Results 1 to 15 of 15
Thread: 94 Toyota build
    Greasy Fingernails xmikedentx's Avatar
    Jan 2007
    Mentone
    I started this build the day before the superbowl, and a month later I can finally post some pics...
    What I've done.. 62" Deaver's, Total chaos, baja bushings, king double bypasses, the bump stops are on my workbench right now... Gen II up front, lower uniball, with bypasses soon...
    First of all thanks to jesse@tlt and matt for posting up their trucks so i could get some ideas going, and thanks to Danny who has helped me work on this thing..
    [IMG]http://thumb15.webshots.net/t....MG]
    Get all you oil through me! Special DR pricing on anything AmsOil.
    Jan 2007
    Mentone
    Jan 2007
    Mentone
    Jan 2007
    Mentone
    Jan 2007
    Mentone
    53" eye to eye, thanks so f-ing much matt
    for the starting point
    Jan 2007
    Mentone
    ride height (kind of). With no weight it is sitting at 11" up, and 5.5" down
    Jan 2007
    Mentone
    inside shackle gusset. It goes back so far on the inside because there was a hole and butt joint where my new frame plate joined the original frame.
    Jan 2007
    Mentone
    front hanger. Thanks to the guys at Kartek for their tricks on how to place it perfectly.
    Jan 2007
    Mentone
    top shock mount.
    Jan 2007
    Mentone
    Prepping the old housing, I threw in a lock right locker, which works great for how easy it was to install.
    Jan 2007
    Mentone
    Bedsides installed with dzus tabs. 3 on the top rail on the inside of the bed and 2 on the bottoms.
    Jan 2007
    Mentone
    Lower mounts, which you can barely see (sorry) and the 3/4" that supports the main 1" square tubing that the bedside mounts to.
    Jan 2007
    Mentone
    This is how the main hoop attaches to the frame. 3/16" plate was welded on the sides, and then the .120 1 3/4 was welded to that. The x-bracing was welded to the top of the frame to distribute the stress across two sides (4 points) of the frame, rather than one attachment point.
    Jan 2007
    Mentone
    Mounted the Hi-lift today.....
    old matt_helton's Avatar
    Yorba Linda, CA
    nice job man. looks awesome.
  1. toyota build-up
    By 2.9raceranger in forum Truck Talk
    Last Post: 05-29-2009, 01:07 PM
  2. toyota 1450 build
    By fleshwound in forum Fab Shop
    Last Post: 06-19-2007, 08:29 AM
  3. toyota pickup best build option
    By toyotatruck333 in forum Truck Talk
    Last Post: 10-07-2006, 12:22 AM
  4. Blitzkrieg Toyota front end build
    By Speedmetal in forum Fab Shop
    Last Post: 03-13-2006, 10:49 AM
  5. TOYOTA T100 Build
    By ampperf in forum Fab Shop
    Last Post: 01-10-2006, 08:19 PM
