Results 1 to 3 of 3
    Nov 2011
    Default 03 Silverado Long travel CV
    I have a 2003 Chevy Silverado 2500HD gas(6L) 4x4 and I am designing long travel suspension for it. I am going to make custom spindles and make it about 4 inches wider per side in the front than stock and run 35" tires.
    Im using the stock front differential.
    I am going to run 934 plunging CV inner joints and either going with a 934 non plunging outer or a stock Chevy HD outer cv joint.
    If I go with a stock HD outer joint does anyone know some that makes some axles with 33 (934cv) splines on one side and 41 (HD cv) on the other?
    If I go with 934 non plunging outer joint does anyone know where I can get a 33 spline stub axle that would fit in a chevy HD hub and bolt up to a 934 cv joint?
    I am planning on machining a adapter to bolt the 934 inner cv joint to the differential stock stub axles but if anyone knows where I can that let me know.
    Let me know if anyone has a better or easier solution for front drive axles to hook up to a chevy 2500HD with long travel suspension.
    Dec 2011
    Fort Meade, SD
    Looks like a call to RCV Performance might be your best bet.
    Oct 2011
    Did you find anything out on this? Cause I'm in the process on putting a long travel kit on my 1500 4x4 and I'm planning on running the 934 immersed with the factory 2500 outers. My friend said he knows a shop that will custom make the axels for us but if anybody specializes in those, that would be better.
    Sent from my SAMSUNG-SGH-I997 using Tapatalk
  1. Silverado Long Travel
    By Kevoni in forum Truck Talk
    Last Post: 03-23-2010, 06:47 AM
  2. Silverado ***long travel kit***
    By Johnh133 in forum Parts & Accessories
    Last Post: 02-23-2010, 09:55 AM
  3. 97 Long Travel Silverado Must GO
    By smoothlikebutta in forum Trucks & Buggies
    Last Post: 08-27-2008, 04:25 PM
  4. 99-06 Silverado CST Long Travel
    By ET Chaser in forum Parts & Accessories
    Last Post: 05-07-2008, 09:10 PM
  5. silverado long travel
    By XJRAYXJ in forum Truck Talk
    Last Post: 09-25-2006, 11:08 PM
