Results 1 to 12 of 12
    Just Run Them Over. lostbehindwords's Avatar
    Oct 2005
    Orange, Ca
    Default 97 dodge dakota 4x4 with f250 3/4 ton axles
    so i have a dakota with solid front and rear axles off a 250 and my power steering pump went out so i replaced it. I'm running 37" tires with a 10 inch lift, now my rack and pinion are out plus i believe i need a new steering/gear box? my ball joints are fine just had them checked, any ideas if i should buy maybe a after market box and pinion+pump? please give me some info on what to do or what site i can order from so i'm not going through theses yearly...thanks
    Just Run Them Over Already, Shit.
    I Love (.)(.)'s Josh40601's Avatar
    Podunk, KY
    so you have rack and pinion and are running a straight axle?
    Ranger Build Thread -> http://www.dezertrangers.com/vb/dr-rides/125855.htm
    Depression is merely anger without enthusiasm
    Oct 2006
    GNARNIA
    Quote Originally Posted by Josh40601 View Post
    wouldnt/shouldnt he be running a pitman arm?
    Podunk, KY
    Quote Originally Posted by ilovesoccermoms View Post
    exactly. I'm trying to figure out what the hell is going on... Like, a steering box AND rack and pinion on a SAS? Doesn't make sense to me... I have been wrong before though so that's why I asked...
    That guy with the dakota wastedyouth02's Avatar
    Prescott Valley/ san diego/ afghanistan
    now my rack and pinion are out plus i believe i need a new steering/gear box?...... i think he just divided by 0
    I've seen SAS trucks before with the rack mounted on the axle but I wouldn't do it that way. When I did mine I just used a box from a '91 Explorer. Like you guys already said, he wouldn't have both.
    How about some pictures so we can see what you have.
    Oct 2005
    Orange, Ca
    Alright I guess I was wrong. The rack and pinion are gone but heres whats happening. I'll be driving and my wheels will randomly sharp turn and its scares the shit out of me almost got into a couple accidents. I'm pretty sure i need a new steering gear box because my wheels are harder than shit to turn even after replacing the power steering pump. Any ideas?
    Podunk, KY
    sounds like bump steer to me. happens when the track rod angle is different than the drag link. You also might have a power steering problem (fluid, leak, pump no good) Very rarely do steering boxes go bad, but like they said before, throw up some pics and lets figure this shit out
    Does the steering wheel turn when this happens? If the steering wheel turns with the wheels then most likely your alignment is off but that wouldn't explain why it's hard to turn. Was it always hard to turn or is this something it just started doing? Also, what steering box did you use and what pump?
    Mall Crawler 1969f100's Avatar
    Folsom
    pics??
    Quote Originally Posted by Dirt E Dreamer View Post
    whats the point of building it to loose money [selling] its like dating a hot girl and bailing when shes ready to fuck
    What's a desert? BrokeCuzWheelin's Avatar
    Milwaukee, WI
    Death wobble
    Probably bad trackbar bushings/heims.
    Oct 2005
    Orange, Ca
    I'll get some pics up as soon as possible just been pouring rain like no other.
  1. dodge dakota lt kit
    By csalazar in forum Truck Talk
    Last Post: 02-02-2009, 09:09 PM
  2. 97-03 dodge dakota. help plz
    By MR.SIMS in forum Truck Talk
    Last Post: 11-11-2008, 10:56 AM
  3. 99 dodge dakota
    By ericc in forum Trucks & Buggies
    Last Post: 04-29-2007, 03:31 AM
  4. Dodge Dakota
    By Rangersaurus in forum Truck Talk
    Last Post: 03-19-2007, 09:04 PM
  5. dodge dakota 2wd
    By joshhomeslice in forum Truck Talk
    Last Post: 09-29-2004, 10:07 PM
