Page 2 of 2 FirstFirst 12
Results 41 to 47 of 47
7Likes
Thread: swapping M50D with C-4 worth it?
    Las Vegas, NV
    Quote Originally Posted by 2stroke2death View Post
    so it is possible for a c6 to bolt up to a 4.0?
    it's NOT necessary. the c4 is plenty strong...
    -Sean
    "NEVER UNDERESTIMATE THE POWER OF STUPID PEOPLE IN LARGE NUMBERS!!!"
    Racer half-ass astronaut's Avatar
    El Segundo,CA
    Direct bolt up, no.
    You would basically have to design a bellhousing adapter, and go through a bunch of headaches to gain almost nothing.
    "Someone who thinks logically provides nice contrast to the real world"
    "Takes more than a 40 of King Cobra and a little hippy cabbage to make a car that bad." <-- on the topic of Dodge/Chrysler
    Quote Originally Posted by sparkypyro View Post
    Fastest way to a million dollars in desert racing is to start with 2 million.
    Senior Asshole 2stroke2death's Avatar
    Altadena, CA
    thats what i figured. is a stock c4 strong enough or are there things that need to be done for it to be strong enough?
    Las Vegas, NV
    It's a good idea to get a 300m input shaft, a welded front drum, a billet servo, manual valvebody, and a rebuild kit that uses extra clutch plates..
    -Sean
    Altadena, CA
    if i do this, im doing it right. ill do all of that or get something thats already done
    Las Vegas, NV
    It's not even all that expensive for all that stuff. You can get all of it through broader, just make sure the valvebody you get is constant pressure with engine braking in all 3 gears...
    -Sean
    Altadena, CA
    will do. thanks for all the info
  1. M50d
    By shane1617 in forum Motor and Transmission
    Last Post: 02-27-2012, 12:02 AM
  2. 4.0 M50D manual to c-4
    By 04yfzkid in forum Fab Shop
    Last Post: 11-23-2009, 07:34 PM
  3. M50D transmission
    By 2000prerunner in forum Truck Talk
    Last Post: 10-28-2008, 07:36 PM
  4. M50D-R1 trans!!!
    By 87-RANGER in forum Wanted
    Last Post: 07-05-2008, 10:27 AM
  5. Mazda M50D-R1 2wd
    By broken2wd in forum Wanted
    Last Post: 05-09-2008, 11:50 AM
