Results 1 to 27 of 27
3Likes
  • 1 Post By crazyracer
  • 1 Post By Tchajagos
  • 1 Post By yellowranger1
Thread: 4x4 travel questions
    Member desertdog's Avatar
    Dec 2011
    Default 4x4 travel questions
    im recently new to the 4x4 scene, im just came up on a ford bronco, i want long travel both front and rear but right now it has the 4x4 beam set up, are you able to get thge same ammount of travel out of 4x4, if not( which im assuminng not) whats the difference between a 2wd beam set up and 4x4 beam set up?
    DR Mod Travisfab's Avatar
    El Cajon
    You can get in the high teens with extended beams, or low teens with stock width beams.
    Mega Member tvoymang's Avatar
    Oct 2005
    IE
    It is very possible to make a 4x4 bronco work well offroad. There are several build threads on here for "go fast" broncos =)
    a lion never loses sleep over the opinions of sheep
    Oct 2005
    IE
    DR Photog DezertWife Photography's Avatar
    Nov 2009
    Carpinteria, CA
    Quote Originally Posted by desertdog View Post
    other then the fact that there is a axle going through the middle of them not much different then a unequal length i beam. you are mostly limited by u joint bind on the center u joint, you can get a lot more then the teens on stock width if you do some work with the u-joints/ pivots to maximize uptravel. ive got a stock width d44 in my truck and its cycling 24in of travel in 4x4.
    Your BRRRs have to shift...you can just start your BRRRs in fifth gear. -Thomas
    http://dezertwifephotography.zenfolio.com
    El Cajon
    24 inches with both beams drooped at the same time with the axles in?
    Nov 2009
    Carpinteria, CA
    yes its strapped at 24.5in of travel stock width d44 cut/turned and uniballed (14up 10.5 droop) with over 50k miles on the truck too.
    I may not know, teach me crazyracer's Avatar
    Pacific Beach, CA
    ^He cheats
    RCV's!
    "Tres Cuatros"
    POLY GOATMy Build: 1994 4x4 Ext Cab Abominable Snowman
    If everything is under control, you're not going fast enough - Mario Andretti
    Good drivers have dead flies on the side windows - Walter Röhrl
    Eddie V. yellowranger1's Avatar
    Sylmar/Northridge, Ca.
    I think the RCV's didn't net much of a difference in travel did they Thomas? I thought they were more for reliability/longevity sake. Go long travel TTB! Sometimes I wish I had!
    Mega Member simon5ay5's Avatar
    santa barbara/ Carp
    Quote Originally Posted by yellowranger1 View Post
    I used to strap it at 22.5 to make the u joints last longer but it cleared when I cycled 24 just didn't last all that long before breaking the u joint or axle.
    Racer sirhk100's Avatar
    Feb 2003
    Do you by chance have that same picture with the passenger side at full bump, driver at full droop?
    Khris
    Nov 2009
    Carpinteria, CA
    No i dont.
    Black Booger Fabrication nooch450's Avatar
    Mar 2012
    New Jersey
    Quote Originally Posted by DezertWife Photography View Post
    Do you guys have stock pivot brackets?
    If not people who can't afford those axle shafts can run 2"ish drop brackets to help the u joint angles.
    Im cycling 17ish with stock width D35 beams and drop brackets. Ill get final #s when I reassemble the truck.
    santa barbara/ Carp
    Quote Originally Posted by nooch450 View Post
    2.5in lift built into the brackets
    Mar 2012
    New Jersey
    Quote Originally Posted by simon5ay5 View Post
    Sweet setup, you must have 6"? lift total with those brackets and cut and turn D44 considering the D44 is already a 2inch ish lift compared to a D35 if I remember correctly.
    Thats how you got that sick amount of up travel lol.
    Apr 2012
    fairfield/vacaville
    i was under the impression that dana 44's suffered from a lack of bump due to the 3rd member being bigger than the 35's and it makes contact with the frame quickly.
    did you notch your frame to help you get that number of bump dezertwife?
    Mar 2012
    New Jersey
    Quote Originally Posted by derrik View Post
    The D44 only seems to limit people a little bit. But with the 2.5" drop brackets he is running it allows for a bit more bump over say copykats 2" drop brackets. Maybe an inch or so? Hard to say tho. And I think they may be running on 37s.
    Edit: copycats brackets are 1.5" drop so that extra inch on his drop brackets will likely allow another 1.5"-2" bump travel without diff/frame clearance issues.
    Nov 2009
    Carpinteria, CA
    No frame notch but what we did was, once the brackets were built we flipped the frame over (with front susp on) and marked out where the beam touched the frame. we then took a torch and heated the frame and hammered on where it hit, cycled it a bunch of times to make sure it was clear. we basically just pushed the frame around the pumkin so everything hit at the same time instead of the pumkins housing hitting before the axle tube.
    its still on 35s right now cause i love the Muds, ill be switching up to 37s soon though. because of how much bump travel i have the beam gets really close to the ground and ive actually dented my beam from bottoming out on a rock. the 37s will help keep the beam farther away from the ground. in this pic u can actually see my skidplate touching the ground..
    Senior Member Tchajagos's Avatar
    Dat up travel.
    McQueens new glass says you can stuff 39" tires.
    santa barbara/ Carp
    Quote Originally Posted by Tchajagos View Post
    Dat up travel.
    Stock ball joints says I can't lol wouldn't trust past 37s. even with 37s I'll be replacing them twice as often
    Dat up travel.
    That's the F150 glass you're talking about... The ranger glass definitely wont clear tires that big.
    Mar 2012
    New Jersey
    Did you consider the metal on metal ball joints?
    Or maybe even custom beam ends with 2 king pins?
    Solution to this? Lets come up with something! Uniballs? In sure our collective minds would be able to fix this issue. Haha.
    Yes the new f150/bronco glass.
    Nov 2009
    Carpinteria, CA
    no point. the ball joints should be fine with 37s. ill just have to replace them sooner. last time i replaced them was about 40k miles ago. so not like im having issues with them.
    here is the truck tucking some 37s..
    Apr 2012
    fairfield/vacaville
    yah that glass looks amazing,im in love with that truck.thanks for the info.
    santa barbara/ Carp
    Quote Originally Posted by sirhk100 View Post
    i do now.
  1. 82 c10 long travel questions
    By jkwalkercchs in forum Fab Shop
    Last Post: 09-21-2013, 06:32 PM
  2. 99-06 Chevy 4wd Mid Travel/LT Questions
    By DiRt YoTa in forum Truck Talk
    Last Post: 11-29-2012, 09:17 AM
  3. H&m long travel questions?
    By tanner287 in forum General Off-road Talk
    Last Post: 08-28-2012, 11:05 AM
  4. Shock and travel questions
    By DJSchick88 in forum Truck Talk
    Last Post: 10-31-2009, 05:38 PM
  5. shock travel questions
    By 4literranger485 in forum Truck Talk
    Last Post: 02-02-2006, 07:07 PM
