i was told to pre/post heat mine.
going to make a build thread?
It's pretty hard to beat a D35 axle with D44 outers. I think your trying to get too technical with trying to go equal length. I can uderstand the whole being different thing.
You could build a widened D35 with D44 outers fairly easy using the tech these guys have shown you.
My D35/D44 setup rocked. and has never given me a lick of trouble.
Or you can just buy a set of D44 TTB conversion brackets from me and bolt on a D44. Get the benifit of 66" track width, using off the shelf parts.
1987 BroncoIV. Runner in the works. '92 4.0L, A4LD, manual t-case. D44 TTB Long travel, 8.8 spooled rear axle with durango leaf springs, 5.13 gears. 35" ProComp muds.
My Truck Build on DR
1992 Slammed Ford Ranger DD.
I see your point and I am thinking about ditching the equal length. I will see when I get started the mock up.
The truck it is going on is a 99 and has no crossmember to start with so I cannot bolt on the conversion setup. I am aiming for a 62-64" track width. The drivers side 44 beam is perfect for that just the passenger side needs mods either extended and in front of the the diff or shortened to go behind the diff.
Copykat hold off on pulling that third member if you haven't already.
I just contacted Moser Engineering and they will shorten and respline for $55 per shaft.
This build has been a disaster. I have modified the passenger side beam and made pivot brackets but I don't know that I can go any further with my lack of funds. I need to extend the steering arm on the TTB knuckles. All the research I have done says it cannot be done safely welding on the castings. So I would need totally fabricated knuckles unless anyone can tell me how to get over this hurdle.
So Copykat I might be going to unequal length after all.
You can weld the the uprights just fine, I have done it many times. There are many race broncos out there with plates welded to the back side of the upright to keep the spindle snout from ripping out. Not to mention all the double sheared steering.
Grind it clean, pre-heat and use stainless rod. Let cool slowly. Easy money.
http://www.mohavebattery.com/ - Dealer of: Rigid Industries, Method Wheels, Amsoil, Optima, & Odyssey.
I may experiment with this but for now I have to get this truck on the road so I am going back to the unequal length setup. I have to buy another passenger side beam since I have modified the one I have. The question I have now is why doesn't anyone use pivot joints like this one 2.0" Ballistic Joint instead of uniballs. I don't what uniballs because I live in Indiana and we have a lot of salt on the roads in the winter. I don't want to wash the bottom of the truck every time I drive it.
That joint it way too wide for beam pivots in my opinion. I can barely get a 1" narrow uniball cup to clear through travel.
That joint has a 1/2 ball so it's weaker and is made out of the same material as a uniball... how would it tolerate salt/corrosion better?
Leaf spring bushings turned so that the centerline of the beam bushing is the same as the centerline of the dad arm bushing.
I just put some joints like that on my truck you have to widen the mount, but if you do it away from the axle it works great I live in central Utah where there is tons of snow and salt on the roads and didn't like the thought of a heim you can't grease if I get a sec ill post some pics.
I used a jonny joint with a 9/16 bolt.
Like the doctor said when you were born "Its going to get ugly"
The mounts I built have a two inch spacing so I could fit the ballistic parts if I ever decided to up grade to them. I don't know if it is worth it to do right now. My other explorer has factory bushings and they don't cause any restriction in movement with 14" of travel. So is it worth spending $80 on?
it sounds like youre on a tight budget. why do you need to upgrade now? the truck doesnt even move.. id put the money towards something else.
