Congrats! It really is an awesome feeling when you swap goes great and works like it should. I have stripped the harness down and I will post pics when I come back from Primm. Im going to remove the second o2 sensors since the pcm my friend has is tuned by Juanco and has had all the smog stuff removed. The previous person to try and "strip" the harness just cut out a bunch of stuff but never cleaned it up and left all the pins in the pcm connector in place with wires cut about 6" from the connector. Unpinned all those wires and removed any wire and connectors that they left in the harness that went to nothing or were not needed.
--JosB
