Results 1 to 9 of 9
    Oct 2011
    Default 94 ranger 4x4 ?????
    I have a 94 xlt 4x4 4.0 when I got the truck the the 4x4 shift control module was removed. I was wondering if there was a way to engage the 4x4 manually without any long term or short term damage. If so could someone guide me through the process.
    Senior Member 93 4by's Avatar
    LBC
    remove the shift motor from the back of the transfer case. there will be a little triangle shaped shaft sticking out. it will probably be pointed at 2wd, turn it until it points to 4wd. it is easier to do with the tranny in neutral. once the shift motor is off it is as simple as crawling underneath the truck with some pliers to shift it. Not ideal, but i lived with it like this in my truck for a few years. lol
    93 Ranger 4.0 4wd - Under Construction -
    Oct 2011
    Thx.I know this is a dumb question,but just making sure. I just have to lock the hubs when i want to engage and disengage correct?
    LBC
    Yes. Do you have manual or automatic hubs?
    Oct 2011
    manual hubs automatic trans.
    Oct 2011
    I bought the transfer case control module but they sent the wrong one. I need the one that has aluminum fins on it. It looks kind of like an amplifier.Did you ever replace yours? If so where did you get the part?
    I LIKE DIRT 1nbred RANGER's Avatar
    menifee
    id say a salvage yard, unless you order through a parts supplier but it might be pricey
    1990 ford f-350 460, 4wd, 4 door, longbed
    1990 ford ranger 4.0, 2wd, giant beams, giant 64
    1991 ford ranger 4.0, 4wd, bone stock
    1970 kaiser m818 (big green)
    1966 m105a2 (1 1/2 ton trailer)
    Nov 2005
    so cal
    isnt there a write up or some kit to convert the auto TC to manual? if so anyone got a link?
    jump it, race it but dont cruise it
    Member big_o7's Avatar
    Aug 2004
    Topeka Kansas
    Easily Convert Your Electric BorgWarner Transfer Case to Manual Operation! | The Shiftster
    used it for a year, pretty good, easy and bomb proof, $60 cant beat it
    Go BIG, Go Hard, Go FORD.....
    94 4.0 Ford Ranger 4x4
