Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 81
4Likes
Thread: How strong are the D44 or D50 TTB's?
    space cadet mjlogan's Avatar
    upland, ca
    i see you already hit up the thread on pirate. your sig quote looks familiar haha.
    When going 35 spline throughout the front, keep in mind you are gona have to run a locker or spider gears in the d50 that will accept 35 spline shafts. From my research, you can put 35 spline side gears in a D50 ARB. The dana 50 hubs are identical to dana 60 stuff. Spindles are nearly identical and considered to be interchangeable. Basically, from the spindles out, you are already good to go, minus the fact that you'll need to run 60 stubs to get 35 spline shafts and 60 u joints. Everything inboard of the spindles, as you know, is gona be cu$tom. To be honest with you, i'd give the stock stuff a try before dumping a ton of money into aftermarket shafts. Unless you are beating on this thing with a locker up front in the rocks in low range. If you need it, i've got a spare 60 30 spline outer that you can have if you want to check clearances on stuff, cause they might be a tight fit on the 50 knuckles.
    Tcase should be a BW1356 and plenty strong. 10.25 rear should also- they are just expensive to build with regards to aftermarket support. Gears/lockers are bank and not as plentiful as more common rearends. If you keep it, convert it to disc brakes to shed a good hundred pounds
    Minot, North Dakota
    Just bumping this to see if anyone has a new info on d60 stuff in a d50 TTB set up?
    Racer 85yota's Avatar
    SLO
    Not sure this was posted yet but he has probably;y the strongest set of D50 TTB's out there. so read up and see if you really want to spend that much money on them.
    YJ-based, "go-fast" Juggy build - Pirate4x4.Com Bulletin Board
    Minot, North Dakota
    No that hasen't been posted yet on here tommy. I have a thread on pirate and everyone told me to look into his thread. I read every post and even sent him a PM. He told me what to do, but the problem is his set up is a little different. He changed the pivot points, so he can run a larger center u-joint where as a stock truck wont have that much room. I am waiting for him to finish it so I can see how it does . Thanks for the link though, will make it easier then having to find it on pirate every time lol
    Senior Member mconcha's Avatar
    Caarlsbag/Escondildo
    His steering setup is begging to join the crappy fab thread.
    Minot, North Dakota
    Lol that is for sure. Still don't understand why he didn't want to do swing steering.
    Minot, North Dakota
    I am going to pretty much copy corey's build of his xj. Going to do a d60 kingpin spindle with d60 stub axles with 1480 u-joints and longer arp studs, then up to custom axles and probably a custom slip with 35 spline axles going into the pumpkin. Hopefully a 1480 u-joint at the center between the diff and the slip, but clearance is very tight there. Thinking about custom d60 kingpins because they are about $250 each online.
    Not sure what I am going to in the diff to accept the 35 spline axles, and weather or not to do a air locker or what. Also since I need longer studs, should I worry about going 5/8th studs on an 8 lug truck
  8. #48
    SLO
    He didn't do a vertical swing steering because at bump it's too close to the ground and would get hit and bent. I asked the same thing, he buys almost all parts through us so I've seen the build since day 1./
  9. #49
    Minot, North Dakota
    Oh that makes sense. Doesn't seem like it would hang down too much, but it's his choice. Yeah I saw everything he bought was from you guys, pretty rad.
  10. #50
    Minot, North Dakota
    Trying to pull up the diagrams, but a lot of these websites are blocked on this government computer. Wondering if I go with a 35spline stub shaft, not sure what kind of drive plate, or hub assembly I can run that will leave with being able to lock and unluck the hubs still. Maybe I just don't understand the concept of how 4x4 works yet to be asking this question lol
  11. #51
    Minot, North Dakota
    Being knew to all this 4x stuff, I really didn't know what I was saying above on stuff. I have got everything figured out except if I need to worry about converting over to 35 spline going into the pumpkin / slip.
  12. #52
    Member Wildhair225's Avatar
    Thanks for this thread I learned alot. I'm starting the front end of my truck this month its a 96 4dr 4x4 PSD with the d50 the truck weighs in at 6900 lbs can't wait to hit a speed bump faster than a crawl.
  13. #53
    Minot, North Dakota
    Quote Originally Posted by Wildhair225 View Post
    Ahh fuck man building the same truck as me lol
  14. #54
    Do you have a build thread on your truck, or some pics your could post?
  15. #55
    Minot, North Dakota
    Haha I still haven't started yet because I am lacking funds. Been researching the hell out of it and pretty much found out everything I need to know except for how to run 35 spline going into the pumpkin.
    Pic in my av is pretty much how the truck still looks. I am just waiting on my injectors (damn $1700) and some other little motor stuff, then I can start buying my parts to build the suspension and such. You should build the truck though, it will be a good all around truck in my opinion
  16. #56
    I think it will be a great truck to build, I have the front and rear bumpers done now i'm waiting on funds for the shocks so i can tear it down, i'll try to get some pics of it tonight if its not dark when I get home.
  17. #57
    Minot, North Dakota
    I thought you said you were going to get pictures last night, you lied . What kind of bumpers do ya have?
  18. #58
    OSHA approved JakeP's Avatar
    Start a build thread Mike! You won't do it!
    8/14/2010
    ==Only the ones like us that were there and lived the event will understand.==
  19. #59
    Minot, North Dakota
    Quote Originally Posted by JakeP View Post
    Haha I already started a thread, bought some stock TTB brackets, and got some radius arm brackets
    Project Black Smoke Project BLK SMK
  20. #60
    Crappy phone pics but here ya go.
  21. #61
    Minot, North Dakota
    Thats a nice looking truck man. What size tubing is the front bumper?
  22. #62
    Thanks, its 2" everthing on it will be.
  23. #63
    Senior Member big-d's Avatar
    Oct 2006
    Glendale, AZ
    I am gathering parts to build a hybrid d44/d50 ttb right now. I have read that you can just swap the 50's lower BJ onto the 44's housing because the upper BJ is the same, also that you have to change the whole end because the spacing is different??? Which one is correct? I don't have the D50 yet to use for measurements (I am looking for a good deal on one with 4.10 gears and a 93-97 Sterling 10.25 with factory Ls & 4.10's)
    I wonder if using plated D44 housings (not D44HD) and D44 pivot brackets with d50 or 60 ends, axle shafts and diff would give you the strength you need and have enough room between the pivot points to use the 1480 joint you were wanting??
    Speed costs money, Now just how fast do you want to go?
  24. #64
    Who's ShiTalKing? partybarge_pilot's Avatar
    Leucadia
    Quote Originally Posted by big-d View Post
    You have to swap the whole end, there isn't enough room on the D44 for the bigger joint and the BJ spacing is much larger on the D50. Just choping out the bottom one you will end up with the axle in the wrong spot.
    Quote Originally Posted by mconcha View Post
    The only thing Ive heard about the D50's is that one beam(cant remember if its driver or passenger side) is drastically shorter than the other. Obviously the D44's are different lengths as well, but are close enough to allow for good travel #'s.
    D50's are actually equal length beams. They are just both short unlike the D44 where the passenger side is the short one. The passenger side brackets are in almost the same place on both. The D-sides are the ones that are way different.
    Monkey fab
    Quote Originally Posted by mcdirt@1s1k View Post
    also what makes him a "pro" because hes done it for 25 yrs? well fuck me ive been taking shits for 25 yrs! does that mean im a pro shitter? fuck no i still get the beer shits!
  25. #65
    Minot, North Dakota
    The more I was looking into I came up with this. D60 king pin spindle with a spacer (because the king pin d60 runs a bolt on caliper mount where as the d50 is built into the spindle), d60 35 spline stub shafts which run a bigger u-joint ( forgot the size off the top of my head) and custom built axles. I would leave the third stock performance wise with just gears and a traction device. I have yet to find anything that accepts 35 spline for a d50 center section. The guy on pirate had a modified d44 lock built for his d50 center section, and had his housing drilled out to run a different seal for the larger axles. I don't remember exactly because it sounded like too much work for me. With a diesel I was just planning on having 5 tunes on my chip (since it's just a turn of a knob for a different tune) and keep one low power for crawling. That is if I ever go through with this.
  26. #66
    Minot, North Dakota
    SO bumping this back up. Since they are equal length, is there any problem with extended them by the bushing to make them equal length that mount on the outside of the frame as well as extending them near the end of the beam for track width? Also I were to go down this path, could I offset the mounts to allow for more room in between the beams (to allow for a larger center u-joint) with out messing up the geometry / side to side wheel base?
    Lastly, whats wrong with, on an open diff front end, running drive plates on the street, when the transfer case is in 2wd?
  27. #67
    Jan 2012
    Might as well share some of my on-going project here. Havent made a build thread on this site, but since people are interested, might as well clarify some things for people. You can leave the top ball joint on a 44 arm and use the 50 lower ball joint. I know because I have done it. I will post all the details later in a build thread, but for now, these pics will have to hold you guys over. These are 44 arms with 50 lower ball joints, 50 knuckles, axleshafts and 50 pig.
    PASSENGER: 44 top, 50 bottom
    DRIVER: 44 top, 50 bottom
    distance between ball joint sockets, 44 top, 50 bottom
    will be plated later
    Like I said, still lots to be done, and will post all details later in a thread.
    DirtFiend602 likes this.
  28. #68
    Leucadia
    Nice!
    Now go get an newer F150 front diff and pop it in there. Instant 40# weight savings........
    DuctTapeRacing likes this.
    Monkey fab
  29. #69
    Jan 2012
    Quote Originally Posted by partybarge_pilot View Post
    Nice!
    I tossed the 44 pig when I snagged the 44 beams. I want the cast 50 housing. This rig will be beat on, and if the 30 spline stuff gives me trouble, I can mod the 50 $hit to squeeze in 35 spline and 60 stuff.
  30. #70
    Minot, North Dakota
    Quote Originally Posted by -Nathan- View Post
    I must say those hybrid beams are looking really good man! Have any tips on places to look for 35 spline d60 stuff inside the d50 carrier? So far the I haven't found any info?
  31. #71
    KBL
    KBL is offline
    Member KBL's Avatar
    May 2011
    Way cool! I have both D44 and D50 beams sitting around waiting for something to happen.
    Questions:
    Are you building this hybrid to get the longer D44 driver's-side housing with the strength of the D50 knuckles?
    Are you using 8-lug wheels, or converting to the 6-on-6-1/2 TT pattern?
  32. #72
    Jan 2012
    I am using the 44 arms for the length, will be using 8 lug wheels (beadlocks), and 50 outers for strength (and ability to upgrade to 60 stuff). Also, I have a set of Copykat's conversion brackets, so the 44 arms will bolt in.
  33. #73
    VillanMotorSports Copykat's Avatar
    Manitoba, Khan-a-dah
    Nice!
    1987 BroncoIV. Runner in the works. '92 4.0L, A4LD, manual t-case. D44 TTB Long travel, 8.8 spooled rear axle with durango leaf springs, 5.13 gears. 35" ProComp muds.
    My Truck Build on DR
    1992 Slammed Ford Ranger DD.
  34. #74
    Senior Member murphco's Avatar
    Oct 2003
    az
    pb i like the saving weight comment but we always snagged the 50 pivot axles for the ability to swap the axle by removing the 3 bolts and pulling it out unlike most ttb 44's that need to have the center section removed so the c clip can be pulled for axle removal.what style are you going for with this,im asking because im tossing the idea around of using the 97 and newer center section with a shortened passenger side axle and housing for my a armed expy,in stock length they break anyways and id like to play with axle length and position of the diff to attempt a narrow as possible center without breaking the bank.hopefully i wont have to bug you with all the plunging cv and hub q&a i had a few months ago.
  35. #75
    Leucadia
    Not all D44's are C-clipped, early units have a 3 bolt flange. I only run these.
    As for the 8.8, You've seen them break an axle? I have seen several exploded inner CV's. Even 930's let go before anything in the diff, hence the 934 upgrade for the JD kits. Still have yet to see a anything in the diff let go even on a supercharged truck running 37's. Now the vac-lock hubs, those are questionable. Warn makes and upgrade for those I believe.
    Monkey fab
  36. #76
    Jan 2012
    04yfzkid and Copykat like this.
  37. #77
    Fuckin sweet!!! Get them rad arms built dude!
  38. #78
    Garage Fab ranger#1's Avatar
    lake havasu city ,AZ
    good lord man i didnt know these were going to be going on a ranger that shits beef cake thats like wayyyyy strong
    build thread http://www.dezertrangers.com/vb/dr-rides/130636.htm my goal: fully huckable DD
  39. #79
    DR Maitre'D DirtFiend602's Avatar
    Scottsdale
    subbed!
    DSR, Nocturnal Fabrication, Gort Chop Shop.
    Instructions? Wtf are those?
    Things women use when they pretend they're men?
  40. #80
    Old Skool Ford Freak JusSumGuoy's Avatar
    Costa Mesa, CA
    Subscribing as I'm another secret d50 lover. LOVE the pics Nathan. One of these days I'll finish some of my current BS & get onto my sweet d50 truck idea.
    I am a tool whore... and
    73-79 Ford fiberglass fenders mold is done! FINALLY some larger flare glass for these trucks!!!
    http://s453.photobucket.com/albums/q...nders%2073-79/
  1. Replies: 3
    Last Post: 02-04-2010, 12:11 AM
  2. dana 35 TTB's
    By NODNARB in forum Stock & OEM Parts
    Last Post: 09-23-2009, 09:44 AM
  3. how strong is the 4.0
    By phinney21 in forum Truck Talk
    Last Post: 10-17-2006, 02:06 PM
  4. how strong?
    By tomynee in forum Truck Talk
    Last Post: 11-02-2003, 10:46 PM
