i have a 94 ranger. im not gonna be driving this truck for a couple of months while im doin the cage on it. it has a full tank of gas that cost me 70 bucks. how do i get it out? i want to fill up my other truck
HOUSEHOLDER MOTORSPORTS
Clean-Dezert.org
myspace.com/deluxfab1112 ..... 777church.com
Dont worry about anything; instead pray about everything. tell god what you need
and thank him for all he has done. philippians 4:6
you could drop the tank and take the sender out and do it that way but i there has to be and easer way.......
aka B-Rad
ES Motorsports
Desertworks Fabrication
BT Motorsports
Can you get power to the fuel pump? I rigged up my truck with a manual fuel pump w/switch just for this purpose. And then disconnect the fuel line, dumped into a gascan.
Professional Oil Blender/Spiller
**I meant a manual switch for the stock pump, not a completely seperate fuel pump.
i was thinkin about siphoning it out but i didnt know if it has a anti siphon valve or somethin. the truck runs and everything i just want the gas for my other truck
Clean-Dezert.org
Takes to long. I would personally go with an Oxy/Acetylene set up. Burn a quick hole and the gas flows fast. Really though, they have a siphone at Pep Boys. just shake the rattla and the gas flows.Originally Posted by [b
DISCLAIMER........ If you are one of the slow types don't use the Oxy setup. The tank will empty faster than you can react.
Remember, green = diesel
Siphon is the way to go, you can go with a small line that is easier to pull a siphon from or a larger line for faster fill. Go to Lowes or Homedepot and just buy some cut to the foot 3/4 inch clear line so you can see the gas coming . Get a bunch of gas cans. Put the line down into your tank. crouch by the ground and suck on the hose until you see the gas just dropping below the frame. it will start to flow on its own. Those rattler ones work some of the time but not always. We used to need a ton of gas for the boat while in mexico wakeboarding, so we would siphon just enough out of our cars when we were desperate, just enough to get us back across the border. Hope this helps.
97 4x4 5sp 4.0
just jump constant power to the fuel pump. get a hose or line of some kind then you can just pump it directly into whatever you want to fill up. Why buy a $30 siphon your only gonna use once?
2003 silverado camburg everything
2007 crf250x
2008 crf 450x
exactly, pull a fuel line and fill it in a bottle til the pump stops pumping. done.Originally Posted by [b
That is another way to do it, but if you dont feel comfortable pulling a fuel line and doing new wiring, the hose at lowes or home depot wont even cost you 5 bucks, not 30
97 4x4 5sp 4.0
SMOKE DAT SHIT LIKE ITS SOME DANK ASS KRHROOONN!!!!!!!
BS welder or DR GOD?? DGAF!!
i knew i shoulda worn TWO rubbers when i hack sawed your moms gash in the bathroom of a bugerking for 10 dollars. who would have thought there would be a hole, and your dumbass would be the result?Originally Posted by [b
www.clean-dezert.org
R.I.P. #7227!!!!
ROFL, best post i've read in a long time!Originally Posted by [b
Titties and beer make me cheer.
So are you sayin you guys are related? Makes sense now......![]()
