Results 1 to 24 of 24
Thread: 5.0 motor swap
    IF IT FEELS GOOD FUCK IT! azpimpdaddy's Avatar
    Phoenix,az
    Default 5.0 motor swap
    Ok, i'm sure this has been asked 1000 times but i'm asking anyway.
    I have a 99 ford ranger 2wd with a 2.5 4banger, what year 5.0 motor can i use and still pass emissions (az) and what is all needed to be done to do this?
    Banned
    Sep 2009
    highdezert CA,
    in california the motor has to be newer than the truck and have all the smog equipment
    Henderson, nv
    get a painless 5.0 wiring kit, motor mounts hardest part is gonna be exhust
    Phoenix,az
    Ok, sounds too easy! lol
    OG Member charlie_brown's Avatar
    Aug 2004
    Waiting for my pass to heaven
    Quote Originally Posted by speed king View Post
    close, it can be the same year or newer.
    Quote Originally Posted by White94OneFiDDy View Post
    the exhaust wont be to hard. there are several companies out there that make swap kits for this. advance adapter is one. not sure on the quality.
    jegs sells a kit also. they all have the header manifolds for sale. there is a certain year headers that bolt right up. it depends on the motor mounts you get.
    when i was looking into it, i got a how to Manuel from james duff that had a bunch of useful things in it. not sure if they still have it. get a remote oil filter.
    i went with the 4.0 SOHC swap. i think being in cali that it would be easier to get through the ref.
    now some one hire me or refer me to your HR so I can get this motor swap done.
    charlie brown goes to baja.
    Quote from Ted Nugent: As long as the idiots don’t like you, it proves you are not an idiot.
    my 4.0 sohc motor swap. http://www.dezertrangers.com/vb/dr-rides/119213.htm
    Phoenix,az
    Charlie, How is the power on the 4.0?
    Aug 2004
    Quote Originally Posted by azpimpdaddy View Post
    i have not done it yet. the guy helping me (using his tools/garage since all my stuff is in storage) wife is pregnant now and they just move into there new house last year. so he has all kinds of home projects to do before the baby comes and my motor swap was not one of them.
    i found another place but it is to close to baja to get it all done so the week after baja it is on.
    yours is a 99. not sure when they stop making the 302 so you may be to late. is 99 a OBII? if so and if you cant do the 302 then the SOHC would be a good option for you.
    Aug 2004
    just did a search and it looks like 95 was the last year for a 5.0. if anybody knows different??
    if that is true, you might have to go with the 4.6 v8. i have heard of a few in rangers but don’t know much about them. have one in my Tbird. smooth power and runs nice. it is a lot wider and that can create some problems with suspension and headers. to do a legal easy swap for more power, its looking like the 4.0 SOHC.
    Check out rangerstation. They may have more info.
    Feb 2009
    Quote Originally Posted by charlie_brown View Post
    Sorry for bringing this back, but...
    I just picked up a 1980 Bronco with a re-man 302 in it from 2003... I'm going to be putting it in a 85 Ranger.
    Would they consider the age of the motor or the truck that it was installed in?
    Camp Pendleton, CA
    http://www.rangerpowersports.com/for...splay.php?f=12
    check that site out, they have a ton of useful info on v8 swaps, the 4.6 isnt quite as easy a swap as the 5.0 is from what ive read.
    OG Member f150drivingkido's Avatar
    Nov 2006
    El Centro
    1980 with a 2003 302? What's the firing order on the 302? Is it an h.o. I just ask because you wouldn't be able to run the 302 out of anything newer then 1994 in a 1980 without changing the computer on the bronco or changing the cam on the 302 because after 1994 the firing order changed from what the 1980 bronco would have if it originally came with a 302
    Someday I'll have the money to do the things I want to do...
    Feb 2009
    Quote Originally Posted by f150drivingkido View Post
    Sorry, it is a 2003 crate 302 non-efi (no computer)
    the broncos original motor went in 03 and this was installed as a brand new unit with 0 miles. Technically speaking this is an old style 302 mfg. in 2003.
    Hope that makes more sense.
    Aug 2004
    you may want to call a ref. on this one.
    my take from talking to others about this is: they stopped putting 5.0 in mustangs in about 97 i think. they were still putting them in explores for a few years longer. your donor vehicle has to be the same year or newer. you have to put all the new motor stuff in your truck. just because it is a 03 create motor, the ref is going to look at it as a 1980 motor with a rebuild of 2003.
    Aug 2004
    like on my swap from a 88 2.9 to a 01 4.0 SOHC. i got the dash, computer, wiring, cats, trans, gauge cluster from the donor truck and putting it in my truck. since i have a fuel cell, i got a small 10 gal stock 2nd tank out of a ranger that i will have to hook up to get it through the smog ref.
    this way when the ref smog test my truck or any motor swap car, it needs to pass the test for the year make and model for where the motor came from.
    Custom User Title AAAlovesME's Avatar
    wow really a smog ref wont let you pass with a fuel cell? Has to be all stock components huh?
    Quote Originally Posted by Bajayota View Post
    The day there is a DR rave is the last day i visit the web site...
    Mega Member Sandfreek's Avatar
    Laveen, AZ
    Quote Originally Posted by AAAlovesME View Post
    You need all of the stock equipment from the vehicle you're taking stuff from.
    California Engine Swap Guidelines - Import Tuner Magazine (Has to do with a Civic, but I'm 99% sure it still applies to trucks.)
    You'd Bacon your Lettuce all over her Tomatoes??
    I've heard of a lot of fetishes but never a sammich fetish.
    Quote Originally Posted by 94exploder View Post
    Big deal? All that means is she couldn't tell you how awful you were due to lack of comparable situations.
    Senior Member RCMracer74's Avatar
    Escondido
    302 went in f1s til 96, 97 new gen and they started using the modulars,
    expo 302s up til like 00 or 01
    idk about broncos or cars
    but the casting no on the block is under the intake manifold so nobody would kno what block ur using, they would only go off what their comp says when they plug into the ecu
    any more info is appreciated, i have 2 302s in my garage, one is going in my ranger haha
    Member ford rules's Avatar
    Jul 2008
    V-8 Tech - Ford Ranger Forum - The Ultimate Ford Ranger Resource
    I would read through this forum theres more then enough info to do a 5.0 swap in here, and alot of the things in this thread are wrong just fyi.
    1995 Ford Ranger 5.0 EFI Built 4R70W NP 205 D-44 Solid Axle 14 Bolt 4.88's Detroit's
    Build in Progress 1997 Ford Ranger 350 SBC Turbo 350 Tranny 9'' J Beams
    Quote Originally Posted by ford rules View Post
    Care to elaborate oh wise one?
    Jul 2008
    Im not trying to argue or start a fight here there is alot of good tech in that fiorum read it and i wont have to elaborate.
    Alot has to do with what year 5.0 you use. I used a 96 in my 5.0 because it was basically a plug and play thing only had to change the charging wiring harness for the 5.0 alt.
    You would have to research but im pretty sure if you have a 99 ranger you should use the new 5.0 out of an expo its more of a plug and play thing. Headers are only 2 options torque monsters.$700 or stock manifolds you can use regular 5.0 headers cause of the gt40-p heads reangled plugs and tight fit in the a-arm ranger.
    Motor mounts i believe once again you can use a stock mount out of either the expo or ranger.
    Your prollay gonna want to swap in a bigger radiator dont buy the james duff swap in one there junk.
    I dont think you will need the oil filter relocation but not 100% sure.
    I think 01 was the last year for the 5.0 expos there the easiest to swap in as they have a shorter front pulley and water pump assembly than other 5.0's there just packaged tighter.
    What tranny are you going to run and computer?
    Drive shafts will need to be shortened i believe.
    You may need to swap the column for the PATS and use the keys from the expo.
    Like i said i did my research for the older body style rangers 95-97 OBD II trucks, From what i recall from reading and researching most of this is correct but read through that forums you will have plenty of info. Rwenzing is a member on there he knows his shit on the newer truck 5.0 swaps he has on with a 5.0 in it.
    I'm seeing a lot of "I think" "I believe" "I'm pretty sure" in your post, don't come on here saying people are wrong when you don't actually know what you're talking about.
    Jul 2008
    Read the thread alot of the shit i said is a lot more better info then the other stuff in the thread. I dont see you bringing any info either.
    Just completed a 1997 Explorer 5.0 to 1991 Ranger swap relatively easy swap. You need to use at least a 99 engine and all its smog but will be simple as that year Ranger has the same frame up front as the Explorer I suggest buying a donor car or you will be held hostage for small parts. Get past smog then modify.
    Alpineblue
    Jul 2008
    Quote Originally Posted by Alpineblue View Post
    The newer ranger swaps are a little more dificult from what i have read and yes get the whole donor vehicle if possible
  1. motor swap 2.9
    By MOBSTER in forum General Off-road Talk
    Last Post: 09-04-2009, 10:11 AM
  2. Motor Swap or Truck Swap
    By Good4You in forum Truck Talk
    Last Post: 07-19-2009, 09:59 AM
  3. Motor swap q's. 5.3 out of an 07 into an 03
    By HALF ASS EXPLORER in forum Truck Talk
    Last Post: 01-22-2009, 02:30 PM
  4. motor swap q's
    By jonnyhoyboy in forum Truck Talk
    Last Post: 01-09-2007, 12:53 AM
  5. MOTOR SWAP
    By crivera in forum Fab Shop
    Last Post: 10-29-2006, 02:20 PM
