i wasnt able to make it out but the owner took it to Gorman this morning. Fab wise everything worked perfectly and he absolutely loved it, said hes never owned anything he could go so fast through the whoops in...lol.
Appears that the new master cylinder or a fitting is leaking fluid all over in the engine compartment and the rear end is making some bad noises. from the description on the phone it sounds like bad wheel bearings. It is also getting a little hotter then i would like, trans and motor both peaked at 220ish while running a 180 thermostat.
