legal truck with extensive firewall mods and stock interior is you need to remount the ECU, which isn't that big of a deal but it is something...
Yeah dude just clarifying with some facts here, don't take my stupid comments about the pipe stuff seriously by the way. Off to bed gnight!
actually arms around 6" wider than stock, converted to a 4wd 6lug spindle (For extra strength) comes out to 7.5" roughly, but if i where to run a 2wd spindle it'd be around 6"... both vert uniballs, and those where numbers with steering hooked up (1/8" bumpsteer through entire travel)
its roughly around 7.5" wider than stock (with 4wd spindle), i added a little length here a there until i got the geometry i was pleased with. also i noticed a type it was 20.25" i wrote 20.5" on accident (typo)
How much metal plate would it take to make the lowers around 4.5-5" over? Im trying to plan and price stuff out
My 5" over fits in a 48x26 sheet per arm.
The frame overlays and arm tabs are seperate tho.
