Results 1 to 13 of 13
    Custom User Title urandaman's Avatar
    Sep 2004
    TX
    Default rebuilding a c4, help
    i have a c4 to be rebuild before i put it in the truck, what areas need more attention than others when building it to handle the rigors of off road driving?
    also,stall speed? is there a certain range to be in, or should i slap the motor on a engine dyno to figure out power band first?
    where could i find a complete rebuild kit as well, ive searched summit a bit but it comes up with single parts and not rebuild kits.
    Who's ShiTalKing? partybarge_pilot's Avatar
    Leucadia
    2500 stall, manual valve body, big pan and big cooler(s)....... What you can do to it depends on how much your willing to spend.
    Monkey fab
    Quote Originally Posted by mcdirt@1s1k View Post
    also what makes him a "pro" because hes done it for 25 yrs? well fuck me ive been taking shits for 25 yrs! does that mean im a pro shitter? fuck no i still get the beer shits!
    Las Vegas, NV
    www.transmissioncenter.net
    manual valve body
    2500-3000 stall converter. get one built for your truck.
    300m input shaft
    welded drum
    good clutches and steels
    -Sean
    "NEVER UNDERESTIMATE THE POWER OF STUPID PEOPLE IN LARGE NUMBERS!!!"
    Sep 2004
    TX
    would a TCI or B&M or similar street/strip or full competition rebuild kit work, along with manual valve body, big pan and coolers?
    there is definately a budget, but i do not want to do it numerous times. the motor is going to be a 306 with a mild build, so it wont have 400+ hp/tq going through it..
    Las Vegas, NV
    a 306 with good heads, cam, and manifold will make close to 400hp.
    an input shaft and welded drum are good insurance, and about $275...
    -Sean
    Racer half-ass astronaut's Avatar
    El Segundo,CA
    I would get a good ArtCarr valve body( the AC from Texas, not the turkey neck art Carr from Huntington beach)
    300m shaft
    Larger oil pan
    Billet forward servo
    New Borg Warner bands and clutches and steels if your old ones are burned.
    I would personally go with a much lower stall speed like 1800-2000, if it's higher, it just means it's going to get hotter.
    First though, take the trans completely apart and check every corner for cracks and stress marks. Take a round file to anyplace starting to crack and fix them. Also, put steel helicoils in the outside bolt holes, aluminum will strip.
    Read up on the c4 and set the backlash properly. If you don't you'll end up blowing the trans internals to pieces.
    "Someone who thinks logically provides nice contrast to the real world"
    "Takes more than a 40 of King Cobra and a little hippy cabbage to make a car that bad." <-- on the topic of Dodge/Chrysler
    Quote Originally Posted by sparkypyro View Post
    Fastest way to a million dollars in desert racing is to start with 2 million.
    Sep 2004
    TX
    i looked up the art carr in texas, could not find a website, only forum posts saying they closed their doors...
    Las Vegas, NV
    higher stall converter only gets hot if you drive it below the stall speed...
    -Sean
    Racer DiRt YoTa's Avatar
    Ram, Ca
    too low of stall will lock up to early and your pounding woops with basically a clutch thats fully engaged so you blow up hard parts in trans and rear ends. too bad your not closer. i know a guy who will do it for cheap... over and over and over again
    22RE Master Tech
    Got boost?
    "this is an 81 Honda... How dare you!"
    Quote Originally Posted by Kellen_Cox View Post
    Hooker travel is the bastard child of the offroad world. devide by 0 to get the true travel numbers.
    Las Vegas, NV
    You're in Texas, call Broader Performance. The guy knows his shit..
    -Sean
    El Segundo,CA
    Quote Originally Posted by DiRt YoTa View Post
    ive never heard of this. I dont see how a torque converter that doesnt have a lock up feature would literally lock up, the slip is all in the clutch packs and in the end the tires.
    ive put my c4 through some pretty rough sections and when I rebuild it, the clutch packs get worn, but never to the point of absolute failure...
    the reason I recommend a low stall is (assuming he has a 4.0) the bellhousing is so small, heat generates faster with that little motors torque converter. Hence, the higher the stall, the more heat its going to generate when your running through slow rough sections, on and off the gas where your motor is running from 1000-2000 rpms, when wind isnt giving the most cooling capabilities....
    Sep 2004
    TX
    Quote Originally Posted by half-ass astronaut View Post
    going to have a 5.0 (306 or 347 depending on the difference in price overall)
    El Segundo,CA
    Nevermind.....
  1. Replies: 15
    Last Post: 02-20-2009, 06:44 PM
  2. Rebuilding help
    By Dezertsand450 in forum Truck Talk
    Last Post: 10-20-2007, 07:52 AM
  3. rebuilding a 4x4 tranny
    By lostbehindwords in forum Truck Talk
    Last Post: 06-02-2007, 08:48 PM
  4. rebuilding bypasses?
    By WhiteTrashCowboyCrew in forum General Off-road Talk
    Last Post: 03-13-2007, 11:59 PM
  5. Help Rebuilding my Top End
    By xxxjuhstenxxx in forum Dirt Bikes & Quads
    Last Post: 12-21-2006, 12:03 AM
