Page 1 of 5 12345 LastLast
Results 1 to 40 of 165
Thread: Small block chevy in ranger
    V BLOCK FAB COASTAL RACING's Avatar
    Feb 2009
    NIPOMO CALI
    Default Small block chevy in ranger
    I am getting ready to put a 500hp sbc in my single cab ranger and i would like to see some pix of similar builds (chevy in ranger) that is. Thanks dr
    i need 83 thru 92 sb bedsides and 87 style front fenders! pm me! also need 2 15x12 or 14 5 on 4.5 wheels
    Racer Vinnie909's Avatar
    Yucaipa
    heres a couple, ill get better shots when i get home this is what i had laying around, the first one is with the old gaint enging cage
    Attached Thumbnails Attached Thumbnails dsc00367.jpg   dsc00511.jpg   dsc00505.jpg
    Yucaipa
    its also pushed back 12 inchs
    Feb 2009
    NIPOMO CALI
    Quote Originally Posted by vinnie909 View Post
    thanks alot man. Exactly what i was looking for. I would really like to see where your headers landed next to your steering box if you dont mind sending more pix. But ya thanks for those piks your truck is fuckin sik i cant wait to run my sbc!
    Senior Member bikeriderdown's Avatar
    ontario
    im trying to doing the same swap soon hahaha
    Senior Member AzJake's Avatar
    Wickenburg Arizona
    Wickenburg Arizona
    Pushed back 3 - 4 " headers are going to be FUN! I think I can modify some of Summits stainless block huggers.
    Wickenburg Arizona
    rained on rusty hack fab bajascott's Avatar
    oregon,sur
    im diggin the prerunner jeep!!
    Its all fun and games untill someone shits in the pool
    already miss the desert
    Wickenburg Arizona
    I knew that would come up sooner or later. It's the four year old's, I swear.
    my room mate has one of those. 4lo locked front and rear is a lot of fun, even in a toy.
    Feb 2009
    NIPOMO CALI
    Default sweet
    Quote Originally Posted by AzJake View Post
    lookin good. with the steering shaft hooked to the column is like an inch or 2 away from your exhaust ports? and what tranny u goin with?
    Feb 2009
    NIPOMO CALI
    these piks are great if anyone has more post them up please! especially VINNIE909
    Senior Member bmxking454's Avatar
    Oceano, CA
    Quote Originally Posted by COASTALRACING View Post
    i knew you couldn't not do a SBC swap in that thing!! ha ha is it going to sip from the bottle? haha JK JK
    Wickenburg Arizona
    I will have to modify the second exhaust tube on blockhugger headers. The steering rod will have to have 2 joints to offset away from the engine. I'm going to run a custom column so I have some room to move it around on that side also. I went with a t400. I'm going to run a relatively stock trans. I will change the valvebody and run a good converter. This engine is around 400 HP so It should be fine. It may be easier in the long run to push the engine farther back (complete custom firewall). I'm running a third seat so I can't afford to lose the leg room by pushing it back any more.
    Feb 2009
    NIPOMO CALI
    Quote Originally Posted by bmxking454 View Post
    i knew you couldn't not do a sbc swap in that thing!! Ha ha is it going to sip from the bottle? Haha jk jk
    haha not rite away but ya nos will most likely end up on it too. The motor is real hard runnin 350 tho its one of our old race engines. The fucked part is runnin 110 gets exspensive:d
    Feb 2009
    NIPOMO CALI
    Quote Originally Posted by azjake View Post
    i will have to modify the second exhaust tube on blockhugger headers. The steering rod will have to have 2 joints to offset away from the engine. I'm going to run a custom column so i have some room to move it around on that side also. I went with a t400. I'm going to run a relatively stock trans. I will change the valvebody and run a good converter. This engine is around 400 hp so it should be fine. It may be easier in the long run to push the engine farther back (complete custom firewall). I'm running a third seat so i can't afford to lose the leg room by pushing it back any more.
    ya the more pix and info you guys put up on this chevy into ranger is very useful.
    Member Mad Dog's Avatar
    Nov 2007
    Klamath Falls,Oregon
    Quote Originally Posted by Vinnie909 View Post
    Have you had your truck on the scales? How is the rear percentage?
    Feb 2009
    NIPOMO CALI
    the 350 chevy doesnt weigh much more than the factory ford v6
    Feb 2009
    NIPOMO CALI
    well ive got mine set in. not sure if i should try diff sets of headers? or just pay the fuckin 1100$ to have them made? any custom header piks on v8 rangers?
    Senior Member orchidrider's Avatar
    apple valley
    bump for header and motor mount pics, just pulled my 2.3 and have a 350 waiting to drop in.
    trophy ranger in the works
    Feb 2009
    NIPOMO CALI
    Thumbs up Here it is now
    022.jpg:d
    Feb 2009
    NIPOMO CALI
    Lol this is the mock up engine! Dont let it fool u
    busy 1450ranger's Avatar
    yucaipa
    The header / steering shaft / steering box clearance will be your toughest bet.
    Feb 2009
    NIPOMO CALI
    Quote Originally Posted by 1450ranger View Post
    the header / steering shaft / steering box clearance will be your toughest bet.
    ya forsure the stock style exhaust manifolds fit easy so do block hugger headers but i really need full length long tube headers for the engine ill be running 13.5 to 1 compression and huge solid lift cam, but im still goin for it!:d
    Feb 2009
    NIPOMO CALI
    anyone heard of a weld up fender well header kit for sbc's? ive seen regular weld up kits but no fender well style
    let me see what i can dig up... and yes it is very tight on the #7 cyl... almost have to go straight up at the flange
    Feb 2005
    Whittier, CA
    i personally have a 94 ranger single cab that i put an sbc in. i completely cut the whole firewall and trans tunnel out and pushed the motor back about 14" from stock. the only headers off the shelf that would work with the least amount of frame modification are the block huggers. the only thing i say is u better put a really good tranny behind that motor u will be surprised how fast the trans takes a shit. go with like a culhane valve body not some shitty tci or b&m deal those suck.
    Sick Gnarticulation!!!
    Feb 2009
    NIPOMO CALI
    Nice fender well exit style headers!! I like that alot, u build them from a kit? Or...
    Feb 2009
    NIPOMO CALI
    I have the engine and trans done comletly solid all the best parts i could afford lol. My grandpa builds race transmissions so no problem there, i appreciate the pix/advise its really helpin, keep it comin
    apple valley
    what kinda modification would u have to do to the block huggers? or even for the stock manifolds?
    Racer 85yota's Avatar
    speedway has fenderwell header kits, was gonna do it on my toyota but decided to run block huggers and build a better engine cage. Is S&G doing the fab on your truck or you just his friend.
    no just a set of long tubes, took me about 2hrs to cut and tack everything .. not to bad of a mission
    Feb 2009
    NIPOMO CALI
    Default s&g
    Quote Originally Posted by 85yota View Post
    sean at s&g did my engine cage and plated my beams/radius arms, i have been working for him for about 3 months now. when we get some time we will start my bed cage and bumpers hopefully soon! im still fukin with the motor swap and trans mount tho so it will be after i have that all in place. speedway motors? dont they have like 10 catalogs? if its them which 1 are the headers in?
    Wickenburg Arizona
    Not to hijack, but how do you determine the diameter of the headers. My engine is 400+ HP with a safe shift point of 6800 rpms.
    theres alot of factors that come into play when chosing header size not just hp... a nice set of 1 5/8 will help your motor an the botom end torque where as 1 7/8 will better help on the top end... either way you not running a considerable amount of power and id personally run the 1 5/8 to keep a little back pressure on the motor!!!!
    hope this helps
    hope this helps
  1. small block in chevy s10
    By DezertKing01 in forum Truck Talk
    Last Post: 02-23-2009, 03:27 PM
  2. toyota+small block chevy=tight fit
    By superyoder85 in forum Fab Shop
    Last Post: 01-23-2008, 06:23 PM
  3. Rangers w/ Chevy small block v8's
    By linked4dezert in forum Truck Talk
    Last Post: 12-31-2007, 03:45 PM
  4. Small Block Chevy 350 v8
    By SCORE30 in forum Parts & Accessories
    Last Post: 08-06-2007, 07:37 PM
  5. Small block chevy
    By xxempiremotorsportsxx in forum Wanted
    Last Post: 07-19-2005, 09:25 PM
